查看: 6508|回复: 0
[面阵相机] 德国SVS500万像素CCD千兆网工业相机eco655MVGE4IO
    5 小时前
  • 签到天数: 3866 天
    连续签到: 59 天
    发表于 2015-4-28 12:06:55 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    SVS SVCam-ECO-4IO系列千兆网工业相机
    基本描述
    SVCam-ECO-4IO cameras are master in LED illumination and communication and can control the timing for illumination precisely. 4 power outputs and 4 inputs (0-24 Volt) provide a maximum of control. Each output can be configured separately to fit the task and type of illumination. Together with a fully programmable sequencer, new possibilities are made available for your applications.
    • VGA up to 5 MegaPixel
    • Progressive scan sensors
    • 4 x direct drive and control of LED lighting
    • GigE Vision and GenICam-Standards compatibility
    • Industrial I/O interface for easy integration
    系列包含产品型号与基本参数
    ModelSensorResolution [pixel]Sensor SizeFrame-
    rate [fps]
    ChromaLens MountInterface
    eco414rCVGE4IOICX414AQ / Sony656 x 4921/2125bayerCS-MountGigE
    eco414MVGE4IOICX414AL / Sony656 x 4921/2125monoCS-MountGigE
    eco424CVGE4IOICX424AQ / Sony656 x 4921/3124bayerCS-MountGigE
    eco424MVGE4IOICX424AL / Sony656 x 4921/3124monoCS-MountGigE
    eco618CVGE4IOICX618AQA / Sony656 x 4941/4155bayerCS-MountGigE
    eco618MVGE4IOICX618ALA / Sony656 x 4941/4155monoCS-MountGigE
    eco415CVGE4IOICX415AQ / Sony780 x 5801/286bayerCS-MountGigE
    eco415MVGE4IOICX415AL / Sony780 x 5801/286monoCS-MountGigE
    eco204CVGE4IOICX204AK / Sony1024 x 7761/347bayerCS-MountGigE
    eco204MVGE4IOICX204AL / Sony1024 x 7761/347monoCS-MountGigE
    eco445CVGE4IOICX445AQA / Sony1296 x 9641/330bayerCS-MountGigE
    eco445MVGE4IOICX445ALA / Sony1296 x 9641/330monoCS-MountGigE
    eco267CVGE4IOICX267AK / Sony1392 x 10401/225bayerCS-MountGigE
    eco267MVGE4IOICX267AL / Sony1392 x 10401/225monoCS-MountGigE
    eco285CVGE4IOICX285AQ / Sony1392 x 10402/334bayerC-MountGigE
    eco285MVGE4IOICX285AL / Sony1392 x 10402/334monoC-MountGigE
    eco274CVGE4IOICX274AQ / Sony1600 x 12361/1,826.5bayerCS-MountGigE
    eco274MVGE4IOICX274AL / Sony1600 x 12361/1,826.5monoCS-MountGigE
    eco625CTLGEA4IOICX625AQA / Sony2448 x 20502/320bayerCS-MountGigE
    eco625MTLGEA4IOICX625ALA / Sony2448 x 20502/320monoCS-MountGigE
    eco655CVGE4IOICX655AQA / Sony2448 x 20502/310bayerCS-MountGigE
    eco655MVGE4IOICX655ALA / Sony2448 x 20502/310monoCS-MountGigE
    eco655MVGE4IO具体参数
    工业相机制造商SVS-VISTEK
    模型eco655MVGE4IO
    芯片
    芯片/生产商ICX655ALA /索尼
    芯片类型面阵CCD
    芯片架构行间转移
    读数类型逐行扫描
    浓度
    芯片尺寸(长X宽)8.45 x7.07毫米
    芯片对角线11.02毫米
    光导摄像管等效2/3“
    Pxel尺寸(长X宽)3.45×3.45微米
    像素时钟60 MHz的
    相机
    尺寸(WxHxD)38 X 38 x 33毫米
    重量85克
    防护等级IP40
    接口千兆以太网
    分辨率2448 x 2050像素
    帧速率10 fps的
    曝光时间(min)7微秒
    曝光时间(最大)1秒
    外部暴露时间(min)7微秒
    外照射时间(最大)
    信噪比58分贝,9.6位
    A / D转换器14位
    增益(最大)18分贝
    手动增益是的
    自动增益是的
    数据深度MONO8,MONO12
    内部存储器64 MB
    手动白平衡是的
    自动白平衡
    AOI1
    AOI可自由编程是的
    镜头卡口CS接口
    电源10到25 V(DC)
    耗电量3.1 W
    数字I / O接口
    输出集电极开路
    输入24V
    eco655MVGE4IO尺寸图
    eco655MVGE4IO引脚接线图
    eco655MVGE4IO光谱响应图
    eco655MVGE4IO购买地址
    SVS eco655MVGE4IO_进口CCD_工业相机_机器视觉商城_LED光源_控制器_工业相机_镜头_图像采集卡_视觉配件_方案_系统_图像处理源代码_培训教程_论坛_机器视觉论坛_石鑫华视觉
    http://visionbbs.com
    GMT+8, 2026-4-24 13:21
