查看: 3597|回复: 0
[NI软件产品] NI SystemLink Client 18.5.2 Win64Eng NI系统连接客户端SLC18.5.2
    发表于 2020-7-29 20:57:05 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    SystemLink Client为SystemLink Server管理的硬件系统提供了本地设备处理和配置。
    SystemLink Client包含处理服务和API,可实现SystemLink的远程配置功能和数据服务。由SystemLink Server管理的每个硬件设备必须安装SystemLink Client才能管理与服务器的通信。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    请注册登录视觉论坛会员,购买附件查看
    SLC18.5.2.txt (295 Bytes, 下载次数: 1, 售价: 10 圆)
    文件大小: 791046622 字节 (754.40 MB)
    修改日期: 2019-03-16 01:47
    MD5: e80b03529f8aaaa138937b4bf01da4dd(官方正确)
    SHA1: 862fad531281b3077fcc35fc3f9e73387d2c419b
    SHA256: f89673e900fb67d8bc4659b5f47406e0f6d17bc52f550fc1490df8e75c99ce53
    CRC32: 2be07589
    NI SystemLink 18.5 Readme
    January 2019
    This file contains important information about NI SystemLink, including system requirements and known issues.
    Licensing Information for SystemLink Clients
    Use NI SystemLink to discover and manage systems on a server. Create and deploy packages to all your managed systems. Leverage Skyline data services to visualize data, trigger alarms, monitor tests,and transfer files over a server.
    NI SystemLink has the following minimum system requirements:
    Server Requirements
    Windows, less than 50 nodes
    Windows, 50+ nodes
    OS
    Windows Server 2016
    Windows Server 2012 R2 (64-bit)
    Windows 7 SP1 (64-bit) or higher
    Windows Server 2016
    Processor
    2-core recommended or higher
    8-core recommended or higher
    RAM
    6 GB minimum
    8+ GB recommended
    16+ GB recommended
    Disk
    6 GB minimum
    8+ GB recommended
    16+ GB recommended
    Target Requirements (Managed Nodes)
    NI PXI (Windows) or Windows PC
    NI CompactRIO
    OS
    NI Linux Real-Time 2018
    Processor
    Pentium 4 G1 (or equivalent) or later
    All Intel and ARM models supported
    RAM
    2 GB minimum
    4 GB recommended
    512 MB minimum
    1+ GB recommended
    Note: NI SystemLink does not support targets with less than 512 MB of RAM.
    Disk
    1 GB minimum
    2+ GB recommended
    512 MB
    Note: VxWorks and Phar Lap OS are not supported.
    Additional Requirements for Servers and Targets
    • .NET Framework 4.6.2
    • One of the following browsers:
      • Chrome
      • Firefox
      • Edge
      • Safari
    Note: NI SystemLink 18.5 web applications do not support Internet Explorer.
    LabVIEW Requirements
    NI SystemLink 18.5 supports the following LabVIEW versions:
    • LabVIEW 2015, 2016, 2017, 2018
    • LabVIEW RT 2017, 2018
    SystemLink uses Volume License Manager to license clients. Download NI Volume License Manager from ni.com and refer to the NI Volume License Manager help for more information on licensing.
    If you evaluate NI SystemLink Server before activating, any clients you connect will initially appear as Not Activated in Systems Manager. Use NI SystemLink Web Application to activate the client after you activate the server.
    Installing SystemLink onto a machine with TDM Server 2017 already installed will break TDM Server 2017. NI recommends you install SystemLink on a different machine or uninstall TDM Server 2017 prior to installing SystemLink.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in SystemLink.
    The following items are the IDs and titles of a subset of issues fixed in SystemLink. This is not an exhaustive list of issues fixed in the current version of SystemLink 18.5. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    ID
    Fixed Issue
    721833Only oldest test results are shown when 1000+ results are in Test Monitor
    719447The Help button in File Viewer and Tag Viewer take you to an NI page that displays "Page Error"
    719351Dashboard canvas scrolls to the top when a control is selected
    718206SystemLink hangs when upgrading NI Package Manager from 18.5 to 18.5.1
    714553Previewing TDMS files without permissions produces HTTP error 401
    Refer to the NI SystemLink Help, accessible from ni.com, for more information about NI SystemLink.
    Refer to the SystemLink GitHub repository for examples and HTTP API documentation.
    © 2017-2019 National Instruments. All rights reserved.
    377243F-01
    GMT+8, 2026-4-23 09:13
