查看: 5827|回复: 0
[LV工具模块] LabVIEW Report Generation Toolkit for Microsoft Office 2010 LV报表工具包RGT2010
  • 签到天数: 3794 天
    连续签到: 45 天
    发表于 2013-5-8 20:56:13 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW Report Generation Toolkit for Microsoft Office 2010 for LabVIEW 2010 报表工具包RGT2010适用LabVIEW2010
    RGT报表生成工具包,从LabVIEW2014版开始,有64位版本。在LabVIEW2014-LabVIEW2015版中(含相应的SP1版本),32位的标准安装包中,集成了RGT工具包,但是64位中没有集成该工具包,需要单独下载安装。从LabVIEW2016版开始,则在32位版本、64位版本中,都集成了RGT工具包可选择安装,不需要另外安装。(这里限标准的安装包,即大小一般1-2GB大小的安装文件,各种套件可能不包含RGT的情况。)
    June 2010  Version 10.0.0
    LabVIEW2009-LabVIEW2013SP1版本的RGT工具包,都是单独安装的。从LabVIEW2014版后,在LV中集成RGT工具包,不需要再单独下载安装。
    The computer you are using must meet the following minimum system requirements to run the Report Generation Toolkit:
    Windows 7/Vista/XP
    40 MB of hard drive space
    LabVIEW 2010
    Microsoft Office 2010/2007/2003/XP
    Note:  You must have both Microsoft Word and Microsoft Excel installed before installing the Report Generation Toolkit.
    请购买附件下载
    RGT2010.txt (643 Bytes, 下载次数: 90, 售价: 10 圆)
    LabVIEW 2010 Report Generation Toolkit for Microsoft Office Readme
    Version 10.0.0
    June 2010
    This file contains information to introduce you to the LabVIEW 2010 Report Generation Toolkit for Microsoft Office. The file contains the following information that you need to understand.
    Refer to the National Instruments Web site for the latest information about the Report Generation Toolkit. Refer to the LabVIEW Help for more information about using the Report Generation Toolkit.
    • Windows 7/Vista/XP
    • 40 MB of hard drive space
    • LabVIEW 2010
    • Microsoft Office 2010/2007/2003/XP
    You can install all of your LabVIEW products—including the Report Generation Toolkit—using the LabVIEW 2010 Platform DVDs. You can find installation instructions for the Report Generation Toolkit along with activation instructions in the following locations:
    • LabVIEW 2010 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2010 Platform DVDs, refer to the National Instruments Web site.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the LabVIEW 2010 Report Generation Toolkit.
    IDKnown Issue
    227535When the Word Update Graph VI uses templates with the file name extension *.docx from Office 2007 or Office 2010, an error occurs. As a workaround save the template with the file name extension *.doc.
    The following items are the IDs and titles of a subset of issues fixed in the LabVIEW 2010 Report Generation Toolkit. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of the LabVIEW 2010 Report Generation Toolkit.
    114803If you save a VI, which uses the Report Express VI, with a file name that includes non-ASCII characters, an error occurs when you run your VI.
    170264The VI Set Report Header Text cannot display strings that begin with a number.
    176502The output of the Excel Find and Replace VI always returns TRUE.
    182126The Excel Set Chart Colors VI cannot change the color in Excel graphs.
    Important Information
    © 2010 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-2-5 10:55
