查看: 3627|回复: 0
[NI软件产品] LabVIEW 2015 FPGA Module Xilinx Compilation Tools Win32Eng LV2015FPGA编译工具(ISE 10.1)
    2 小时前
    发表于 2020-8-18 21:48:52 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    2015Xilinx10
    发布日期
    15-6-25
    受支持的操作系统
    Windows XP 32-bit
    Windows XP 64-bit
    Windows Vista 32-bit
    Windows Vista 64-bit
    Windows 7 32-bit
    Windows 7 64-bit
    语言
    English
    校验和
    (MD5)
    1049AD1264627EB6B4F705EC2BD2C8CF
    LV-FPGA-CT-2015.txt (246 Bytes, 下载次数: 1, 售价: 10 圆)
    LabVIEW 2015 FPGA Module Xilinx Compilation Tools for Windows DVD Readme
    June 2015
    This file contains important information about the LabVIEW FPGA Module Xilinx Compilation Tools for Windows DVD, including system requirements and installation instructions.
    With the LabVIEW 2015 FPGA Module Xilinx Compilation Tools for Windows DVD, one installation gives you access to Xilinx Compilation Tools for Vivado 2014.4 and ISE 14.7, which are supported by the LabVIEW FPGA Module. Install these compilation tools if you want to compile your FPGA VIs on a Windows computer. You also must install these tools on the development computer if you plan to use the Configure Component-Level IP wizard, configure the IP Integration Node, incorporate Xilinx IP, use FPGA IP Builder, or use third-party simulation.
    The LabVIEW FPGA Module Xilinx Compilation Tools for Windows have the following system requirements:
    • Windows 7/Vista/XP Professional (32-bit and 64-bit)
    • 11 GB of disk space
    Note NI recommends a 64-bit OS for the computer on which you install the Xilinx compilation tools.
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2015.
    The following sections contain the NI hardware supported by the LabVIEW 2015 FPGA Module Xilinx Compilation Tools on Windows:
    Use the Xilinx Compilation Tools for Vivado 2014.4 to compile FPGA VIs for the following devices:
    • IC-317x
    • NI 914x
    • NI cRIO-903x, NI cRIO-906x
    • NI PXIe-517xR, NI PXIe-5624R, NI PXIe-5820R, NI PXIe-5840R, NI PXIe-659xR, NI PXIe-782xR, NI PXIe-793xR, NI PXIe-797xR, NI PXIe-7902R
    • NI sbRIO-9651, NI sbRIO-9607, NI sbRIO-9627, NI sbRIO-9637
    • NI USB-785xR
    • NI USRP-RIO 294x, NI USRP-RIO 295x
    Xilinx Compilation Tools for ISE 14.7
    Use the Xilinx Compilation Tools for ISE 14.7 to compile FPGA VIs for the following devices:
    • NI PXI-784xR, NI PXI-785xR, NI PXI-795xR
    • NI PCIe-784xR, NI PCIe-785xR
    • NI PXIe-796xR, NI PXIe-564xR
    • NI cRIO-907x, NI cRIO-908x, NI cRIO-911x
    • NI sbRIO-960x, NI sbRIO-961x, NI sbRIO-962x, NI sbRIO-963x, NI sbRIO-964x
    • NI 9144, NI 9146, NI 9148, NI 915x
    Install the Xilinx Compilation Tools for ISE 10.1 if your FPGA device contains a Xilinx Virtex II chip. Visit ni.com/info and enter the Info Code FPGATool101 to download the Xilinx Compilation Tools for ISE 10.1.
    You can find installation instructions for the LabVIEW FPGA Module Xilinx Compilation Tools for Windows in the LabVIEW FPGA Module Release and Upgrade Notes, which are available online at ni.com/manuals and on the LabVIEW 2015 Platform media.
    To request additional LabVIEW Platform media, refer to the National Instruments website.
    NI LabVIEW FPGA Module Xilinx Compilation Tools for Windows Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW FPGA Module Xilinx Compilation Tools for Windows will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of LabVIEW FPGA Module Xilinx Compilation Tools for Windows that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    Info Code
    LabWindows™/CVI™cvi_lifecycle
    © 2012–2015 National Instruments. All rights reserved.
    Third-Party Copyright Notices
    \LabVIEW 2015\FPGA\Legal
    The Python_2.5_notice.pdf file contains a third-party copyright notice for third-party components used by certain FPGA Module features. The following directory is the default installation location for the file, but the location might vary depending on the configuration of the local computer:
    374738C-01
    GMT+8, 2026-4-23 10:50
