TA的每日心情 | 难过 9 小时前 |
签到天数: 3699 天 连续签到: 26 天 [LV.Master]2000FPS
发表于 2014-12-2 15:48:47
JAI C3系列工业相机
JAI的A系列、B系列、C系列统一归属为C3系列,即C3 – Advanced(A系列-高级型)、C3 – Basic(B系列-基本型)、C3 – Compact(C系列-紧凑型)。
C3系列的优点:
标准化的接口
通用的软件开发包
黑白和彩色版本
带有紧固螺钉的工业千兆网接口或者Camera Link接口
可编程的GPIO
光耦隔离输入输出
全天候的全球服务
持续的在线资源更新
JAI C3系列工业相机
C3系列相机介绍:
The C3 Camera Suite is made up of three product tiers
-Advanced
-Basic
-Compact
Each tier offers a range of high-performance products with individual capabilities, putting unparalleled functionality at your fingertips.
Switch to faster, easier integration
The C3 Camera Suite makes it simpler than ever to integrate cameras into machine vision solutions. System Integrators and Original Equipment Manufacturers can switch between the three tiers without changing any cabling or software.
All C3 cameras integrate smoothly with third-party software libraries, and all are backed by JAI's comprehensive Software Development Kit, ensuring straightforward configuration.
All C3 GigE Vision cameras offer:
-Standardized interface
-Common Software Development Kit
-Monochrome and color versions
-Industrial Gigabit Ethernet connectors with thumb-screws
-Programmable General Purpose Inputs / Outputs (GPIO)
-Opto-isolated inputs and outputs
-Flexible system architectures with up to 100 meters of cable
-Round-the-clock global support
-Constantly updated online resources
C3 Advanced:
High-end cameras designed to handle the most demanding applications, C3 Advanced cameras combine the finest analog and digital circuit designs. The result is the ultimate high-performance cameras.
-Superb performance
-Broad range of pre-processing
-Supports 2CCD and 3CCD
-Housing cross section: 55 x 55 mm
C3 Basic:
Versatile and flexible, C3 Basic cameras are in the mid-range tier. They offer superb thermal management and pre-processing – and guarantee the right image, every time.
-Truly versatile and flexible
-Excellent thermal management
-Multi-tap imager support
-Standard dimensions: 55 x 55 x 55 mm
C3 Compact:
Entry-level cameras offering small form factor, uncompromised image fidelity – and an easy switch from analog compact cameras to a digital platform.
-Entry-level products
-Easy switch from analog
-High frame rate, single tap
-Small size: 29 x 44 x 75 mm
A系列型号:
AM/AB-800GE
AM/AB-201GE
AM/AB-201CL
AM/AB-200CL
AM/AB-1600GE
AM/AB-1600CL
AM/AB-800CL
AM/AB-200GE
B系列型号:
BM/BB-500GE
BM/BB-500CL
BM/BB-141GE
C系列型号:
CM-200MCL/CB-200MCL
CM-200GE/CB-200GE
CM-141MCL/CB-141MCL
CM-140MCL/CB-140MCL
CM-140GE/CB-140GE
CM-040MCL/CB-040MCL
CM-080GE/CB-080GE
CM-040GE/CB-040GE
CM-030GE/CB-030GE |
