查看: 17889|回复: 1
[NI驱动程序] NI Vision Acquisition Software 2015.02 LabVIEW2014SP1 Win32/64Eng 视觉采集软件VAS2015February下载
    半小时前
  • 签到天数: 3829 天
    连续签到: 22 天
    发表于 2015-3-18 10:59:00 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI视觉采集软件(相机驱动),包含IMAQ、IMAQdx等,支持驱动AVT、Basler、TELI、JAI、SONY、TheImagingSource、SVS等三方工业相机。
    2015.02版,支持LabVIEW2014SP1、VisionDevelopmentModule2014SP1、VisionBuilder2014SP1等NI视觉软件与开发平台。
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    NI官方下载地址:
    标准下载:
    请购买附件下载查看
    下载器下载:
    请购买附件下载查看
    文件大小: 2376513454 字节 (2.21 GB)
    修改日期: 2015-03-14 16:50
    MD5: e6bf90c5b80b0e64acb22cfe43025b07(官方正确)
    SHA1: c4fcd43f63e8fd1b83c1e400db29609257962c1a
    SHA256: f6f945c7b3b7f887b69fb2e0af78eb1b2b5fdcb488fed1f4a8898b4623c6c96d
    CRC32: 82b22ccb
    VAS2015.02.txt (363 Bytes, 下载次数: 96, 售价: 10 圆)
    NI Vision Acquisition Software Release Notes
    February 2015
    This file contains important information about National Instruments Vision Acquisition Software, including installation instructions, new features, fixed issues, and known issues.
    Updates and Improvements
    Configuring NI-IMAQ
    Configuring NI-IMAQdx
    Documentation and Examples
    NI Vision Acquisition Software allows you to acquire, display, and save images; control digital I/O on National Instruments image acquisition devices; and configure your driver software and hardware.
    NI Vision Acquisition Software includes the following drivers:
    • NI-IMAQ is driver software for NI 17xx smart cameras, as well as analog, parallel digital, and Camera Link image acquisition devices.
    • NI-IMAQdx is driver software that supports NI 177x smart cameras, as well as IEEE 1394, GigE Vision, DirectShow-compatible USB, USB3 Vision cameras, and IP cameras.
    • NI-IMAQ I/O is driver software for controlling reconfigurable input/output (RIO) on image acquisition devices and real-time targets. The following hardware is supported by NI-IMAQ I/O:
      • NI CVS-1457RT
      • NI CVS-1458RT
      • NI CVS-1459RT
      • NI EVS-1463RT
      • NI EVS-1464RT
      • NI PCI-8254R
      • NI PCIe-8255R
      • NI PCIe-8237R
      • NI PCIe-1473R
      • NI PCIe-1473R-LX110
      • NI 1483R FlexRIO Adapter Module
    Refer to the NI Vision website at ni.com/vision for the latest information about NI Vision Acquisition Software.
    The development computer must meet the following requirements to run NI Vision Acquisition Software:
    Processor
    Pentium 4 1 GHz or equivalent
    Memory
    512 MB RAM
    Display
    1,024 × 768 resolution video adapter with a 16-bit display
    Minimum Recommended
    Free Hard Disk Space
    3.5 GB
    NI-IMAQ
    1.5 GB
    NI-IMAQdx
    1.5 GB
    NI-IMAQ I/O
    2.5 GB
    Operating System
    • Windows 8.1 (32- and 64-bit)
    • Windows 8.0 (32- and 64-bit)
    • Windows 7 (32- and 64-bit)
    • Windows Vista (32- and 64-bit)
    • Windows XP SP3 (32-bit)
    The following table lists the NI application software versions, including service packs, supported by the NI Vision Acquisition Software. The installer specifically allows side-by-side installations of NI Vision Acquisition Software for each of the supported versions of LabVIEW, enabling you to use the NI Vision Acquisition Software with multiple versions of LabVIEW. National Instruments recommends that you install LabVIEW, LabVIEW Real-Time, and any other supported development environment before installing NI Vision Acquisition Software.
