查看: 16125|回复: 0
[LabVIEW] NI LabVIEW 2015 Win64ENG 64位LV2015英文版下载
    昨天 08:12
  • 签到天数: 3787 天
    连续签到: 38 天
    发表于 2015-8-7 15:45:52 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    标准下载:
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    下载器下载:
    提取码: 请购买附件下载查看
    标准下载(EXE版和ZIP版内容一样,EXE为早年发行版,ZIP为后期重新压制版):
    请购买附件下载查看
    NI下载器下载:
    请购买附件下载查看
    LV2015ENG64.txt (701 Bytes, 下载次数: 43, 售价: 10 圆)
    LabVIEW 2015 Readme for Windows
    June 2015
    Refer to the National Instruments website for the latest information about LabVIEW 2015.
    LabVIEW 2015 (64-bit)
    ProcessorPentium III/Celeron 866 MHz (or equivalent) or later (32-bit)
    Operating SystemWindows 8.1/8/7/Vista (32-bit and 64-bit)
    Windows XP SP3 (32-bit)
    Windows Server 2012 R2 (64-bit)
    Windows Server 2008 R2 (64-bit)
    Windows Server 2003 R2 (32-bit)
    Disk Space620 MB5 GB (includes default drivers from the NI Device Drivers media)
    Temporary Files DirectoryN/ALabVIEW uses a directory for storing temporary files. National Instruments recommends that you have several megabytes of disk space available for this temporary directory.
    Note  The following list describes restrictions for using LabVIEW on Windows:
    • LabVIEW does not support Windows 2000/NT/Me/98/95 or Windows XP x64.
    • You cannot access LabVIEW using a Guest account on Windows.
    You can access the LabVIEW Installation Guide and the LabVIEW Upgrade Notes at ni.com as well as on the installation media.
    When run on Windows (64-bit), LabVIEW 2015 (64-bit) provides access to more memory than a 32-bit operating system or a 32-bit application can provide. LabVIEW 2015 (64-bit) includes nearly all of the development environment features of LabVIEW 2015 (32-bit).
    LabVIEW 2015 (64-bit) supports many hardware devices. Refer to the National Instruments website for information about drivers compatible with LabVIEW 2015 (64-bit). For GPIB devices, you must use at least NI-488.2 2.6 for Windows. Refer to the specific hardware documentation for more information about compatibility with LabVIEW 2015 (64-bit).
    Supported Modules
    The following list contains additional changes to LabVIEW that are not included in the LabVIEW Help, the LabVIEW Upgrade Notes, or both:
    • National Instruments does not support remote front panels for Google Chrome starting from version 42. Visit the National Instruments website for more information.
    ID
    Fixed Issue
    52263Some operations on integer waveforms lose dt value
    225616Error 1172 (System.Reflection.AmbiguousMatchException) is returned when using the .NET invoke node to call a .NET method that also contains an additional generic version of the same method.
    257275Format Into String does not work with the %d format for numbers larger than I32
    278730Web Services ignore the No App switch on RT targets
    315474Feedback node with waveform data input, and greater than 2 iterations of delay, outputs an array of waveform
    333388Incorrect highlight execution order with LVOOP property node
    348592Select node causes buffer copy
    361311"Natural log of 1 + x" primitive incorrectly returns NaN for small positive values
    372784LabVIEW 2012 and later have added overhead to dynamic dispatch calls when compared to LabVIEW 2011
    377653There is inconsistent labeling on 'Constrained Nonlinear Curve Fit.vi' TRLM instance.
    392232Autopreallocate Arrays and Strings VI Property Can Crash LabVIEW when not in FPGA Context
    392446Installing LabVIEW on a Windows laptop decreases battery life
    397550LabVIEW can switch to different Front Panels or Block Diagrams when going between LabVIEW and other programs.
    400736Error -4403 returned from Write Palette.vi for Template VIs
    401689Constrained Non-Linear Optimization VI has Potential for Infinite Loop
    408351The Bookmark Manager window is not closed when 'Esc' key is pressed
    413786Help button does not work on Setup page of LabVIEW 64-bit Example Finder
    413954Slow VI compilation with complex VI
    419089Infinite loop in NI_Gmath.lvib:cno_isisubopt.vi under certain conditions
    421739Quick drop ctrl+r needs to wire the To More Specific/Generic side terminal instead of center terminal
    424089The advanced analysis Kummer Function returns 'NaN' instead of correct values for certain combinations of input parameters.
    425562Scan from String requires a space between modifiers when using SI notation
    426157VI invoke node Find CtrlWithKeyFocus don't work with typedefs
    434426Reading from same UDP port twice simultaneously crashes LV
    435756Web Services reset all resource VIs to their default parameters (GET as Terminal/XML) when multiple files are simultaneously added to project.
