查看: 18288|回复: 0
[LV工具模块] NI Vision Development Module 2014F1 Win32/64Eng 视觉开发模块VDM2014F1 适用LabVIEW2014
    昨天 08:12
  • 签到天数: 3787 天
    连续签到: 38 天
    发表于 2014-9-2 10:36:50 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI视觉开发模块整合了图像处理和机器视觉功能,适用于多种编程语言(如:NI LabVIEW与Microsoft C++、Visual Basic、.NET)。通过这些功能,即可增强图像、检查显像、定位特征、识别对象并测量部件。搭配程序库,NI视觉开发模块还包含NI视觉助手(Vision Assistant)和NI视觉采集软件。
    视觉开发模块的特性如下:
    数百种图像处理功能, 包含模式与几何匹配、OCR、条形码阅读器、目标分类和颗粒分析
    亚像素 (subpixel)精度, 降至像素的1/10和度数 (degree)的1/10
    通过视觉助手(Vision Assistant), 快速进行应用建模和代码生成
    驱动软件适用于数千款相机, 包含千兆以太网相机和IEEE 1394相机
    请购买附件下载查看
    标准下载:
    请购买附件下载查看
    NI下载器下载:
    请购买附件下载查看
    VDM2014F1.txt (440 Bytes, 下载次数: 108, 售价: 10 圆)
    NI Vision Development Module 2014 f1 Readme
    August 2014
    This file contains important information about National Instruments Vision Development Module, including installation instructions, new features, fixed issues, and known issues.
    Updates and Improvements
    How to Activate the NI Vision License
    Deploying Vision Applications
    Documentation and Examples
    The NI Vision Development Module provides hundreds of image processing and machine vision functions. Along with programming libraries, the NI Vision Development Module also includes NI Vision Assistant. Installing this software may remove previous versions of the NI Vision Development Module that are currently installed.
    Note: The NI Vision Development Module overwrites existing NI Vision examples and NI Vision VIs. Move modified examples or VIs that you want to save to another directory before installing the NI Vision Development Module.
    Refer to the NI Vision website at ni.com/vision for the latest information about the NI Vision Development Module.
    The development computer must meet the following system requirements to run the NI Vision Development Module.
    MinimumRecommended
    Processor233 MHz Pentium or equivalentPentium 4/M or equivalent
    Memory256 MB RAM512 MB RAM
    Display1,024 × 768 resolution video adapter with a 16-bit display1,024 × 768 resolution video adapter with a 24- or 32-bit display
    Free Hard Disk Space
    3.2 GB
    Operating System
    • Windows 8.1 (32- and 64-bit)
    • Windows 8 (32- and 64-bit)
    • Windows 7 (32- and 64-bit)
    • Windows Vista (32- and 64-bit)
    • Windows XP SP3 (32-bit)
    The following table lists the NI application software versions, including service packs, supported by the NI Vision Development Module. The installer specifically allows side-by-side installations of Vision Development Module for each of the supported versions of LabVIEW, enabling you to use the NI Vision Development Module with multiple versions of LabVIEW. National Instruments recommends that you install LabVIEW, LabVIEW Real-Time, or any other supported development environment, before installing the NI Vision Development Module.
    NI Application SoftwareVersions Supported by NI Vision Development Module
    NI LabVIEW
    2011, 2012, 2013, 2014
    NI LabVIEW Real-Time Module
    NI LabVIEW FPGA Module
    2014
    NI LabWindows™/CVI™
    2010, 2012, 2013, 2014
    NI Vision Development Module .NET Support
    NI Vision Development Module 2013 SP1 was the last version to release updated support for the .NET Framework 2.0, .NET Framework 3.5, and .NET language integration into Visual Studio 2005 and Visual Studio 2008. Visual Studio 2010 and later are not supported.
    New versions of NI Vision Development Module will not provide new .NET feature support or development. It is recommended that you begin new development in other supported development environments.
    This release of the NI Vision Development Module includes the following new features:
    • New Vision FPGA VIs for performing common image processing and analysis tasks on an FPGA target. These VIs require the LabVIEW FPGA Module 2014.
