查看: 3839|回复: 0
NI Vision Development Module 2015 Readme
    昨天 08:38
  • 签到天数: 3691 天
    连续签到: 18 天
    发表于 2015-8-5 21:11:36 | 显示全部楼层 |阅读模式 来自:广东省东莞市 移动
    June 2015
    This file contains important information about National Instruments Vision Development Module, including installation instructions, new features, fixed issues, and known issues.
    Updates and Improvements
    How to Activate the NI Vision License
    Deploying Vision Applications
    Documentation and Examples
    The NI Vision Development Module provides hundreds of image processing and machine vision functions. Along with programming libraries, the NI Vision Development Module also includes NI Vision Assistant. Installing this software may remove previous versions of the NI Vision Development Module that are currently installed.
    Note: The NI Vision Development Module overwrites existing NI Vision examples and NI Vision VIs. Move modified examples or VIs that you want to save to another directory before installing the NI Vision Development Module.
    Refer to the NI Vision website at ni.com/vision for the latest information about the NI Vision Development Module.
    The development computer must meet the following system requirements to run the NI Vision Development Module.
    MinimumRecommended
    Processor233 MHz Pentium or equivalentPentium 4/M or equivalent
    Memory256 MB RAM512 MB RAM
    Display1,024 × 768 resolution video adapter with a 16-bit display1,024 × 768 resolution video adapter with a 24- or 32-bit display
    Free Hard Disk Space
    3.2 GB
    Operating System
    • Windows 8.1 (32- and 64-bit)
    • Windows 8.0 (32- and 64-bit)
    • Windows 7 (32- and 64-bit)
    • Windows Vista SP1 (32- and 64-bit)
    • Windows XP SP3 (32-bit)
    • Windows Server 2008 R2 SP2 (64-bit)
    • Windows Server 2003 R2 SP2 (32-bit)
    The following table lists the NI application software versions, including service packs, supported by the NI Vision Development Module. The installer specifically allows side-by-side installations of Vision Development Module for each of the supported versions of LabVIEW, enabling you to use the NI Vision Development Module with multiple versions of LabVIEW. National Instruments recommends that you install LabVIEW, LabVIEW Real-Time, or any other supported development environment, before installing the NI Vision Development Module.
    NI Application SoftwareVersions Supported by NI Vision Development Module
    NI LabVIEW
    2012, 2013, 2014, 2015
    NI LabVIEW Real-Time Module
    NI LabVIEW FPGA Module
    2014 and 2015
    NI LabWindows™/CVI™
    2010, 2012, 2013, 2015
    NI Vision Development Module .NET Support
    NI Vision Development Module 2013 SP1 was the last version to release updated support for the .NET Framework 1.1, .NET Framework 2.0, .NET Framework 3.5, and .NET language integration into Visual Studio 2005 and Visual Studio 2008. Visual Studio 2010 and later are not supported.
    New versions of NI Vision Development Module will not provide new .NET feature support or development. It is recommended that you begin new development in other supported development environments.
