查看: 3209|回复: 0
[NI驱动程序] NI-Sync 16.0 Driver Win32/64Eng NI PXI同步模块及实时控制器驱动程序下载June.2016
    2 小时前
    发表于 2020-9-3 00:05:24 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-Sync用于支持用户使用PXI同步模块或任何运行实时操作系统的NI控制器。
    NI-Sync是一个NI仪器驱动程序,用于配置系统定时和同步,包括基于信号的同步和直接使用时钟。您还可以使用时间协议(如IEEE 1588标准,IEEE 802.1AS标准,IRIG或GPS)执行基于时间的同步,作为时间戳的时间参考或执行同步时钟和触发生成。NI-Sync支持PXI同步模块和实时PXI、CompactDAQ和CompactRIO控制器以及紧凑视觉系统和工业控制器。NI-Sync中还包括高级实用程序及范例,可帮助用户更轻松地创建应用程序。
    百度网盘下载(限速,请开会员或使用工具下载):
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    NI官方下载地址(可能无法下载完成或地址无效):
    NI-Sync16.0.txt (244 Bytes, 下载次数: 0, 售价: 10 圆)
    文件大小: 1489321504 字节 (1.39 GB)
    修改日期: 2016-07-12 04:21
    MD5: f04f9cb0972b2300c5ba0668a5b0d13e
    SHA1: f7859daf852cd3cbbc46c339a1ebc1ca31d1fc27
    SHA256: 3b5680d455372390f8fdbc30eb477cf5ed876010e8303a869bde8c7eae4fc819
    CRC32: c3adb651
    NI-Sync 16.0 Readme
    June 2016
    This file includes important information about NI-Sync, including system requirements, a partial list of bugs fixed for NI-Sync 16.0, and known issues.
    Contents
    Supported Devices
    NI-Sync 16.0 supports the following operating systems:
    • Windows 7 x86, x64
    • Windows 8.1 x86, x64
    • Windows 10 x86, x64
    • Windows Server 2008 R2 (x64)
    • Windows Server 2012 R2 (x64)
    • NI Real-Time Phar Lap ETS
    The following table lists the application software versions, including service packs, supported by NI-Sync.
    Application SoftwareVersions Supported by NI-Sync
    LabVIEW2013, 2014, 2015, 2016
    LabVIEW Real-Time Module2013, 2014, 2015, 2016
    LabWindows™/CVI™2013, 2015
    NI-Sync 16.0 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, NI-Sync drops support for Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-Sync 16.0 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-Sync 16.0 to an unsupported OS. Additionally, after installing NI-Sync 16.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Supported Devices
    NI-Sync 16.0 supports the following devices:
    Signal-Based Modules
    • NI PXI-6651
    • NI PXI-6652
    • NI PXI-6653
    • NI PXIe-6672
    • NI PXIe-6674
    • NI PXIe-6674T
    Time-Based Modules
    • NI PCI-1588
    • NI PXI-6682
    • NI PXI-6682H
    • NI PXI-6683
    • NI PXI-6683H
    You can access the software and documentation known issues list online. For a list of known issues with NI-Sync 16.0, visit ni.com/info and enter the Info Code NISync160KnownIssues.
    For a list of bug fixes for NI-Sync, visit ni.com/info and enter the Info Code NISyncFixList.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for NI-Sync are located in the \examples\instr\niSync directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    • For signal-based examples that use clocks and triggers directly, open the NI Example Finder and navigate to Hardware Input and Output»Timing and Synchronization»Signal-Based.
    • For time-based examples that use time references such as IEEE 1588-2008 or GPS as a basis for synchronization, open the NI Example Finder and navigate to Hardware Input and Output»Timing and Synchronization»Time-Based.
    • For more information on silent installations of suited NI products, such as NI Developer Suite, refer to KB 4GGGDQH0, How Do I Automate the Installation of a Suited Installer?.
    When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8.
    Note  MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8.x. You can launch MAX either from the Apps view or from within NI Launcher.
    ©2003-2016 National Instruments. All rights reserved.
    375085D-01
    GMT+8, 2026-4-23 10:38