    437915When converting a Timestamp into a string with the Format into String primitive, certain incorrect format strings will cause the End of file encountered error.
    438751Renaming a group in a Mixed Signal Graph crashes LabVIEW once there is a plot containing data
    441262Call Library Function Nodes maximum error checking mode incorrectly reports memory corruption with CStrs and PStrs.
    443165Modifying the dependencies of a Packed Project Library (PPL) may cause LabVIEW to crash
    444759Default probes should fit to probe watch window pane
    444851Encapsulated PostScript (EPS) is not supported on Mac 64-bit
    447789"RecipeBkUp::SanityCheck()" Crash
    449869"ICallPiccCallback" 0x89B93EF0
    451059"CProjectItemWrapper::GetPropertyBag(IlvProjectPropertyBag**)"
    453489Minimizing the lvlib group in VI hierarchy messes up the entire VI hierarchy.
    458700Equals? Function executes slowly on long strings
    458724Uninstalling myRIO Module 2013 causes LabVIEW Getting Started Screen to become unresponsive.
    462624Mouse wheel scrolling does not work on the Functions Palette.
    463275Using the same Application twice in installer causes unexpected behavior
    463408Log scale on a Graph does not use correct minimum with certain data
    463760Improved security of an authenticated session when used over an un-encrypted connection like http.
    466635Add new "Create Unique File" VI to vi.lib
    468062Path to URL.vi does not handle network path
    468921Auto-populating folders may not update their contents correctly
    469070In some cases, Fract/Exp String To Number VI does not convert the string correctly
    469178Sound Examples do not have volume control
    469269Error when VIPM quits LV -- svcloc_interface.cpp line 1702
    471706Cannot paste into destination name of installer properties in LabVIEW 2013
    474004Multiple LabVIEW windows do not group in RHEL.
    474143Copy functions returns a permission error (error code 8) occasionally when running in a loop
    474764A VI can hang at Occurrences if Allow Debugging is disabled
    476028MAX/NIER report: Null pointer dereference in LVBroker.dll!CniLVBroker::HandleVIClose(niLVReq & req, int (void) *)
    476714The INI file created for a LabVIEW-built executable contains a truncated list of VIs in the "server.vi.access=" line when enabling TCP/IP with multiple Exported VIs
    477112If you cancel the file dialog, it will never show again in Write to Measurement File Express VI.
    477280When using [VersionNumber], Application Builder post-build VIs do not get passed the proper path
    477352In the TDMS File Viewer VI, the menu becomes partially hidden after making the plot legend visible
    477864When a number of controls are grouped on a tab control page, switching to that page takes a long time, proportional to the number of controls grouped
    477954VI Analyzer throws error 1 when analyzing project with a Networked Computer under the Target Folder.
    478485Selecting a Polymorphic VI while loading a caller VI causes a crash due to missing polymorphic instances
    478854Source Distribution Target Directory not used, VIs placed in startup folder
    478906Conditional Double Probe does not handle NaN equality check
    479161Error 7 When Building Installer for EXE with Custom Destinations
    480103Using VirtualBench API through TestStand and the LVRTE causes crashes on exit
    480480Invoke Node shows the English shortname at the first drop in German LabVIEW
    480921Unable to delete and re-add a destination folder successfully in build specification of a LabVIEW Installer
    484575Issue writing to individual digital waveform channels in TDMS files
    484662LabVIEW Runtime installer should allow multiple versions in one distribution
    484767Bookmarks changed event does not return the path of the VI(s) in which the bookmarks changed
    484940Create Express VI tool throws Error 1099 when template VIs are marked as Source Only
    485412Make Ctr-W shortcut wire to inner terminals of tunnels
    486475LabVIEW crashes when adding a saved copy of an lvclass member to an lvlib
    488710Multicolumn Listbox Key Navigation is not consistent
    489848"Remove empty cases" option in case structure disappears when Subdiagram Label is visible.
    490378Report Generation Toolkit, headers.vi has a reference leak.
    490606Web Service installer fails to install on Win Server 2008 R2
    491093Application Web Server fails to run on VxWorks when root directory has too many files
    491198Any VI that has a VI Documentation greater than 8000 characters will cause the context help window to truncate the documentation.
    491539Unexpected behavior with Resample Waveforms (Single Shot).vi
    496699LabVIEW crashes when attempting to reinitialize unused plots in plot legend of waveform graph
    497131The WebDAV Put.vi when executed on a cRIO target can lead to a memory leak
    497256CoreAnimation thread warning when calling a LabVIEW-built Framework on Mac OS X 10.0
    497516Replacing a Waveform control with an Array(Silver) crashes LabVIEW with internal error in datamgr.cpp.