    • Support for the NI CVS-1459RT and NI cRIO-903x
    • Support for LabVIEW 2014 (32- and 64-bit)
    • New IMAQ Read Barcode 2 VI, which automatically locates and reads 1D barcodes in images
    NI Vision Assistant includes the following new features:
    • New Vision FPGA steps for performing common image processing and analysis tasks on an FPGA target. You can migrate the FPGA steps to LabVIEW. Requires the LabVIEW FPGA Module 2014.
    • Updated Barcode Reader step, which automatically locates and reads 1D barcodes in images
    The following list describes issues in previous versions of NI Vision Development Module that are fixed in this update. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of NI Vision Development Module.
    482971Vision functions cause a crash on some real-time targets running older versions of the LabVIEW Real-Time Module.
    481093Passing an empty image to the RT Video Out VI causes a crash on the NI CVS-1459RT, NI cRIO-903x, and NI cDAQ-913x.
    488461Higher refresh rates for full-screen image display are possible on the NI CVS-1459RT, NI cRIO-903x, and NI cDAQ-913x.
    486845The IMAQ Read QR Code VI has a memory leak.
    484281Vision FPGA VIs performing kernel operations on 16-bit images incorrectly cast the resulting pixel output to 8-bit values.
    487647The IMAQ FPGA GrayMorphology Close 9x9 U16x1 VI does not process the U16 data type correctly.
    The following list describes issues in previous versions of NI Vision Assistant that are fixed in patch files that must be downloaded and applied separately. To obtain these files, visit ni.com/info and enter the following Info Code: vision2014f1
    480317Vision Assistant incorrectly uses Bayer decoding VIs in FPGA code generation after switching to a monochrome image.
    479862In the Vision Assistant Filters step, the Smoothing - Low Pass filter allows even kernel sizes. If LabVIEW FPGA code is generated with an even kernel size, an error will occur.
    484413After generating FPGA code from Vision Assistant, the image displayed is the last image processed instead of the image retrieved from a saved buffer.
    486717After generating FPGA code from Vision Assistant, the four-wire handshaking feedback node is not connected in some cases.
    The following list describes issues in previous versions of NI Vision Development Module that are fixed in this release. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of NI Vision Development Module.
    477802Some LabWindows/CVI examples are looking for NIMachineVision.c files at an unknown location.
    380928The IMAQ Edge Tool 3 VI can cause a fatal error in LabVIEW when using a large ROI.
    456495There is a memory leak when using an Optical Character Recognition (OCR/OCV) step inside the Vision Assistant Express VI.
    441410Coordinate System code generated with Vision Assistant returns error -1074396199.
    466853Color Classification training returns does not return normalized class distances in the results table.
    426037Vision examples in LabWindows/CVI 2013 or later fail to compile.
    477375Error 1004 occurs when adding a Vision Assistant Express VI to NI Teststand.
    477936The Image Correction Step returns an error in the Vision Assistant Express VI.
    470581The IMAQ Rotate VI crashes on Windows XP when overlays are set to rotate and transform.
    463438The IMAQ RejectBorder VI removes non-border objects in large images.
    467893Using an image probe on a VI running on LabVIEW Real-Time causes the target to reboot.
    447511SSE3 and SSE4 processor instruction set capabilities are not properly determined at runtime.
    Installation InstructionsInstalling from the LabVIEW Platform DVDs
    If you purchased LabVIEW, you can install all of your LabVIEW products—including the NI Vision Development Module—using the LabVIEW Platform DVDs.
    To request additional LabVIEW Platform DVDs, refer to the National Instruments Web site.
    Installing from the NI Vision Development Module Installation Media
    Complete the following steps to install the NI Vision Development Module from the NI Vision Development Module installation media.
    • Insert the NI Vision Development Module installation media.
    • If you do not have autorun enabled, double-click autorun.exe. If you have autorun enabled, autorun.exe runs automatically.
    • (Optional) Activate NI Vision Development Module when prompted by the installer, or activate at a later time using the NI License Manager.
    When you run an NI Vision application for the first time, it prompts you to activate a license for the product. If you do not activate a valid license, the NI Vision application will run in Evaluation Mode and continue to prompt you to activate a license on each subsequent launch.
    Complete the following steps to activate the NI Vision license through an Internet connection.
    • Run the product you want to license.
