查看: 5770|回复: 0
[LabVIEW] NI LabVIEW 2010SP1 Win32ENG 32位LV2010SP1英语版下载
  • 签到天数: 3696 天
    连续签到: 23 天
    发表于 2013-5-8 20:46:02 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    请购买附件下载查看
    LV2010SP1ENG.txt (322 Bytes, 下载次数: 52, 售价: 10 圆)
    LabVIEW 2010 Service Pack 1 Readme for Windows
    Version 10.0.1
    December 2010
    This file contains important last-minute information about LabVIEW 2010 Service Pack 1 (SP1) for Windows, including installation and upgrade issues, compatibility issues, a partial list of bugs fixed for LabVIEW 2010 SP1, changes from LabVIEW 2010, and a link to the Web page that contains known issues for LabVIEW.
    Refer to the LabVIEW Upgrade Notes for more information about upgrade and compatibility issues and a complete list of new features in LabVIEW 2010 and related service packs. Refer to the LabVIEW Release Notes for installation instructions and a complete list of system requirements. After you install LabVIEW, refer to the labview\manuals directory to access these documents. You also can access the LabVIEW Release Notes and LabVIEW Upgrade Notes at ni.com.
    Refer to the National Instruments Web site for the latest information about LabVIEW 2010 SP1.
    Installing LabVIEW 2010 SP1
    Installing Another Language Version
    Licensing
    LabVIEW 2010 SP1 (64-bit)
    Additions to the LabVIEW Help
    If you have LabVIEW 2010 installed, you can install LabVIEW 2010 SP1 without uninstalling LabVIEW 2010.
    Note: You cannot have both LabVIEW 2010 and LabVIEW 2010 SP1 installed simultaneously because LabVIEW 2010 SP1 installs over LabVIEW 2010.
    If you do not have LabVIEW 2010 installed, you can install LabVIEW 2010 SP1 without first installing LabVIEW 2010.
    Refer to the LabVIEW Release Notes for more information about installing LabVIEW on Windows.
    If you have LabVIEW 2010 SP1 installed in another language, uninstall that version before you install the new language version.
    Licensing
    LabVIEW relies on licensing activation. You must activate a valid LabVIEW license before you can run LabVIEW. To activate the license, use the serial number you received as part of your installation package. If you upgrade to LabVIEW 2010 SP1 from LabVIEW 2010, use your existing LabVIEW 2010 serial number during installation.
    Refer to the LabVIEW Release Notes for more information about licensing in LabVIEW.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in LabVIEW 2010 and related service packs.
    When run on Windows (64-bit), LabVIEW 2010 SP1 (64-bit) provides access to more memory than a 32-bit operating system or a 32-bit application can provide. LabVIEW 2010 SP1 (64-bit) includes nearly all of the development environment features of LabVIEW 2010 SP1 (32-bit), including the LabVIEW Application Builder.
    Refer to the National Instruments Web site for information about obtaining a copy of LabVIEW 2010 SP1 (64-bit).
    LabVIEW 2010 SP1 (64-bit) supports many hardware devices. Drivers are available for DAQ devices, VISA devices, GPIB devices, and image acquisition devices. For GPIB devices, you must use at least NI-488.2 2.6 for Windows. Refer to the specific hardware documentation for more information about compatibility with LabVIEW 2010 SP1 (64-bit).
    Supported Modules
    LabVIEW 2010 SP1 (64-bit) supports only the NI Vision Development Module. Refer to the Vision Development Module documentation for more information. LabVIEW 2010 SP1 (64-bit) does not support any additional modules.
    The following list contains additional changes to LabVIEW that are not included in the LabVIEW Help, the LabVIEW Upgrade Notes, or both:
    • The Mass Compile dialog box includes the Include warnings for read-only VIs checkbox, which determines whether the mass compile results include warnings next to the read-only VIs.
    • The Advanced TDMS palette includes the TDMS Generate Random Data VI, which generates random data that you can use to test the performance of the Advanced TDMS VIs and functions.
    • The TDMS Configure Asynchronous Writes function does not include the data mode input.
    • On the Web Server page of the Options dialog box, the Configure Web Application Server button launches NI Web-based Monitoring and Configuration on the local system.
    • On the Web Server page of the Options dialog box, the Enable Web Server checkbox is renamed Enable Remote Panel Server.
    • In the Icon Editor dialog box, select Edit»Import Icon from Owning Library to import the icon of the owning project library. LabVIEW creates a user layer with the name NI_Library and with the icon of the owning library as the glyph. If a user layer with that name already exists, the new user layer overwrites the existing user layer.
    • The VISA Find Resource function returns error code -1073807343 if the system locates no devices.
    • LabVIEW 2010 and related service packs do not support the Disconnect Polys And Typedefs method.
