查看: 5901|回复: 0
[NI软件产品] NI Switch Executive 2019 Full Win32/64Eng 美国国家仪器开关管理软件NISE19.0.0离线安装完整版下载
    3 小时前
    发表于 2020-8-8 00:45:47 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Switch Executive是一款开关管理与路由应用软件,能够加速开发过程、简化对复杂开关系统的维护。
    Switch Executive提供交互式配置和自动路由功能,使开关系统的设计变得更加容易。您可以为开关模块、外部连接和信号路由分配别名,从而简化系统的文档,以便未来进行修改。使用Switch Executive开发的测试代码可以复用于LabVIEW、LabWindows/CVI、Measurement Studio和TestStand环境。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    请注册登录视觉论坛会员,购买附件查看
    请注册登录视觉论坛会员,购买附件查看
    (MD5) 3549593d426a4f1dbda0d8f2e1686957
    (SHA256) 8bf23a1dbd7d49ffadfa56837a8be76153edf3982573ede2327864e3a6e466d5
    SE19.0.0.txt (291 Bytes, 下载次数: 0, 售价: 10 圆)
    Switch Executive 2019 Readme
    March 2019
    This file contains important information about Switch Executive, including installation instructions, new features, and known issues.
    Switch Executive Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    Switch Executive is a switch management and routing application that accelerates development and simplifies maintenance of complex switch systems.
    Switch Executive 2019 has the following requirements:
    Switch Executive 2019 supports the following operating systems:
    • Windows 10/8.11/7 SP12
    Note  In 2017, Switch Executive dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. Switch Executive 2019 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use Switch Executive 2019 to an unsupported OS. Additionally, after installing Switch Executive 2019, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    For more information about the changes to our OS support for 2016, refer to Why Does my LabVIEW, LabWindows/CVI, Measurement Studio, or TestStand Built Installer Fail on Windows XP/Vista and Server 2003?.
    Switch Executive 2019 supports the following application software versions, including service packs.
    Versions Supported by Switch Executive
    LabVIEW2016, 2017, 2018, 2019
    LabVIEW NXG3.0, 3.1
    LabWindows™/CVI™2013 and later
    • Install an ADE, such as LabVIEW or LabWindows™/CVI™.
    • Visit ni.com/downloads and search for Switch Executive 2019.
    • Click Switch Executive 2019 and then the download link and run the executable (.exe) file.
    • Follow the instructions in the installation prompts. You may see access and security prompts during installation. Accept the prompts to complete the installation.
    • When the installer completes, select Restart in the dialog box that prompts you to restart, shut down, or restart later.
    Note
    • If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/info and enter the Info Code f4l4xp for more information and steps to resolve this issue.
    Installing Switch Executive for LabVIEW NXG
    Switch Executive no longer installs IVI Compliance Package. Switch Executive supports IVI configuration and runtime, but no longer supports the following features:
    • IVI-COM Adapters
    If you want to use the above features, you must install IVI Compliance Package separately, either from ni.com/downloads or from the NI Device Drivers 2019 DVD.
    • Switch Executive 2019 adds support for LabVIEW 2019 and LabVIEW NXG 3.1.
    Switch Executive supports all IVI switches, which includes all National Instrument switches and some third-party switches.
    You can access the software and documentation known issues list online. Visit ni.com/info and enter the Info Code eximpk for an up-to-date list of known issues in Switch Executive 2019.
    Refer to the NI Switch Executive Help, accessible from Start»All Programs»National Instruments»Switch Executive»Switch Executive Documentation, for information about Switch Executive.
    You can access all the installed Switch Executive examples at Start»All Programs»National Instruments»Switch Executive»Switch Executive Examples and online at ni.com/examples.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for Switch Executive are located in the LabVIEW XXXX\examples\SwitchExecutive directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    • Click the Browse tab to locate modulation examples by task at Toolkits and Modules»NI Switch Executive.
    • Click the Search tab to search all installed examples by keyword. For example, search for "Switch Executive" to locate all Switch Executive examples.
    The following sections detail considerations for using LabVIEW NXG with Switch Executive.
    LabVIEW NXG Help
    LabVIEW NXG Examples
    • For more information about silent installations of individual NI products, refer to Automating the Installation of a Single Installer.
    • For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to How Do I Automate the Installation of a Suited Installer?.
    • To determine what version of NI Installers your product contains, refer to How Can I Determine the Type and Version of My NI Installer?.
    When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8.
    Switch Executive will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    Info Code
    LabWindows/CVIcvi_lifecycle
    © 2002–2019 National Instruments. All rights reserved.
    375352E-01
    GMT+8, 2026-4-23 11:02