    NI Application SoftwareVersions Supported by NI Vision Acquisition Software
    NI LabVIEW
    2011, 2012, 2013, 2014
    NI LabVIEW Real-Time Module
    NI LabVIEW FPGA Module
    NI LabWindows™/CVI™
    2010, 2012, 2013, 2014
    NI Vision Development Module
    7.1 or later
    NI Vision Builder for Automated Inspection
    2.5 or later
    NI Vision Acquisition Software .NET Support
    NI Vision Acquisition Software February 2014 was the last version to release updated support for the .NET Framework 2.0, .NET Framework 3.5, and .NET language integration into Visual Studio 2005 and Visual Studio 2008. Visual Studio 2010 and later are not supported.
    New versions of NI Vision Acquisition Software will not provide new .NET feature support or development. It is recommended that you begin new development in other supported development environments.
    Remote Target Support
    NI Vision Acquisition Software February 2013 was the last version of NI Vision Acquisition Software to provide support for the NI 1454, 1455, and 1456 Compact Vision Systems. New software features of NI Vision Acquisition Software will not work on these devices. Backward compatibility for existing applications is maintained.
    This release of NI Vision Acquisition Software includes the following new features.
    • Simplified the software installation experience in MAX by using Recommended Software Sets for Vision Acquisition Software on NI Embedded Vision Systems, NI Compact Vision Systems, and NI 17xx smart cameras. This feature is only available for LabVIEW Real-Time 2014 SP1.
    • Added support for Data Neighborhood in NI CVS-1458RT and CVS-1459RT Compact Vision Systems
    NI-IMAQ 14.5
    • Support for LabVIEW 2014 SP1 (32- and 64-bit)
    NI-IMAQdx 14.5
    • High performance USB3 Vision driver for Linux Real-Time targets which reduces CPU utilization
    • Ring acquisition mode added for NI-IMAQdx VIs which reduces CPU utilization
    • Support for using the Vision FPGA Transfer VIs in LabVIEW 64-bit with a LabVIEW bitfile that was previously compiled with the LabVIEW FPGA Module to transfer image data between the host and the FPGA
    • Ability to ignore attribute out-of-range errors on GigE Vision and USB3 Vision cameras
    NI-IMAQ I/O 14.5
    The following list describes issues in previous versions of NI Vision Acquisition Software that are fixed in this release. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of NI Vision Acquisition Software.
    489509USB3 Vision cameras timeout after repeatedly stopping and restarting acquisition, which requires the camera to be unplugged and reconnected before it is usable again.
    511043LabVIEW-based applications can crash when connecting to a camera that returns unexpected malformed data.
    456871A crash occurs when disabling some Vision Acquisition Software devices in Device Manager.
    511238NI 1712, 173x, and 175x smart cameras cannot acquire images to addresses in internal memory higher than 128 MB.
    508111The Detailed Help link in the LabVIEW context help window for NI-IMAQdx VIs is not properly linked.
    468270, 504970, 497386, 509800, 501862, 492656, 481066Various crash and stability issues with NI Vision Acquisition Software in MAX.
    510253NI-IMAQdx, NI-IMAQ, and NI-IMAQ I/O cannot be deployed with development support included in the LabVIEW Application Builder Additional Installers settings.
    467119NI SoftMotion cannot be installed to a CVS-1457RT or CVS-1458RT.
    40716164-bit addressing for GigE Vision and USB3 Vision cameras is not available. New NI-IMAQdx Read Register2, Write Register2, Read Memory2, and Write Memory2 VIs are available for this purpose.
    419914Switching between NI-IMAQ devices in MAX causes a buffer locking error.
    369766NI-IMAQdx will not enumerate cameras that advertise GEV 2.0 compatibility.
    489363The histogram window in MAX opens to the maximum width of the desktop display area.
    508701Closing a histogram window in MAX during a Grab can cause a hang.
    479184NI-IMAQ device icons do not display accurate states for device readiness in MAX.
    503307The Vision Acquisition Express VI cannot transfer files with NI Linux Real-Time targets.
    493233The Vision Acquisition Express VI cannot enumerate all files on NI Linux Real-Time targets.
    Complete the following steps to install NI Vision Acquisition Software:
    Note: You must have administrator access to install NI Vision Acquisition Software.
    • Insert the NI Vision Acquisition Software installation media.
    • If you do not have autorun enabled, double-click autorun.exe. If you have autorun enabled, autorun.exe runs automatically.