    • If you wire a combination of signed and unsigned integers to the upper limit, x, and lower limit inputs of the In Range and Coerce function, the data type of the coerced(x) output must be large enough to represent the full range of possible input values. If the coerced(x) output is an unsigned integer, the signed input values must be positive because an unsigned integer cannot represent a negative number.
    • When a change to a VI in a packed project library impacts the inplaceness of the connector pane, by default the caller VI adapts to inplaceness changes. As a result, you do not need to recompile the VI that calls the packed library. If you want the caller VI to recompile when the inplaceness changes, remove the checkmark from the Callers adapt at run time to Exported VI connector pane state checkbox on the Connector Pane State page of the Packed Library Properties dialog box. If you make a non-inplaceness change to a VI in a packed library, the VI must recompile.
    • Some National Instruments components require Microsoft Silverlight 4.0. If you use a component that requires Silverlight, a dialog box prompts you to install Silverlight from the Internet. Microsoft Silverlight 4.0 is available from the Microsoft Web site at microsoft.com/silverlight.
    • Due to compiler optimizations in LabVIEW 2010 and related service packs, VIs can execute faster but might take up to five times longer to compile. You might not notice these changes unless you load a large VI. Refer to the National Instruments Web site for more information about compiler optimizations.
    The following table contains the IDs and titles of a subset of issues fixed in LabVIEW 2010 SP1. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    142433LabVIEW 8.6 internal error. Failure in drawmgr.cpp at line 2548
    231395Closing VI without quitting out of reorder cluster elements mode crashes LabVIEW
    234701Unexpected behavior in Local domain property page
    236536Tagger crashes on startup if it contains a dataset I/O server whose dataset id is set to a network boolean variable without the value.
    237220LabVIEW 2009 SP1 TD80ReadWrite.cpp line 1487
    237547Opening block diagram with shared variable node bound to I/O variable crashes 64-bit LabVIEW
    238566You cannot remote debug an application with an XControl in it.
    239042The Open VI Reference primitive cannot open VIs in the .Net Interop Assembly
    239399LabVIEW 2009 Mac OS X Runtime with 2 LabVIEW Frameworks - InitLVClient failed
    240373Upgrade issue is 2010 from 821: a broken wire appears in 2010
    240387Trying to include Web UI Builder xap in a web service makes it fail to deploy
    240502Creating a source distribution with the main destination set to a library will not work correctly
    240720Array subset doesn't get copied at inplace node boundary
    240745FP sane crash in LabVIEW 2010 from copying a wire with a label
    240985Strange edit time behavior with the Search Variable Container primitive.
    241479When copying a project library .lvlib , stopping search for needed VI aborts LabVIEW
    242182Paste operation in icon editor creates two layers instead of just one
    242603LabVIEW 2010 crashes on compile if you have a divide primitive with dominator less than 1 wired to the for loop count terminal (N)
    242693A Packed Project Library will not export VIs that did not have block diagrams before the build
    242778Library (or class or XControl) may become corrupted by saving a reference to non-existent untitled VI
    242796LabVIEW fails to compare VIs that contain feedback nodes set to show their enable terminal
    242867InstallQuitNotification() doesn't work in LabVIEW built .Net Assembly and Shared Library
    243091New radix for string control manipulation crashes LabVIEW in some cases
    243106Broken wires or bad terminals with Insert Into Array primitive crashes LabVIEW 2010
    243380Intensity Chart crash in LabVIEW
    243625Nested libraries cause unnecessary dirty dot.
    24392164-bit LabVIEW 2010 won't deploy web services by default
    24396364-bit LabVIEW 2010 doesn't install clientaccesspolicy.xml to www folder
    244148Certain Trigonometric Functions Return Incorrect Results in LabVIEW 2010 when Using Extended Precision Inputs
    244224Specific out of memory exception caught in llvm gencode
    244393AppBuilder on Linux uses wrong file name for configuration file destinations
    244819Creating a snippet of code combination with breakpoint throws cpp error: Signal.cpp line 3077
    245129LabVIEW App crashes when resizing Modern vertical toggle switch
    245334Error 74 with .NET reference and "Create Database.vi"
    245571Control References no longer colored by data type
    245609Connector Pane Terminals Lose "Required" Setting When Switching with Ctrl-Click
    245844Building a Packed Library hangs LabVIEW
    245915Recursive VI cause a crash when saved for previous
    246156ThEvent.cpp line 236 in LabVIEW 2010
    246254Always Included libraries show blank target in shared variable deployment page
    246375Unexplained broken wire when local variable of Chart control interacts with uninitialized shift registers
    246497LabVIEW 2010 hangs when you expand a RFSG property node that has been changed to set to default
    246593Power of X and Y-th Root of X returns incorrect result when using single precision numbers
    246611CPUID(4) provided cache that CPUID(2) did not. Intel cache parse may need an update
    24667364-bit Application web server does not install clientaccesspolicy.xml
    246681lvwsdsc not generated correctly unless your VI is in your project directory
    246966Write to Text File output changed from LabVIEW 2009 to 2010 if the user selects cancel in the file dialog
    247151setXML invoke node crashes LabVIEW 2010
    247379Remove then Undo of Tab Control Crashes LabVIEW
    247384TestStand Error -18004 When Attempting to Configure or Execute LabVIEW 2010 VIs While Debugging My LabVIEW User Interface in LabVIEW 2010
    247501Export Simplified Image option for graphs does not appear in a LabVIEW 2010 executable
    247734Browse dialog of path control returns wrong path
    247859LabVIEW crashes when opening VI containing a particular Simulation Node
    248065Application Builder fails with Error 74 with upgraded .NET and a dll call
    248143Compiling a VI which has a FXP data wired to a Loop-N terminal of a for loop results in LabVIEW crash.