    This release of the NI Vision Development Module includes the following new features:
    • Flat Field Correction
      • IMAQ Flat Field Correction VI, which corrects the non-uniform intensity in images using flat field and dark field images
      • IMAQ Flat Field Estimation VI, which estimates the background flat field for images with objects
      • IMAQ Compute Average Image VI, which averages multiple images and returns a single averaged image
      • IMAQ Compute Median Image VI, which computes the median of pixels over multiple images and returns a single median image
    • Feature Detection and Correspondence
      • IMAQ Corner Detector VI, which detects corner points in an image using Harris and Shi-Tomasi methods, and returns pixel and real-world locations
      • IMAQ FAST Feature Point Detector, which detects salient feature points in an image using the features from accelerated segment test (FAST) method, and returns pixel and real world locations
      • IMAQ Feature Point Descriptor VI, which computes descriptors for feature points using fast retina key point (FREAK) and binary robust invariant key points (BRISK) methods
      • IMAQ Match Feature Points VI, which estimates the correspondence between two feature point descriptor sets
    • Feature Extraction
      • IMAQ Extract HOG Feature Vector VI, which extracts histogram of oriented gradients (HOG) features from an image
      • IMAQ Extract LBP Feature Vector VI, which extracts local binary pattern (LBP) features from an image
    • The Image Display Control on Windows and NI Linux Real-Time with Embedded UI supports 16-bit color palettes
    • The Image Display Control on NI Linux Real-Time with Embedded UI now supports image zoom, scrolling, and panning
    • LabWindows/CVI and C API support for flat flat field correction, feature detection, feature correspondence, and feature extraction
    • C API support for NI Linux Real-Time targets using Eclipse IDE (C/C++ development tools for NI Linux Real-Time)
    • IMAQ FPGA Particle Analysis Report VI for computing particle and hole statistics
    • Support for variable number of gradients interpolation in the IMAQ FPGA Bayer To RGB VI
    • IMAQ Write File 2 VI allows saving bit-depth information for 16-bit images when saving to the PNG file format
    NI Vision Assistant includes the following new features:
    • Flat Field Correction step to correct an image for intensity variations due to non-uniform lighting
    • Flat Field Creation Wizard to create, analyze, and store flat field images
    • Feature Detection step for FAST feature detection, and Harris and Shi-Tomasi Corner point detection
    • Support for 16-bit color palettes and a new palette editor to create, visualize, and store color palettes for 8-bit and 16-bit images
    • Support for particle analysis report and Bayer VNG decoding on FPGA targets
    • New FPGA Performance Meter, which provides detailed information about algorithm performance on FPGAs
    The following list describes issues in previous versions of NI Vision Development Module that are fixed in this release. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of NI Vision Development Module.
    476092Zoom to Fit setting does not persist to both image views when configuring a Vision Assistant step with a split display such as Brightness.
    486837IMAQ Extract Contour leaks when no contour is found in the ROI.
    492363, 508809Image Display Control properties on the host are not retained when the control is deployed as an Image Display Control on NI Linux Real-Time with Embedded UI.
    509929, 518544NI Linux Real-Time targets with the Embedded UI enabled will crash when the target is disconnected from the host while using the Image Display Control or any LabVIEW array indicator in synchronous mode inside a loop on the target.
    510278The mapped image shown in an Image Display Control on NI Linux Real-Time with Embedded UI may not match the mapped 16-bit image shown on the host-side Image Display Control.
    516401IMAQ Find Circles VI will cause LabVIEW to crash if too many circles are present.
    516473IMAQ Light Meter (Rectangle) VI does not use a unique temporary image name internally, which could cause race conditions when running the VI in a reentrant manner.
    517332Resizing the ROI in a Vision Assistant Barcode Reader step unchecks the Validate option.
    519852Projection-based edge location changes with kernel size when simple calibration with direct axis orientation data is present in the image.
    520769IMAQ Clamp Max crashes when it does not find enough curves in the image.
    525265Vision Assistant code generation: Bayer parameters input is generated as a constant in the FPGA VI and as a control on the Host VI.
    525663Vision Assistant incorrectly detects grayscale image as binary images.
    526256IMAQ Set Calibration Axis Info 2 VI crashes when NaN values are supplied as a parameter.
    526348Memory leak observed when using IMAQ LabelToROI VI.
    The following list describes previously undocumented issues that were fixed in NI Vision Development Module 2014 SP1.
    487474The IMAQ Find Straight Edges 3 VI parameter Average SNR (dB) is not returned correctly when requesting more than one edge.
    504682IMAQ Image Cluster to Image Datatype VI crashes LabVIEW 2014 for some input values.
    Installation InstructionsInstalling from the LabVIEW Platform DVDs
    If you purchased LabVIEW, you can install all of your LabVIEW products—including the NI Vision Development Module—using the LabVIEW Platform DVDs.
    To request additional LabVIEW Platform DVDs, refer to the National Instruments Web site.
    Installing from the NI Vision Development Module Installation Media
    Complete the following steps to install the NI Vision Development Module from the NI Vision Development Module installation media.
    • Insert the NI Vision Development Module installation media.
    • If you do not have autorun enabled, double-click autorun.exe. If you have autorun enabled, autorun.exe runs automatically.
    • (Optional) Activate NI Vision Development Module when prompted by the installer, or activate at a later time using the NI License Manager.
    When you run an NI Vision application for the first time, it prompts you to activate a license for the product. If you do not activate a valid license, the NI Vision application will run in Evaluation Mode and continue to prompt you to activate a license on each subsequent launch.
