查看: 4071|回复: 0
[NI软件套件] NI Software Platform Bundle-X86-Eng_2009_suite Win32Eng NI SPB2009 32位英文版下载,基于LabVIEW2009
    8 小时前
  • 签到天数: 3849 天
    连续签到: 42 天
    发表于 2020-8-4 23:59:26 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    包含3DVD
    请注册登陆视觉论坛账号,购买附件查看下载地址,充值请联系在线客服
    SPB2009.txt (533 Bytes, 下载次数: 3, 售价: 50 圆)
    LabVIEW 2009 Platform DVDs Readme
    With the LabVIEW Platform DVDs, one installation gives you access to nearly all products in the LabVIEW platform. Install modules and toolkits from the DVDs to ensure compatibility with LabVIEW 2009. If you purchased any of these add-ons, install and activate them using the LabVIEW Platform DVDs. If you want to evaluate any of these add-ons before purchasing them, you can install these add-ons from the LabVIEW Platform DVDs and try them for free for 30 days.
    Installing, Evaluating, and Activating LabVIEW
    Installing Another Language Version
    LabVIEW Module and Toolkit Compatibility
    Readmes for Products on the LabVIEW Platform DVDs
    Important Information
    You can run the LabVIEW Platform installer on the following operating systems:
    • Windows Vista, including Windows Vista x64
    • Windows XP, excluding Windows XP x64
    • Windows 2000
    Note  The LabVIEW Platform installer does not support Windows NT/Me/98/95 or any of the Windows Server editions.
    Refer to the LabVIEW Release Notes for a complete list of system requirements for the LabVIEW Development System and to the product readmes for additional module and toolkit system requirements.
    Refer to the National Instruments Web site for the latest information about and instructions for downloading LabVIEW 2009 (64-bit).
    Complete the following steps to install and activate LabVIEW for Windows.
    • Disable any automatic virus detection programs before you install. Some virus detection programs interfere with installation.
    • Insert the LabVIEW Platform DVD 1.
    • In the Product List, select all the products you want to install licensed versions of or that you want to install for evaluation. Select Install to minimize user interaction. Selecting Custom install opens additional dialog boxes that require your input.
      Note  Some LabVIEW products have additional system requirements. As you select each product in the Product List, verify that the computer on which you are installing meets the additional requirements listed in the description.
    • Enter serial numbers from the software kits to install licensed versions. Leave the Serial Number field blank to evaluate the product. You can find the serial number on the Certificate of Ownership in the software kit. If your software kit does not include a Certificate of Ownership, you can find the serial number on the product packing slip or on the shipping label.
      Note  You can use serial numbers from a previous version of a product to install and activate the 2009 version of the product.
    • Follow the instructions to finish installing and activating LabVIEW and any module or toolkit that you selected.
    • After installation, enable any virus detection programs you disabled.
    To modify the current LabVIEW installation or to uninstall LabVIEW, select National Instruments Software in the Add/Remove Programs applet in the Control Panel. When you modify the installation, a list of National Instruments software appears. Select a product in the list to add or remove individual components or to uninstall the product. Select multiple products to remove by pressing the or key while you select each product. Click the Uninstall button to remove all the products you selected.
    If you have another language version of LabVIEW 2009 installed on your computer, uninstall that version before installing the new language version.
    Note  LabVIEW SignalExpress is a multilingual product that operates in the same language as the system locale for English, French, German, and Japanese. All other system locales default to the English version of LabVIEW SignalExpress. You do not need to uninstall LabVIEW SignalExpress to change languages.
    Use the LabVIEW Platform DVDs to ensure you install modules and toolkits that are compatible with LabVIEW 2009. If the LabVIEW Platform DVDs do not include the module or toolkit you need, first refer to the LabVIEW Module and Toolkit Compatibility Information page for information about which modules and toolkits are compatible with the current version of LabVIEW. Then install the compatible module or toolkit in the LabVIEW 2009 directory and mass compile any VIs that you saved in previous versions of LabVIEW.
    Other toolkit versions might not work with LabVIEW 2009. If you attempt to install incompatible toolkit versions, you might corrupt your LabVIEW 2009 installation. If you install an incompatible version and corrupt your LabVIEW 2009 installation, first uninstall the toolkit and then repair the LabVIEW installation using the Add/Remove Programs applet in the Control Panel.
    Refer to the following readmes for information about each product on the LabVIEW Platform DVDs, including installation, activation, known issues, and bug fixes.
    • LabVIEW Development System
    • Adaptive Filter Toolkit
    • Advanced Signal Processing Toolkit
    • Control Design and Simulation Module
      • Control Design Assistant
    • Database Connectivity Toolkit
    • DataFinder Toolkit
    • Datalogging and Supervisory Control Module
    • Desktop Execution Trace Toolkit for Windows
    • Digital Filter Design Toolkit
    • FPGA Module
    • Internet Toolkit
    • LabVIEW SignalExpress
      • English
      • French
      • German
      • Japanese
    • MathScript RT Module
    • Microprocessor SDK
    • Mobile Module
    • NI Motion Assistant
    • NI SoftMotion
    • PID and Fuzzy Logic Toolkit
    • Real-Time Execution Trace Toolkit
    • Real-Time Module
    • Report Generation Toolkit for Microsoft Office
    • Simulation Interface Toolkit
    • Sound and Vibration
      • Sound and Vibration Assistant
      • Sound and Vibration Assistant (Japanese)
      • Sound and Vibration Analysis VIs
    • Statechart Module
    • System Identification Toolkit
    • Touch Panel Module
    • Unit Test Framework Toolkit
    • VI Analyzer Toolkit
    • Vision Development Module
    © 2003–2009 National Instruments Corporation. All rights reserved.