    497755Cannot reset the values of Build Specification Version in Set Build Specification Version VI to zero
    499042Incorrect Diagram Identifier reported by LV Compare tool when comparing case structures
    500986Error 1 generated in property node when remote debugging
    501004Performance improvements for 3D Plot VIs
    501633Variable Engine does not have a "Run-Time" product for deployment.
    502081Ctrl+shift+E (find in project) doesn't work for clone VIs.
    502105"New..." dialog only looks for VI templates in the LabVIEW directory, which is not writable on Linux systems
    503234The method "Synchronize in all Contexts" causes LabVIEW to crash.
    505523Diff and Merge do not work with Enable Hyperlinks
    508525Improve "Select a VI" experience with Quick Drop Replace and Insert
    509097LabVIEW crashes when sending an empty input array to the Preallocated Read from File VI
    509204Format Into String outputs an incorrect string when using Timestamp data and an order modifier
    510063LabVIEW does not exit properly after encountering a NIER exception
    510881LabVIEW Crash when saving Library containing Shared Variables with Class Object in Typedef.
    510908Application Builder slows when builds involve PPLs with controls in them
    511588Currently selected item in the Connector Pane selection menu is not outlined
    511708LabVIEW crashes when use "save method" to save the UDF VI if the MathScript RT Module and Control Design and Simulation Module are both installed.
    511770The Waveform Unbundle/Bundle node pair on InPlace Element Structures cannot be scripted
    512153Cursor in LabVIEW can disappear when switching between tools.
    512294Crash in search 1D array when run on VI with host interface node
    512464After making a change in Format Into String, the containing VI does not recompile automatically.
    512761The input XML containing "\n" hangs the LabVIEW storage VIs.
    513188Improved Bookmark Manager performance by adding additional caching.
    513259Substitute Actor VI does not transfer nested actors
    513281Improved error handling in AB_Engine_EXE_Call_Write_Icons.vi
    513457"Change to Array" menu option should not appear on tab controls or XControls.
    513871MAX/NIER report: Access violation in lvrt.dll!std::_Tree
    513963Classes containing NaN values compare incorrectly when using the Equals function
    514518LabVIEW 2014 crashes upon close while an RFmx example VI is running continuously from a LabVIEW Project context.
    515054Icon transparency of VIs is not maintained when building a Source Distribution
    515086Building VIs with certain recursive dependencies can cause a LabVIEW crash
    515223Advanced TDMS Write broken wire behavior is incorrect.
    515763The To Long Integer conversion bullet can crash when converting a float64 array to an int32 array if the start of the input data (just after the dimsize) is not 16 bytes aligned.
    515779Invoke node Append String returns error 1043 while display style set to backslash "" codes
    515884LabVIEW crashes when using the Class Browser to select a class which contains an accessor available via property nodes
    515920Memory issues due to timestamp handling in the Data Storage VIs.
    516057LabVIEW Application Builder API Build (path).vi returns unclear error 1055 when Build Specification name or target name is incorrect
    516217The WebDAV Put.vi when executed on a cRIO target can lead to a memory leak
    516227UI Thread LabVIEW code cannot execute while a Time Stamp Control's 'Set Time and Date' window is visible.
    516506'Build All' error does not indicate which build specification failed.
    516674LabVIEW crashes when dragging a class member VI from the Class Browser onto an Untitled VI of a Library
    516841VeriStand crashes after manipulating a System Definition via the System Explorer
    516905Cannot get VI Path/Name for Type Definitions, Classes, or Global VIs if dependency is missing
    517128Error 1357 when building using two VIs with the same name and only capitalization differences.
    517307Mass Compile of VeriStand 2014 LabVIEW examples will crash LabVIEW
    519216LabVIEW crash when closing subVI Icon Editor that was opened from VI Hierarchy.
    519533IDFinder downloads the wrong version of VIs for Instrument drivers
    519665LV crashes when copying user event data while handling high priority user events
    520343Runtime popup menus appear on the Project properties dialog
    521114Property VIs of classes do not require that inputs/outputs match the class itself
    521509LabVIEW security update
    524370LabVIEW 2014 crashes on VI load if old error cluster controls are connected to case structures or conditional terminals
    Using NI Launcher
    If you want to find a particular application or related files, such as documentation files, from the Start screen, you can access all installed files from the Apps view. To get to the Apps view, right-click anywhere on the Start screen and select All apps (Windows 8.0) or click the down arrow on the bottom left of the screen (Windows 8.1).
    LabVIEW will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of LabVIEW that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    Info Code
    LabWindows™/CVI™cvi_lifecycle
    © 2004–2015 National Instruments. All rights reserved.
    374715C-01
    GMT+8, 2026-1-30 05:43
