查看: 4470|回复: 0
[TestStand] NI TestStand 2010SP1 and Patch 美国国家仪器测试序列管理软件TS2010SP1及补丁下载
    14 小时前
  • 签到天数: 3863 天
    连续签到: 56 天
    发表于 2020-2-29 18:37:50 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    TestStand是一款旨在帮助测试和验证工程师快速构建和部署自动化测试系统的应用软件。自TestStand2010版开始,TS版本号由数字改为年代版本。自TestStand2014版开始,增加TS64位版本。
    TestStand是一款可立即运行的测试管理软件,可帮助您快速开发自动化测试和验证系统。您可以使用TestStand来开发、执行和部署测试系统软件。还可以通过在TestStand中开发测试序列来扩展系统的功能,这些测试序列可集成使用任何编程语言编写的代码模块。TestStand还为报告生成、数据库记录以及与其他企业系统的连接提供了可扩展的插件。您可以使用易用的操作界面将测试系统部署到生产环境中。
    TestStand2010SP1
    链接: 请注册视觉论坛会员登录后购买附件下载查看 提取码: 请购买附件下载查看
    TestStand2010SP1Patchf1补丁
    TestStand2010
    请购买附件下载查看
    请购买附件下载查看
    TS2010SP1.txt (1.03 KB, 下载次数: 8, 售价: 10 圆)
    NI TestStand™ 2010 SP1 Readme
    July 2011
    This document contains information about bugs fixed in NI TestStand 2010 SP1. Refer to the What's New in TestStand 2010 SP1 section in the NI TestStand Version 2010 SP1 Release Notes for information about other changes since TestStand 2010. Refer to the What's New in TestStand topics for previous versions of TestStand in the NI TestStand Help for information about new features, compatibility and known issues, and bug fixes for those versions.
    Refer to the NI TestStand Version 2010 SP1 Release Notes for information about getting started with TestStand, such as system requirements, installation instructions, and descriptions of the TestStand licenses. If you do not activate a TestStand license, TestStand operates in evaluation mode.
    Supported Platforms
    Installing TestStand Silently
    Licensing
    Upgrading TestStand 2010 to TestStand 2010 SP1
    Installing TestStand 2010 SP1 Deployment Software
    TestStand 2010 to TestStand 2010 SP1 Bug Fixes
    TestStand 4.2.1 to TestStand 2010 Bug Fixes
    Additional Information
    Supported Platforms
    Use the following Microsoft operating systems with TestStand 2010 SP1:
    • Windows 7 Service Pack 1 (32-bit and 64-bit), including Starter Edition
    • Windows Vista (32-bit and 64-bit) Business, Enterprise, or Ultimate Service Pack 2
    • Windows XP Service Pack 3
    • Windows Server 2008 R2 (64-bit) and Windows Server 2003 R2 (32-bit)
      Note  TestStand supports only R2 editions of Windows Server.
    Refer to the TestStand and Windows 7/Vista section of the NI TestStand Version 2010 SP1 Release Notes for more information about using TestStand on Windows 7/Vista.
    TestStand does not support Guest user accounts on Windows. TestStand supports Administrator and Limited accounts on Windows 7/Vista and Administrator, Power Users, and Users accounts on Windows XP.
    Note  This version of TestStand supports, and was tested with, the latest operating system service packs that were available at the time this version of TestStand was released. National Instruments recommends using TestStand with the latest operating system service pack.
    Refer to the NI TestStand Version 2010 SP1 Release Notes for a list of other recommended system requirements.
    Refer to the National Instruments KnowledgeBase article 50O9851O, Does TestStand support calling VIs using LabVIEW 64-Bit? on the National Instruments Web site for information about LabVIEW 64-bit support.
    Using Microsoft Silverlight
    You can install TestStand without viewing any installation dialog boxes. Refer to the National Instruments KnowledgeBase article 4CJDP38M, Automating the Installation of a Single Installer, on the National Instruments Web site for information about installing National Instruments software silently. Refer to the NI TestStand Version 2010 SP1 Release Notes for more information about installing TestStand.
    Licensing
    TestStand relies on licensing activation. You must activate a valid TestStand license before you can run TestStand. To activate TestStand, use the serial number you received as part of your installation package. Refer to the NI TestStand Version 2010 SP1 Release Notes for more information about licensing in TestStand.
    You can install TestStand 2010 and TestStand 2010 SP1 on the same computer and run applications in both versions, or you can upgrade an existing TestStand 2010 installation to TestStand 2010 SP1. TestStand 2010 and TestStand 2010 SP1 use separate directories for the , , and directories. You cannot install TestStand 2010 SP1 over a previous TestStand version, and you cannot install TestStand 2010 SP1 in the default installation directory for a previous version of TestStand. If you installed a previous version of TestStand in a non-default directory, you can uninstall the previous version of TestStand and install TestStand 2010 SP1 to that directory.