    Complete the following steps to activate the NI Vision license through an Internet connection.
    • Run the product you want to license.
    • Click Yes when prompted to interactively activate your product.
    • Ensure that Automatically activate through a secure Internet connection is selected, and click Next.
    • Enter the product serial number, and click Next.
    • Enter your registration information, and click Next.
    Tip: Enter your email address to receive a copy of your activation code for your records.
    Deployment refers to developing an application so that it can be distributed, or deployed, on a different computer than the one on which the application was developed. The NI Vision Development Module provides everything you need to deploy custom NI Vision applications to target computers. The NI Vision Development Module provides the following options:
    • The ability to create NI Vision Runtime installers, which integrate with the LabVIEW Application Builder, applications built in LabWindows/CVI, or a custom installer.
    • The ability to install the NI Vision Runtime directly from the NI Vision Development Module installation media.
    • One NI Vision Runtime License, which allows you to install a custom application on a single machine.
    The NI Vision Development Module installer contains the runtime installer for NI Vision. The runtime installer is installed at \Run-Time Engine, where is the location to which the NI Vision Development Module is installed. Visit the ni.com to download software upgrades for NI Vision and the NI Vision Runtime installers.
    Purchasing NI Vision Deployment Licenses
    You must purchase an NI Vision Runtime License (part number 778044-03) for each target machine onto which you want to install your custom NI Vision application, even if you install the NI Vision Runtime directly from the NI Vision Development Module installation media. The NI Vision Development Module ships with one runtime license. Contact a National Instruments sales representative or visit ni.com to purchase additional runtime licenses.
    Note: Additional NI Vision Runtime licenses do not include installation media. To install additional licenses, use the original NI Vision Development Module installation media and the serial number provided by National Instruments.
    Using the NI Vision Runtime
    You can call the NI Vision Runtime installer from the application installer. If you create the application installer with the LabVIEW Application Builder or with LabWindows/CVI, you can direct the installer to call the NI Vision Runtime installer.
    Refer to the LabVIEW Help for more information about the LabVIEW Application Builder. Refer to the NI LabWindows/CVI Help for more information about building and distributing LabWindows/CVI applications.
    You can also direct a custom application installer to call the NI Vision Runtime installer. This may be useful if you are creating an installer for applications created in other development environments. Refer to the documentation that came with the installer software to learn how to call executables from the custom installer. If you are using a custom installer, call the NI Vision Runtime installer at the end of the installation procedure because the installer may require the system to be restarted.
    To call the NI Vision Runtime installer silently (non-interactively), you must add /q /AcceptLicenses yes as command line arguments to the runtime installer. For example, enter \Run-Time Engine\visionrte.exe /q /AcceptLicenses yes, where is the location to which NI Vision is installed, and is the version number of the NI Vision Runtime installed. Refer to the Automating the Installation of NI Products section for more information on how to change the level of interactivity of the installer or whether it automatically initiates a system restart.
    Distributing LabVIEW Applications
    The NI Vision Runtime installer does not install LabVIEW VIs. If you use the LabVIEW Application Builder to create an application (EXE) or dynamic link library (DLL), the Application Builder automatically includes the VIs used by the application. If you distribute a VI, you must include all subVIs that comprise the top-level VI. You must include the appropriate LabVIEW Runtime as part of the installation.
    Refer to the LabVIEW Help for more information about viewing the hierarchy of VIs and for more information about using the LabVIEW Runtime.
    Distributing LabWindows/CVI Applications
    In addition to including the NI Vision Runtime with the installer, you must include the appropriate LabWindows/CVI Runtime. Refer to the NI LabWindows/CVI Help for more information about creating an executable, creating a dynamic link library, and distributing applications.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the NI Vision Development Module.
    National Instruments is aware of the following issues you may encounter while using NI Vision Development Module.
    • When an FPGA target is active in a LabVIEW project, the Vision Assistant executable cannot generate code for a non-FPGA LabVIEW target into that same instance of LabVIEW.
    • When zoom factors above 30 are used, the Image Display Control on NI Linux Real-Time targets leaves black-colored border space.
    • The snapshot property node for the Image Display Control on NI Linux Real-Time targets returns an error even though the control is functioning properly. This issue is present only when the target is connected to the host.
