TA的每日心情 | 无聊 昨天 11:29 |
签到天数: 3774 天 连续签到: 25 天 [LV.Master]2000FPS
发表于 2015-5-11 15:07:54
VST VS-LD系列低畸变微距工业镜头
概述
Distortionless Macro Lens
低畸变微距镜头
Low distortion even when using extension tubes 10 models from focal lengths f4mm~f75mm
很低的畸变,即使使用延长管时,10种型号,焦距从4mm到75mm
Compact size: 32mm in diameter (except for VS-LD 6.5)
紧凑小巧的尺寸:32mm直径(除了VS-LD6.5mm的镜头)
For VGA ~3 Megapixel sensors
可以适用于30万像素~300万像素图像传感器
Reduced shading
减少的像差
镜头畸变对比图Distortion comparison chart
镜头平移Lens shift(对焦距离)
VS-LD Series maintains low distortion and less shading by utilizing a higher amount of lens shift. The result is a lens with a great variety of WD and magnifications while maintaining a high quality image in the entire FOV.
VS-LD系列使用更高的镜头平移空间也同样可以保持较低的畸变和较少的像差。其结果就是同一枚镜头可以使用多种不同的工作距离和放大倍数,也能在整个视场中保持较高的图像质量。
VS-LD系列与普通常规镜头的镜头平移距离(对焦距离)
型号与规格 | 型号 | 焦距f(mm) | 光学倍率 | 工作距离(mm) | 光圈F | TV畸变 | 传感器靶面尺寸 | 重量 | | VS-LD4 | 4 | 0.01x~0.04x | 405.1~93.1 | 2.10~2.16 | 0.95%~0.92% | 1/2” | 52g | | VS-LD6.5 | 6.5 | 0.01x~0.06x | 631.5~89 | 2.28~2.4 | 0.11%~-0.01% | 1/2” | 50g | | VS-LD10 | 10 | 0.02x~0.1x | 499.8~89 | 2.24~2.42 | 0.08%~-0.08% | 1/2” | 46g | | VS-LD15 | 15 | 0.03x~0.15x | 491.8~91.8 | 2.06~2.3 | 0.11%~0.00% | 2/3” | 46g | | VS-LD20 | 20 | 0.04x~0.22x | 511.0~86.8 | 2.22~2.60 | 0.06%~-0.15% | 2/3” | 45g | | VS-LD25N | 25 | 0.05x~0.25x | 511~103 | 2.1~2.5 | 0.05%~-0.09% | 2/3” | 47g | | VS-LD30 | 30 | 0.1x~0.23x | 312.7~143.1 | 2.20~2.46 | 0.03%~-0.05% | 2/3” | 46g | | VS-LD35 | 35 | 0.3x~0.5x | 142.4~95.7 | 2.47~2.85 | ~-0.03% | 2/3” | 58g | | VS-LD50 | 50 | 0.1x~0.25x | 503.8~213 | 2.70~3.06 | ~0.05% | 2/3” | 73g | | VS-LD75 | 75 | 0.15x~0.35x | 527.7~245.9 | 4.38~5.14 | ~-0.02% | 2/3” | 100g | 购买
购买本系列工业镜头,请登录机器视觉商城:
http://visionbbs.com |