    Using the TestStand 2010 to 2010 SP1 Migration Tool
    If you are upgrading from TestStand 2010, you can use the TestStand 2010 to 2010 SP1 Migration Tool to migrate your customizations and configuration settings from TestStand 2010 to TestStand 2010 SP1. The Migration Tool identifies what files to copy to TestStand 2010 SP1 by detecting files you have created or modified since installing TestStand 2010. The tool makes a backup of any existing customization and configuration files before copying files over. This tool also redirects paths in TestStand files that refer to TestStand 2010 directories to refer to TestStand 2010 SP1 directories instead. Select Start»All Programs»National Instruments»TestStand 2010 SP1»Tools»TestStand 2010 to 2010 SP1 Migration Tool to launch the Migration Tool. Because the TestStand 2010 customization and configuration files overwrite any existing customization and configuration files, National Instruments recommends that you run the Migration Tool before you start development work with TestStand 2010 SP1.
    Migrating Manually
    Complete the following steps to manually upgrade an existing TestStand 2010 installation to TestStand 2010 SP1.
    • Navigate to the standard Windows Control Panel facility for adding and removing programs and run the TestStand 2010 uninstaller.
    • Install TestStand 2010 SP1.
    • Move any custom components you added to the TestStand 2010 directory to the TestStand 2010 SP1 directory. Custom components include code templates, engine callbacks, icons, language files, models, run-time servers, step types, tools, type palettes, and sequence file translators.
    • Move any configuration files you want to use from the TestStand 2010 directory to the TestStand 2010 SP1 directory.
    When you install TestStand 2010 and TestStand 2010 SP1 on the same computer, TestStand 2010 SP1 cannot directly access the custom components in TestStand 2010. You must copy custom components you added to the TestStand 2010 directory to the TestStand 2010 SP1 directory. You can copy the configuration files you want to use from the TestStand 2010 directory to the TestStand 2010 SP1 directory.
    Use the TestStand Version Selector to switch to TestStand 2010, 2010 SP1, or any other version installed on the computer before you launch a TestStand application. National Instruments does not support running applications that use two different versions of TestStand at the same time.
    Refer to the TestStand Directory Structure section of Chapter 8, Customizing and Configuring TestStand, of the NI TestStand Reference Manual for the location of the , , and directories.
    If you are upgrading from TestStand 4.2.1 or earlier, you must manually migrate your customizations and configuration settings to TestStand 2010 SP1. Refer to the Migrating Manually section of the NI TestStand Version 2010 SP1 Release Notes for information about the tasks you need to perform to upgrade manually.
    You can install deployments for TestStand 2010 and TestStand 2010 SP1 on the same computer. Use the TestStand Version Selector to select the active version of TestStand before you launch the deployed TestStand application. National Instruments does not support running applications that use two different versions of TestStand at the same time.
    Refer to the List of Known Issues in TestStand 2010 SP1 on the National Instruments Web site for a list of known issues in TestStand 2010 SP1. You can also view this list by date.
    Changes in NI TestStand 2010 introduce an incompatibility with NI TestStand ATML Toolkit 1.0 that prevents NI TestStand ATML Toolkit 1.0 from working correctly with NI TestStand 2010. Refer to the National Instruments KnowledgeBase article 5EQAI8XU, NI TestStand ATML Toolkit 1.0 Incompatibilities, for information about this issue.
    The following sections list the bugs that existed in TestStand 2010 and earlier and have been fixed in TestStand 2010 SP1.
    Use this Toggle Expansion button to expand or collapse the following sections. You must enable the Allow Blocked Content option in Microsoft Internet Explorer to collapse each section. You must expand each section you want to print or search.
    TestStand Engine
    TestStand Sequence Editor
    TestStand Deployment Utility
    TestStand User Interfaces
    TestStand User Interface Controls
    .NET Adapter
    C/C++ DLL Adapter
    TestStand File Diff/Merge Application
    Reports
    IVI
    Microsoft Visual Studio
    Miscellaneous
    The following sections list the bugs that existed in TestStand 4.2.1 and earlier and have been fixed in TestStand 2010.
    TestStand Engine
    User Interfaces
    LabWindows/CVI
    C/C++ DLL Adapter
    .NET Adapter
    Database
    IVI
    Miscellaneous
    Refer to the Technical Support page at ni.com/support and search for TestStand to access the TestStand Support Web page, which contains online documentation, KnowledgeBase articles, tutorials, example code, discussion forums, and other resources.
    © 2011 National Instruments Corporation. All rights reserved.
    Third-Party Copyright Notices
    The TestStand 2010 FOSS Notices.pdf file contains third-party copyright notices for third-party components used by certain TestStand features. The TestStand 2010 FOSS Notices.pdf file is located on the distribution media in the directory. TestStand installs the TestStand 2010 FOSS Notices.pdf file on a local computer in the following location: \Doc\TestStand 2010 FOSS Notices.pdf.
    This product includes the Intel® Math Kernel Library. For more information about the Math Kernel Library, visit http://www.intel.com/software/products/mkl.
    This product includes software developed by the Apache Software Foundation (http://www.apache.org/) that is subject to the Apache License, Version 2.0, a copy of which may be found at: http://www.apache.org/licenses/LICENSE-2.0. Copyright 1999 The Apache Software Foundation. All rights reserved.
    CVI, LabVIEW, National Instruments, NI, ni.com, NI TestStand, the National Instruments corporate logo, and the Eagle logo are trademarks of National Instruments Corporation. Refer to the Trademark Information at ni.com/trademarks for other National Instruments trademarks.
    GMT+8, 2026-4-21 22:24