    NI-IMAQ and NI-IMAQdx integrate with NI MAX, the National Instruments utility for configuring and testing your measurement and automation system. The NI MAX icon appears on your desktop after you install NI Vision Acquisition Software.
    Configuring NI-IMAQ
    Complete the following steps to install an image acquisition device and configure NI-IMAQ:
    Note: You must install NI-IMAQ before installing your image acquisition device.
    Caution: Power off and unplug the computer before installing your hardware. Wait for any motherboard LEDs to power off before proceeding, since some computers remain powered for some time after being unplugged.
    • Install your image acquisition device, and connect the camera. Refer to the device documentation for specific hardware installation instructions.
    • Run NI MAX.
      • Double-click the NI MAX icon on the desktop. You can use NI MAX to modify camera properties. Once you have saved these properties, they become the default settings for all NI-IMAQ applications.
      • Expand Devices and Interfaces and NI-IMAQ Devices to display a list of the image acquisition devices installed on your computer.
    • Select a camera file, and acquire an image.
      • Click the plus sign next to the image acquisition device to expand the menu tree and list the available channels or ports. Right-click the channel or port to display a list of available cameras.
      • Select the appropriate camera type from the list. Camera type selection varies according to the image acquisition device installed.
      • To change the camera settings, modify the parameters at the bottom of the image viewer panel.
      • You can acquire an image in the following ways:
        • Use the Snap button to acquire and display a single image with the image acquisition device.
        • Use the Grab button to acquire images continuously. A grab allows you to focus the camera.
    Tip: For a complete list of supported cameras, right-click the channel or port, select Camera, and click Search ni.com.
    Note: Refer to the right side of the MAX user interface, which displays context-sensitive help, for information about configuring image acquisition devices with NI MAX.
    Configuring a Remote PXI/Compact PCIe Image Acquisition Device
    Use NI MAX to install NI-IMAQ for LabVIEW Real-Time from the host machine onto the target system. The NI-IMAQ for LabVIEW Real-Time components enable the remote device to acquire and analyze images as directed by the host machine.
    Note: Install NI-IMAQ and the LabVIEW Real-Time Module on the remote system before you install and configure the image acquisition device. Follow the steps in the NI MAX help window to install software.
    Tip: Configuring remote image acquisition devices is similar to configuring local image acquisition devices, except that the procedure for working with camera files is different. Refer to the Measurement & Automation Explorer Help for NI-IMAQ for information about working with camera files on remote image acquisition devices.
    • Launch NI MAX.
    • In the Configuration tree, expand Remote Systems.
    • Expand the appropriate system.
    • Expand Devices and Interfaces.
    • Expand NI-IMAQ Devices.
    • Expand the device you want to configure.
    Refer to the Measurement & Automation Explorer Help for NI-IMAQ for information about configuring specific NI image acquisition devices. You can access this help file from the NI MAX Help menu by selecting Help»Help Topics»NI Vision»NI-IMAQ.
    Complete the following steps to configure NI-IMAQdx.
    If you are using a USB camera, ensure that the camera is compatible with DirectShow, and that the camera driver is installed and functioning. For specific information about drivers and camera compatibility, consult your camera manufacturer documentation.
    Instructions for configuring an IEEE 1394 or GigE Vision camera are included in the Measurement & Automation Explorer Help for NI-IMAQdx. You can access this help file from the MAX Help menu by selecting Help»Help Topics»NI Vision»NI-IMAQdx.
    Installing the High Performance GigE Vision Driver
    If you have an Intel Pro/1000 Series gigabit Ethernet Network Interface Card (NIC), it is recommended that you install the High Performance GigE Vision Driver. This will ensure optimized performance and minimal configuration. To associate your hardware with the high performance driver, complete the following steps.
    Windows 8.1/8/7/Vista/Server 2012/Server 2008
    • Install the NIC.
    • Right-click the NIC in the Device Manager, and select Update Driver.
    • Choose Browse my computer for driver software.
    • Browse to the driver location. The newest driver version is installed to \NI-IMAQdx\Staging\NI GigEVision\Current.
    • Click Next.
    • Click Close.
    Windows XP and Windows Server 2003
    • Install the NIC.
      • If Windows does not prompt you to choose a driver, proceed to step 2.