    • Click Yes when prompted to interactively activate your product.
    • Ensure that Automatically activate through a secure Internet connection is selected, and click Next.
    • Enter the product serial number, and click Next.
    • Enter your registration information, and click Next.
    Tip: Enter your email address to receive a copy of your activation code for your records.
    Deployment refers to developing an application so that it can be distributed, or deployed, on a different computer than the one on which the application was developed. The NI Vision Development Module provides everything you need to deploy custom NI Vision applications to target computers. The NI Vision Development Module provides the following options:
    • The ability to create NI Vision Run-Time Engine installers, which integrate with the LabVIEW Application Builder, applications built in LabWindows/CVI, or a custom installer.
    • The ability to install the NI Vision Run-Time Engine directly from the NI Vision Development Module installation media.
    • One NI Vision Run-Time License, which allows you to install a custom application on a single machine.
    The NI Vision Development Module installer contains the runtime engine installer for NI Vision. The runtime engine installer is installed at \Run-Time Engine, where is the location to which the NI Vision Development Module is installed. Visit the ni.com to download software upgrades for NI Vision and the NI Vision Run-Time installers.
    Purchasing NI Vision Deployment Licenses
    You must purchase an NI Vision Run-Time License (part number 778044-03) for each target machine onto which you want to install your custom NI Vision application, even if you install the NI Vision Run-Time Engine directly from the NI Vision Development Module installation media. The NI Vision Development Module ships with one runtime license. Contact a National Instruments sales representative or visit ni.com to purchase additional runtime licenses.
    Note: Additional NI Vision Run-Time Licenses do not include installation media. To install additional licenses, use the original NI Vision Development Module installation media and the serial number provided by National Instruments.
    Using the NI Vision Run-Time Engine
    You can call the NI Vision Run-Time Engine installer from the application installer. If you create the application installer with the LabVIEW Application Builder or with LabWindows/CVI, you can direct the installer to call the NI Vision Run-Time Engine installer.
    Refer to the LabVIEW Help for more information about the LabVIEW Application Builder. Refer to the NI LabWindows/CVI Help for more information about building and distributing LabWindows/CVI applications.
    You can also direct a custom application installer to call the NI Vision Run-Time Engine installer. This may be useful if you are creating an installer for applications created in other development environments. Refer to the documentation that came with the installer software to learn how to call executables from the custom installer. If you are using a custom installer, call the NI Vision Run-Time Engine installer at the end of the installation procedure because the installer may require the system to be restarted.
    Unlike in previously released versions of The NI Vision Run-Time Engine, this installer cannot be invoked without an installer dialog prompt. Please contact National Instruments for a revised version which can be invoked silently. The NI Vision Run-Time Engine installer is located at \Run-Time Engine\visionrte.exe, where is the location to which NI Vision is installed, and is the version number of the NI Vision Run-Time Engine installed.
    Distributing LabVIEW Applications
    The NI Vision Run-Time Engine installer does not install LabVIEW VIs. If you use the LabVIEW Application Builder to create an application (EXE) or dynamic link library (DLL), the Application Builder automatically includes the VIs used by the application. If you distribute a VI, you must include all subVIs that comprise the top-level VI. You must include the appropriate LabVIEW Run-Time Engine as part of the installation.
    Refer to the LabVIEW Help for more information about viewing the hierarchy of VIs and for more information about using the LabVIEW Run-Time Engine.
    Distributing LabWindows/CVI Applications
    In addition to including the NI Vision Run-Time Engine with the installer, you must include the appropriate LabWindows/CVI Run-Time Engine. Refer to the NI LabWindows/CVI Help for more information about creating an executable, creating a dynamic link library, and distributing applications.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the NI Vision Development Module.
    National Instruments is aware of the following issues you may encounter while using NI Vision Development Module.
    • On systems where the NI Vision Development Module license is expired or invalidly licensed, built Vision executables and DLLs will return licensing error -1074396157 regardless of whether the Vision Run-Time Engine is properly activated.
    • The standalone NI Vision Run-Time Engine installer EXE cannot be invoked silently. Refer to the Using the NI Vision Run-Time Engine section for more information.
    • Vision FPGA VIs may be broken when opened on one target after being used on another target. You can fix the broken VI by forcing LabVIEW to recompile it by pressing + + Run Button.
