查看: 4065|回复: 0
[NI软件产品] NI SystemLink Client 18.1.1 Win64Eng NI系统连接客户端SLC18.1.1
    发表于 2020-7-29 20:47:22 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    SystemLink Client为SystemLink Server管理的硬件系统提供了本地设备处理和配置。
    SystemLink Client包含处理服务和API,可实现SystemLink的远程配置功能和数据服务。由SystemLink Server管理的每个硬件设备必须安装SystemLink Client才能管理与服务器的通信。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    请注册登录视觉论坛会员,购买附件查看
    SLC18.1.1.txt (294 Bytes, 下载次数: 0, 售价: 10 圆)
    文件大小: 775992846 字节 (740.04 MB)
    修改日期: 2018-10-05 22:47
    MD5: 2c1e5c5c5276803b44f92165926db2e9
    SHA1: 325b57d394abd8b1ff656ed71cd69384bcb34338
    SHA256: e77020a644c572be68620b241ac1470f8cd4146dc27f901871bc94d47dd5e3cf
    CRC32: 8e1f258d
    NI SystemLink 18.1 Readme
    July 2018
    This file contains important information about NI SystemLink, including system requirements and known issues.
    Licensing Information for SystemLink Clients
    Use NI SystemLink to discover and manage systems on a server. Create and deploy packages to all your managed systems. Leverage Skyline data services to visualize data, trigger alarms, monitor tests,and transfer files over a server.
    NI SystemLink has the following minimum system requirements:
    Server Requirements
    Windows, less than 50 nodes
    Windows, 50+ nodes
    OS
    Windows Server 2016
    Windows Server 2012 R2 (64-bit)
    Windows Server 2008 R2 (64-bit)
    Windows 7 SP1 (64-bit) or higher
    Windows Server 2016
    Processor
    2-core recommended or higher
    8-core recommended or higher
    RAM
    6 GB minimum
    8+ GB recommended
    16+ GB recommended
    Disk
    6 GB minimum
    8+ GB recommended
    16+ GB recommended
    Target Requirements (Managed Nodes)
    NI PXI (Windows) or Windows PC
    NI CompactRIO
    OS
    NI Linux Real-Time 2018
    Processor
    Pentium 4 G1 (or equivalent) or later
    All Intel and ARM models supported
    RAM
    2 GB minimum
    4 GB recommended
    512 MB minimum
    1+ GB recommended
    Note: NI SystemLink does not support targets with less than 512 MB of RAM.
    Disk
    1 GB minimum
    2+ GB recommended
    512 MB
    Note that VxWorks and Phar Lap OS are not supported.
    Additional Requirements for Servers and Targets
    • .NET Framework 4.6.2
    • One of the following browsers:
      • Chrome
      • Firefox
      • Edge
      • Internet Explorer
      • Safari
    LabVIEW Requirements
    NI SystemLink 18.1 supports the following LabVIEW versions:
    • LabVIEW 2015, 2016, 2017, 2018
    • LabVIEW RT 2017, 2018
    SystemLink uses Volume License Manager to license clients. Download NI Volume License Manager from ni.com and refer to the NI Volume License Manager help for more information on licensing.
    If you evaluate NI SystemLink Server before activating, any clients you connect will initially appear as Not Activated in Systems Manager. Use NI SystemLink Web Application to activate the client after you activate the server.
    Installing SystemLink onto a machine with TDM Server 2017 already installed will break TDM Server 2017. NI recommends you install SystemLink on a different machine or uninstall TDM Server 2017 prior to installing SystemLink.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in SystemLink.
    The following items are the IDs and titles of a subset of issues fixed in SystemLink 18.1. This is not an exhaustive list of issues fixed in the current version of SystemLink. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    ID
    Fixed Issue
    699210High CPU usage on Linux RT Salt Minions
    702585Uninstall button enabled for target's essential software
    700688Cannot install the Skyline Test Monitor Support for TestStand on machines without the TestStand Development Environment
    702587Available Feeds tab times out while trying to load the available feeds for a managed system
    698874Dashboard Builder does not update in web browser if you have used a previous version
    The following items are the IDs and titles of additional issues fixed in SystemLink 18.1.1.
    ID
    Fixed Issue
    706519Periods in device names cause managed systems to appear disconnected
    707573Missing dependency on startup can cause services crash loop
    Refer to the NI SystemLink Help, accessible from ni.com, for more information about NI SystemLink.
    © 2017-2018 National Instruments. All rights reserved.
    377243D-01
    GMT+8, 2026-4-23 09:13