    248224Customers can build executables using third party toolkits in evaluation mode
    248822VI Created in 2010 Gives "VI Failed To Compile" Error
    249216Cleanup block diagram can crash if wire label is moved off of a wire
    249978Failed to convert .NET Object to Variant error when calling NationalInstruments.LabVIEW.Interop.DoubleWaveform
    250080Control Value -> Get All not working in 2010
    250119LabVIEW crashes if you delete a compound arithmetic primitive with a breakpoint
    250488NI Web-Based Monitoring and Configuration not installed with stand-alone web service
    251229Adjusting X-Scale Multiplier Property Affects Graph Annotations
    251397Broken wires or bad terminals with Insert Into Array primitive crashes LabVIEW 2010
    252210LabVIEW Crashes when Summing an Array Created from a Cluster when a Fixed Length Data Element is also Present in the Cluster
    252215Odd behavior when moving a wire's label
    252230Custom Probes don't work for Chart
    252406LabVIEW 2010 undo does not unzoom plot with undo
    252697Unable to create a new Library inside a project using invoke node
    252799datamgr.cpp crash line 2720 when using strict type def control containing XControl
    253243Print.VI to HTML crashes LabVIEW when using Complete Format with a 2010 Custom Control
    253844XControl issue when upgrading: property "Name" not accessable correctly
    254255Opening a VI inside a packed project library that calls the Create Reports Express VI in the RTE crashes the RTE
    254558LabVIEW crashes when right-clicking on listbox in Control Editor
    254821LabVIEW built executable with network streams won't exit process
    255166Opening VI with floating broken wire crashes LabVIEW.
    255982Child Class Property Node does not output until deleting and rewiring any part of the VI
    256172Source distributions link incorrectly against classes inside of packed libraries
    256324Indicator in LabVIEW 2010 subVI does not update from local variable
    256768Ctrl Val.Set method returns error 1 in executable
    257197Error Constant erroneously added to Variant to Data
    Recompiling VIs for Bug Fixes
    The following fixes require you to manually recompile VIs to correct the problem:
    • 240720—Array subset doesn't get copied at inplace node boundary
    • 246966—Write to Text File output changed from LabVIEW 2009 to 2010 if the user selects cancel in the file dialog
    • 255982—Child Class Property Node does not output until deleting and rewiring any part of the VI
    • 256324—Indicator in LabVIEW 2010 subVI does not update from local variable
    • 276831—Output of zero generated from the multiply node with certain DAQmx properties and VIs when using highlight execution
    To force a recompile of a VI without recompiling its subVIs, press the key while you click the Run button. To force a recompile of all VIs in memory, press the keys while you click the Run button. To force a recompile of the entire current VI hierarchy, close all VIs currently opened, open the top-level VI, and press the keys while you click the Run button. This method does not recompile any of the VIs called dynamically in the hierarchy.
    You also can force a recompile of all VIs in a specified directory using the following steps.
    • Open LabVIEW.
    • Select Tools»Advanced»Mass Compile to display the Mass Compile dialog box.
    • Navigate to the desired directory and click the Current Folder button.
    • Click the Mass Compile button to force a recompile of all VIs in that directory.
    • Click the Done button to return to LabVIEW.
    © 2010 National Instruments Corporation. All rights reserved.
    For copyright notices, conditions, and disclaimers, including information regarding certain third-party components used in LabVIEW, refer to the Copyright topic of the LabVIEW Help.
    LabVIEW, National Instruments, NI, ni.com, LabVIEW, the National Instruments corporate logo, and the Eagle logo are trademarks of National Instruments Corporation. Refer to the Trademark Information at ni.com/trademarks for other National Instruments trademarks.
    GMT+8, 2025-10-29 12:16