    • The Image Display Control on NI Linux Real-Time targets may not work properly when an image is set using a property node value and the target is connected to the host. The property node value works properly when the target is disconnected from the host.
    • Vision FPGA VIs may be broken when opened on one target after being used on another target. You can fix the broken VI by forcing LabVIEW to recompile it by pressing + + Run Button.
    • Vision FPGA Filter VIs with a mask using a 9x9 kernel support image widths up to 2,000 pixels.
    • The IMAQ FPGA GrayMorphology Dilation 5x5 U8x1 VI left border will give incorrect values on Kintex-based NI FPGA targets.
    • The AVI2 VIs do not support writing extra data to AVIs.
    • Japanese and Simplified Chinese for text overlays are not supported on NI Linux Real-Time targets.
    • The Calibration Axis is not set properly in the Calibration Training Interface, resulting in wrong real-world coordinates, when the Calibration Type is set to Point Coordinate Calibration and the Implicit Calibration Axis option is deselected.
    • The IMAQ Read QR Code VI may hang when the QR Code Cell Size has a minimum size of 2 or less. Setting the minimum size to 3 or higher will prevent this issue.
    • The IMAQ Read Data Matrix Barcode 3 VI may hang on some I16 images.
    • Zooming out on a large 32-bit image in the Image Display Control in LabVIEW will cause the image to black out. Only the displayed image is affected. The image itself is not modified.
    • To store error statistics on corrected images, you must run the IMAQ Get Calibration Info2 VI before correcting the calibration template image. The Return Error Information input must be set to TRUE.
    • Vision Assistant cannot generate C code if a double-byte character exists in the path to Vision Assistant or in the destination path for the generated code.
    • Some Vision Development Module .NET examples only work if Measurement Studio 8.6 or later is installed.
    • The Visual Basic .NET Label example does not compile.
    • The installed documentation for NI Vision functions in LabWindows/CVI is incomplete. Refer to the Documentation and Examples section for information about downloading the latest version.
    • There is no 64-bit Vision API for C or .NET.
    • Installing the Vision Development Module on a Windows Vista 64-bit computer where Visual Studio 2005 has been recently installed causes compatibility warnings.
    • On some systems, the Vision Development Module cannot open two of the installed AVI files, SideCrash1.avi and SideCrash2.avi, when running as a 64-bit application.
    • NI Vision installs a copy of tbb.dll that can conflict with third-party programs using a later version of tbb.dll.
    • The IMAQ Compare VI average operation saturates unsigned 16-bit image values to 32768 instead of 65536.
    • The IMAQ Read File VI recognizes and reads a U16 TIFF image as an I16 TIFF image if the image was not originally created by NI Vision.
    • The IMAQ Overlay Multiple Lines 2 VI returns an error when Fill is the selected Drawing Mode.
    • The IMAQ Edge Tool 3 VI changes the position of edges found when image was calibrated with point coordinates calibration.
    Documentation and examples are installed onto your hard drive with the NI Vision Development Module. To view the documentation, select Start»All Programs»National Instruments»Vision»Documentation»Vision Documentation, or navigate to \Public\Public Documents\National Instruments\Vision\Documentation.
    Refer to the National Instruments Product Manuals Library at ni.com/manuals for the most recent versions of product documentation.
    The following sections describe the documents available for each application development environment and where to find examples.
    • NI Vision Concepts Help—Describes the basic concepts of image analysis, image processing, and machine vision. This document also contains in-depth discussions about imaging functions for advanced users.
    NI Vision for LabVIEW
    • NI Vision for LabVIEW Help—This document contains reference information about NI Vision VIs and details about how to use NI Vision with LabVIEW. It describes how to create machine vision and image processing applications in LabVIEW. It also describes how to create a real-time vision application using NI Vision and the LabVIEW Real-Time Module, and how to use the Vision FPGA VIs with an FPGA target and the LabVIEW FPGA Module. You can access this help in LabVIEW by selecting Help»NI Vision for LabVIEW Help.
    • NI Vision for LabVIEW Examples—Illustrates common applications you can create with NI Vision. In LabVIEW, select Help»Find Examples. Click the Help button in the NI Example Finder to display the NI Example Finder Help. NI Vision examples for LabVIEW are installed to \examples\Vision and \examples\Vision FPGA, where is the location LabVIEW is installed.