      • If Windows prompts you to choose a driver, proceed to step 3.
    • Choose not to connect to the Windows Update Web site, and click Next.
    • Choose to Install from a list or a specific location, and click Next.
    • Choose Don't Search. I will choose the driver to install.
    • Click Next.
    • Select National Instruments GigE Vision driver from the list, and click Next. The driver version that is compatible with Windows XP and Windows Server 2003 is installed to \NI-IMAQdx\Staging\NI GigEVision\WHQL.
    • Click Finish.
    Installing the Universal GigE Vision Driver
    NI-IMAQdx will work with any standard gigabit Ethernet NIC. To use NI-IMAQdx with a standard gigabit Ethernet NIC, complete the following steps:
    • Install the NIC and any related drivers. Refer to the NIC device documentation for installation instructions.
    • Enable jumbo frames (frame packet size is greater than 1,500 bytes) on your NIC.
      • Right-click the NIC in the Device Manager, and select Properties.
      • Click the Advanced tab, and Jumbo Frames will appear in the Property list if supported by your NIC.
      • Select the largest frame size available and click OK.
      Note: The procedure for enabling jumbo frames on your NIC may vary by manufacturer. Refer to the NIC device documentation for more information about enabling jumbo frames.
    • Disable the Windows Firewall or any additional third party firewalls on the port. Windows Firewall can be disabled on individual ports from the Advanced tab of the Windows Firewall applet.
    Configuring Multiple Ports (Windows XP only)
    If you plan to use multiple ports with NI-IMAQdx, complete the following steps:
    • Open the Network Connections window in Windows, and select all of the ports that cameras will be connected to by holding while clicking each port.
    • Right-click one of the selected ports, and choose Bridge Connections.
      Note: If you are not using the High Performance Driver, you will be unable to use jumbo frames on bridged devices.
    Configuring NI-IMAQdx for Windows
    Complete the following steps to configure NI-IMAQdx for Windows:
    • Connect the camera.
    • Run NI MAX.
      • Double-click the NI MAX icon on your desktop. You can use NI MAX to modify camera attributes. After you have saved these attributes, they become the default settings for all NI-IMAQdx or NI Vision applications.
      • Expand Devices and Interfaces»NI-IMAQdx in the configuration tree to display a list of the cameras installed on your computer.
      • For IEEE 1394 and USB3 Vision cameras, NI-IMAQdx may not be associated with the camera if a third-party driver is installed. If this is the case, change the associated driver by right-clicking the camera and selecting Driver»NI-IMAQdx.
      • Select the camera from the list. You then can view or modify the camera attributes on the Camera Attributes tab located below the image viewer.
    Tip: Click the Show Help button to display the help window on the right side of the image viewer. Move your mouse over the properties to view context-sensitive help in the bottom half of the help window.
    Configuring NI-IMAQdx for the LabVIEW Real-Time Module
    If you are using a Windows development machine, the LabVIEW Real-Time Module, and an RT target, complete the following steps to install and configure NI-IMAQdx:
    • Install NI-IMAQdx software on your Windows development machine.
    • Ensure that your RT target is connected to the same subnet as the Windows development machine.
    • Run NI MAX.
      • Expand the Remote Systems list in the configuration tree.
      • Select your RT target in the list.
      • Configure your network settings. Refer to the Remote Systems Help in NI MAX (Help»Help Topics»Remote Systems) for instructions about configuring network settings.
    • Install NI-IMAQdx on the Real-Time target.
      • Click the Software item below the RT target in the configuration tree.
      • Click Install Software on the NI MAX toolbar to launch the LabVIEW Real-Time Install Software Wizard.
      • Select Vision Software under the version of the LabVIEW Real-Time Module you are using.
      • Click Next.
      • Select any additional add-ons you would like to install to the target machine.
      • Click Next. Review the list of software you selected to install.
      • Click Next to begin downloading the software to the target machine. When NI MAX has finished downloading the software, it restarts the remote device.
      • Click Finish.
    • Connect your camera to your remote system.
    • Press to refresh the NI MAX configuration tree. Your camera should be listed in the Remote Systems list.
      Tip: Press to refresh the configuration tree whenever you connect a new device to an RT target.