    For copyright notices, conditions, and disclaimers, including information regarding certain third-party components used in LabVIEW, refer to the Copyright topic of the LabVIEW Help.
    NI设备驱动自述文件2009年8月发行
    © 2003-2009 National Instruments. 版权所有
    专利权
    关于NI产品的专利权,见软件中的帮助>>专利信息、当前文件夹中的patents.txt文件,或访问ni.com/patents。
    关于NI-DAQ的重要信息
    NI-DAQ 8.x包含在驱动程序的最新版本中,称为NI-DAQmx。 NI-DAQmx取代了传统NI-DAQ(Legacy)。 NI-DAQmx和传统NI-DAQ(Legacy)均有各自的API、硬件和软件配置。
    传统NI-DAQ(Legacy)是较早版本的DAQ驱动,其中包含的API可用于为早期NI DAQ设备开发数据采集、仪器使用和控制程序。 传统NI-DAQ(Legacy)只在某些特定情况下使用。 关于两种NI-DAQ API的概述,NI-DAQmx的优点,以及使用传统NI-DAQ(Legacy)的更多信息(包括支持设备、操作系统、应用程序版本和语言版本的完整列表),见NI-DAQ的自述文件。 如需安装最新版本的NI-DAQmx软件,可访问ni.com/downloads
    设备驱动自述文件
    关于NI设备驱动的最新重要信息,见下列相关产品的自述文件:
    • 数据采集
      • NI-DAQ 8.9.5
      • 传统NI-DAQ 7.4.4 (Legacy)
    • 仪器控制
      • NI-488.2 2.7.1
      • NI-VISA 4.5.1
      • NI-Serial 3.4
      • IVI Compliance Package 4.0
    • 模块化仪器
      • NI-Switch 3.8.5
      • NI-DMM 3.0
      • NI-Scope 3.5.2
      • NI-RFSA 2.1.2
      • NI PXI-5660支持
      • NI-FGEN 2.6.3
      • NI-DCPower 1.3.1
      • NI-RFSG 1.5.1
      • NI-HSDIO 1.6.1
    • 可配置IO
      • NI-RIO 3.2
    • 运动与视觉
      • NI-Motion 8.0
      • NI-IMAQ 4.3
    • 分布式I/O
      • NI-FieldPoint 6.0.5
    • 实时和嵌入式
      • NI-488.2 2.7.1
      • NI-Serial 3.3.4
    • 通信总线和协议
      • NI-CAN 2.6.3
      • NI-DNET 1.6.4
      • I2C和SPI
        • NI-845x 1.1.3
    • NI LabVIEW SignalExpress 2009
    安装说明
    插入光盘后,将弹出启动窗口。 在该窗口中,单击安装设备驱动程序,即可启动安装。 如未弹出启动窗口,可直接从光盘的根目录启动setup.exe。
    系统要求
    安装程序只能运行在以下Microsoft操作系统上:
    • Windows XP
    • Windows 2000
    • Windows Vista x86
    • Windows Vista x64
    必须在计算机上安装3.0版本的MSI (Windows Installer)引擎,才可运行安装程序。 如计算机上未安装3.0或更高版本的MSI,安装程序将自动更新引擎,并可能要求用户重新启动计算机。
    安装特定组件的附加要求
    安装某些组件时,需满足附加要求。
    组件附加系统要求NI软件要求
    以下产品的Visual C++ 2008支持:
    • NI-DAQmx
    • NI -488.2
    • NI-VISA
    National Instruments Measurement Studio VC++ 2008
    以下产品的Visual C++ 2005支持:
    • NI-DAQmx
    • NI -488.2
    • NI-VISA
    National Instruments Measurement Studio VC++ 2005
    以下产品的Visual C++ 2003支持:
    • NI-DAQmx
    • NI -488.2
    • NI-VISA
    National Instruments Measurement Studio VC++ 2003
    以下产品的.NET Framework 1.1和2.0支持:
    • NI-DAQmx
    • NI -488.2
    • NI-VISA
    Microsoft .NET Framework 1.1
    Microsoft .NET Framework 2.0
    以下产品的LabWindows/CVI支持:
    • NI-DAQmx
    • NI-CAN
    • NI-DNET
    7.0或更高版本的LabWindows/CVI
    其它安装说明
    如在Windows Vista上安装NI驱动软件,必须先卸载所有比2007年2月驱动版本更早的NI软件。 ni.com/kb上的知识库文章46BH366K包含更多的相关信息,以及在Windows Vista上升级NI驱动软件的辅助工具。如需通过网络安装NI设备驱动程序,可复制整张DVD中的内容至一个目录,运行该位置的安装程序。您可通过编程启用或禁用NI设备驱动程序安装包中的各个组件,选择安装所需NI设备驱动程序,实现无人值守的安装。 关于在无人值守情况下,选择安装所需NI设备驱动程序的更多信息,见自述文件所在目录中的spec.ini文件。
    卸载说明
    如需卸载NI设备驱动程序,可在Windows的添加/删除程序中选择NI软件。
    GMT+8, 2026-4-7 17:21