    NI Vision for LabWindows/CVI
    • NI Vision C Support Help—Contains reference information about NI Vision C functions.
    • NI Vision for LabWindows/CVI User Manual—Describes how to create machine vision and image processing applications in LabWindows/CVI using the NI Vision Development Module.
    • Function panel help within LabWindows/CVI—Allows you to right-click within each Vision function to access help for that function, control, function class, and function library. Function panels are installed at National Instruments\Shared\CVI\Bin\NIVision.lfp.
    • NI Vision LabWindows/CVI example programs are installed at \Public\Public Documents\National Instruments\CVI\samples\Vision.
    NI Vision for Eclipse and other Text-based Development Environments
    • Getting Started with C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition with the NI Vision Development Module and NI-IMAQdx—Describes how to use the C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition to develop an example C application using the NI Vision Development Module API and/or NI-IMAQdx, and deploy it on a Linux remote target. This tutorial outlines the basic steps required to build and deploy an example application.
    • To view text-based example programs, select Start»All Programs»National Instruments»Vision»Examples»Vision Examples, or navigate to \Public\Public Documents\National Instruments\Vision\Examples.
    NI Vision Assistant
    • To access Vision Assistant documentation from the Start menu, select Start»All Programs»National Instruments»Vision»Documentation»Vision Assistant Documentation, or navigate to \Public\Public Documents\National Instruments\Vision Assistant\Documentation.
    • To access Vision Assistant examples from the Start menu, select Start»All Programs»National Instruments»Vision»Examples»Vision Assistant Examples, or navigate to \Public\Public Documents\National Instruments\Vision Assistant\Examples.
    • NI Vision Assistant Tutorial—Describes the Vision Assistant software interface and guides you through creating example image processing and machine vision applications.
    • NI Vision Assistant Help—Contains descriptions of Vision Assistant features and functions and provides instructions for using them. In Vision Assistant, select Help»Online Help.
    • NI Classification Training Interface Help—Contains information about how to use the NI Classification Training Interface to classify binary samples. In the NI Classification Training Interface, select Help»Online Help.
    • NI Color Classification Training Interface Help—Contains information about how to use the NI Color Classification Training Interface to classify color samples. In the NI Color Classification Training Interface, select Help»Online Help.
    • NI OCR Training Interface Help—Contains information about how to use the NI OCR Training Interface to learn characters, save character sets, and verify characters by comparing them to a reference character. In the NI OCR Training Interface, select Help»Online Help.
    • NI Texture Training Help—Contains information about how to use the NI Texture Training Interface to train a texture classifier file for use in texture defect detection applications. In the NI Texture Training Interface, select Help»Online Help.
    • NI Calibration Training Help—Contains information about how to use the NI Calibration Training Interface to select and create a calibration for use in machine vision applications. In the NI Calibration Training Interface, select Help»Online Help.
    • NI Vision Template Editor Help—Contains information about how to use the NI Vision Template Editor to learn and edit template images that you can use with pattern matching, geometric matching, and golden template comparison functions. In the NI Vision Template Editor, select Help»Online Help.
    • NI Flat Field Creation Wizard Help—Contains information about how to use the NI Flat Field Creation Wizard to create a dark or bright field image and perform flat field correction in a machine vision application. In the NI Vision Flat Field Creation Wizard, select Help»Online Help.
    When you install National Instruments software on Microsoft Windows 8.x, you will notice a few additional tiles on the Start screen, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (MAX), and the new NI Launcher.
    Using NI Launcher
    NI Launcher helps you find and launch installed NI products. It provides you with a method of finding NI products similar to the Start menu in previous versions of Microsoft Windows. To use NI Launcher, click the NI Launcher tile on the Start screen. NI Launcher launches the desktop and opens a menu containing a list of NI products. Double-click any NI product to launch it.
    Note  MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8.x. You can launch MAX either from the Start screen or from within NI Launcher.
    Finding All Programs
    NI Vision Development Module Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    NI Vision Development Module will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI Vision Development Module that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2015 National Instruments. All rights reserved.
    375127B-01
    GMT+8, 2025-10-25 03:49