    • Select the camera from the list. You then can view or modify the camera attributes from the Camera Attributes panel located below the image viewer.
    • Runtime installers are localized for deployment, but the development support installers are not. This could lead to a partially localized installation from a custom-built installer.
    • Some NI Vision Acquisition Software examples listed in NI Example Finder in LabWindows/CVI do not launch properly from the Task view. You can launch them from the Directory Structure view, or you can access the examples from the installed location instead:
      • Windows 8.1/8/7/Vista/Server 2012/Server2008—C:\Users\Public\Documents\National Instruments\CVIversion\samples
      • Windows XP/Server 2003—C:\Documents and Settings\All Users\Documents\National Instruments\CVIversion\samples
    NI-IMAQ
    • In LabVIEW 2012 and earlier, error codes returned during a property node read or write are not being reported correctly. The status flag is set correctly, to notify you that an error occurred, but the code is set to an invalid value.
    • In LabVIEW 2012 and later, Project Explorer displays the NI 176x smart camera as a valid real-time target. However, LabVIEW 2012 and later do not support them.
    NI-IMAQdx
    • Volume License Manager attempts to check out available NI Vision Development Module licenses before trying NI Vision Acquisition Software licenses.
    • Attempts to extend the evaluation period for NI Vision Acquisition Software licenses from within LabVIEW or the LabVIEW Run-Time Engine are unsuccessful in connecting to the internet.
    • Renaming a camera on some real-time targets may take a long time to complete.
    NI-IMAQ I/O
    • On NI CVS-1457RT targets, serial configuration is not available in MAX. Programmatic configuration is still available in Vision Builder AI and LabVIEW.
    • Only one NI PCIe-1473R framegrabber can use the virtual serial port at a time.
    • In LabVIEW 2013 and later, Project Explorer displays the NI 1454, 1455, and 1456 Compact Vision Systems as usable real-time targets. However, LabVIEW 2013 and later do not support them.
    Documentation is installed onto your hard drive with NI Vision Acquisition Software. To view the NI Vision Acquisition Software documentation, select Start»All Programs»National Instruments»Vision»Documentation.
    NI Vision Acquisition Software Documentation for NI MAX
    • You can access the Measurement & Automation Explorer Help for NI-IMAQ and the Measurement & Automation Explorer Help for NI-IMAQdx from the NI MAX Help menu by selecting Help»Help Topics»NI Vision. These documents are installed to \MAX\Help.
    NI Vision Acquisition Software Documentation for LabVIEW
    • You can access the NI-IMAQ VI Reference Help, NI-IMAQdx VI Reference Help, and NI Vision-RIO VI Reference Help from the LabVIEW Help menu.
    • NI Example Finder—Illustrates common applications you can create with NI Vision Acquisition Software. In LabVIEW, select Help»Find Examples. Click the Help button in the NI Example Finder to display the NI Example Finder Help.
    NI Vision Acquisition Software Documentation for LabWindows/CVI
    • NI-IMAQ Function Reference Help—Contains reference information about NI-IMAQ functions for LabWindows/CVI. This help file is installed to \NI-IMAQ\Docs.
    • NI-IMAQdx Function Reference Help—Contains reference information about NI-IMAQdx functions for LabWindows/CVI. This help file is installed to \NI-IMAQdx\Docs.
    • Function panel help within LabWindows/CVI—Allows you to right-click within each function to access help for that function, control, function class, and function library. The niimaq.fp, NIIMAQdx.fp, and imaqio.fp function panels are installed to \CVI\Bin.
    • Example programs are installed to
    When you install National Instruments software on Microsoft Windows 8.x, you will notice a few additional tiles on the Start screen, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (MAX), and the new NI Launcher.
    Using NI Launcher
    Note  NI MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8.x. You can launch NI MAX either from the Start screen or from within NI Launcher.
    Finding All Programs
    NI Vision Acquisition Software Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    NI Vision Acquisition Software will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI Vision Acquisition Software that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    NI LabVIEWlifecycle
    NI LabWindowsT/CVITcvi_lifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2015 National Instruments. All rights reserved.
    发表于 2017-8-12 10:31:42 | 显示全部楼层 来自:广东省东莞市 电信
    GMT+8, 2026-3-18 09:26
