查看: 4282|回复: 0
[NI软件产品] NI SystemLink Suite 19.5.1 Win32/64 Eng/Ger/Chs/Jpn NI系统连接套件19.5.1版百度网盘下载
    2 小时前
    发表于 2020-7-28 11:16:44 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    SystemLink软件为测试和测量系统提供软件部署、系统配置、测试监控和数据管理工具。
    SystemLink软件提供了一个基于网络的解决方案来管理所连接系统、软件配置以及测试结果和测量数据,进而帮助企业提高运营效率和生产力。SystemLink可以与LabVIEW、NI TestStand、LabVIEW NXG(SystemLink19.6版以后支持)、DIAdem(SystemLink19.0版以后支持)等NI软件以及硬件之间完全互操作,包含了用于集成各种第三方软件和硬件技术的工具。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    请注册登录视觉论坛会员,购买附件查看
    SL19.5.1.txt (306 Bytes, 下载次数: 0, 售价: 20 圆)
    文件大小: 2260189184 字节 (2.10 GB)
    修改日期: 2019-11-15 09:37
    MD5: 1bf631abe9d13d7f91a0f59b8090752c(官方正确)
    SHA1: cb89e4a7ae8d7c21840464565b4974727e47b32c
    SHA256: db7b871604af21e74d92f8b4ee09ab6a1d7a9fd58ddbdf82e9846858d3643f8f
    CRC32: 577fc2c5
    NI SystemLink 19.5 Readme
    September 2019
    This file contains important information about NI SystemLink, including system requirements and known issues.
    Licensing Information for SystemLink Clients
    Use NI SystemLink to discover and manage systems on a server. Create and deploy packages to all your managed systems. Leverage SystemLink data services to visualize data, trigger alarms, monitor tests, manage assets, and transfer files to a server. SystemLink TDM is a Big Analog Data™ solution for automated preparation and analysis of large amounts of data in various formats and structures from different geographic locations.
    NI SystemLink has the following minimum system requirements:
    Server Requirements
    Windows, less than 50 nodes
    Windows, 50+ nodes, SystemLink TDM
    OS
    Windows Server 2016
    Windows Server 2012 R2 (64-bit)1
    Windows 7 SP1 (64-bit) or higher
    Windows Server 2016
    Processor
    4-core recommended or higher
    8-core recommended or higher
    RAM
    6 GB minimum
    16+ GB recommended
    16 GB minimum
    32+ GB recommended
    Disk
    6 GB minimum
    8+ GB recommended
    16+ GB recommended
    1 NI software installs VC2015 runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2, require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    Note  SystemLink TDM does not support server versions from the Microsoft Semi-Annual Channel. In addition, SystemLink TDM does not support Windows Server Core mode.
    Target Requirements (Managed Nodes)
    NI PXI (Windows) or Windows PC
    NI CompactRIO
    OS
    Windows 7 SP1 (32-bit) or higher
    NI Linux Real-Time 2019
    Processor
    Pentium 4 G1 (or equivalent) or later
    All Intel and ARM models supported
    RAM
    2 GB minimum
    4 GB recommended
    512 MB minimum
    1+ GB recommended
    Note: NI SystemLink does not support targets with less than 512 MB of RAM.
    Disk
    1 GB minimum
    2+ GB recommended
    512 MB
    Note: VxWorks and Phar Lap OS are not supported.
    Additional Requirements for Servers and Targets
    • .NET Framework 4.6.2
    • One of the following browsers:
      • Chrome
      • Firefox
      • Edge
      • Safari
    Note: NI SystemLink 19.5 web applications do not support Internet Explorer.
    Supported Software
    NI SystemLink 19.5 supports the following LabVIEW versions:
    • LabVIEW 2016, 2017, 2018, 2019
    • LabVIEW RT 2017, 2018, 2019
    SystemLink TDM supports the following DIAdem versions as clients:
    • DIAdem 2015, 2017, 2018, 2019 (recommended)
    SystemLink uses Volume License Manager to license server modules and add-ons as well as clients. Download NI Volume License Manager from ni.com and refer to the NI Volume License Manager help for more information on licensing.
    If you evaluate NI SystemLink Server before activating, any clients you connect will initially appear as Not Activated in Systems Manager. Use NI SystemLink Web Application to activate the client after you activate the server.
    Known IssuesYou can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in SystemLink.Bug Fixes
    The following items are the IDs and titles of a subset of issues fixed in SystemLink. This is not an exhaustive list of issues fixed in the current version of SystemLink 19.5. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    Note  If you installed SystemLink 19.5.1, refer to the NI SystemLink 19.5.1 Readme for information about the bugs fixed in that version.
    ID
    Fixed Issue
    733866SystemLink TDM crashes if the system is low on RAM or disk space
    737691In rare cases the index may contain orphaned entries due to a race condition. To purge these orphaned entries, the "Optimize Index" method was enhanced.
    727677If you assign the value "MoveToLoadedLevel" to the PropInheritanceModeDF variable in an analysis script, DIAdem does not replace the "root_abc" property with "root~abc". This means that the properties are not grouped correctly.
    745479SystemLink sometimes fails to deploy RT applications when configured to use HTTPS with a self-signed certificate
    741742C# services only uses TLS 1.0 for RabbitMQ connection
    Refer to the NI SystemLink Manual, accessible from ni.com, for more information about NI SystemLink and the services and APIs it offers.
    © 2017-2019 National Instruments. All rights reserved.
    377243J-01
    GMT+8, 2026-4-23 10:38