    • The following updates and corrections to the IMAQ FPGA Convolute VI documentation:
      • The kernel buffer should be transposed and then converted to a 1D array before being passed to the Convolution Kernel parameter. For example:
        123
        456
        789
        Transpose to:
        147
        258
        369
        Convert to 1D array:
        147258369
      • The VI expects the inverse of the Divider Value input. For example, if the Divider Value is calculated to be 25, take the inverse (1/25 = 0.04) and pass the inverse value to the VI. Refer to the Convolution Kernels topic in the NI Vision Concepts Help for more information.
    • The following updates and corrections to the IMAQ FPGA Binary Morphology VI and IMAQ FPGA Gray Morphology VI documentation:
      • The Structural Element matrix should be transposed and then converted to a 1D array before being passed to the VIs. Refer to the convolution example above for how to transpose and convert the matrix.
      • The VI documentation incorrectly states that "The connected source image for a morphological transformation must have been created with a border capable of supporting the size of the structuring element." The border for the source image is calculated by the VI.
      • For the Erosion and Dilation VI instances, use this formula to calculate the total latency.
        Total Latency = Minimum Latency + (Image Width + 1)((Kernel Size/2) - 0.5) + Kernel Size
      • For the Open and Close VI instances, use this formula to calculate the total latency.
        Total Latency = Minimum Latency + 2*((Image Width+2)((Kernel Size/2) - 0.5) + 3)
    • Vision FPGA Filter VIs with a mask using a 9x9 kernel support image widths up to 2,000 pixels.
    • The IMAQ Edge Detection VI and IMAQ FPGA Edge Detection VI produce different results when using gradient filters.
    • Specifying a negative angle in the IMAQ Learn Pattern 4 VI causes error -1074395249.
    • The AVI2 VIs do not support writing extra data to AVIs.
    • Japanese and Simplified Chinese for text overlays are not supported on NI Linux® Real-Time targets.
    • The IMAQ Read QR Code VI may hang when the QR Code Cell Size has a minimum size of 2 or less. Setting the minimum size to 3 or higher will prevent this issue.
    • The IMAQ Read Data Matrix Barcode 3 VI may hang on some I16 images.
    • Zooming out on a large, 32-bit image in the Image Display in LabVIEW will cause the image to black out. Only the displayed image is affected. The image itself is not modified.
    • To store error statistics on corrected images, you must run the IMAQ Get Calibration Info2 VI before correcting the calibration template image. The Return Error Information input must be set to TRUE.
    • Vision Assistant cannot generate C code if a double-byte character exists in the path to Vision Assistant or in the destination path for the generated code.
    • Some Vision Development Module .NET examples only work if Measurement Studio 8.6 or later is installed.
    • The Visual Basic .NET Label example does not compile.
    • There is no 64-bit Vision API for C or .NET.
    • Installing the Vision Development Module on a Windows Vista 64-bit computer where Visual Studio 2005 has been recently installed causes compatibility warnings.
    • On some systems, the Vision Development Module cannot open two of the installed AVI files, SideCrash2.avi, when running as a 64-bit application.
    Documentation is installed onto your hard drive with the NI Vision Development Module. To view the documentation, select Start»All Programs»National Instruments»Vision»Documentation»NI Vision. The NI Vision Development Module documentation set consists of the following documents:
    • NI Vision Concepts Help—Describes the basic concepts of image analysis, image processing, and machine vision. This document also contains in-depth discussions about imaging functions for advanced users.
    The following sections describe the documents available for each application development environment and where to find example programs.
    NI Vision for LabVIEW Documentation
    • NI Vision for LabVIEW Help—This document contains reference information about NI Vision VIs and details about how to use NI Vision with LabVIEW. It describes how to create machine vision and image processing applications in LabVIEW. It also describes how to create a real-time vision application using NI Vision and the LabVIEW Real-Time Module, and how to use the Vision FPGA VIs with an FPGA target and the LabVIEW FPGA Module. You can access this help in LabVIEW by selecting Help»NI Vision for LabVIEW Help.
    • NI Vision for LabVIEW Examples—Illustrates common applications you can create with NI Vision. In LabVIEW, select Help»Find Examples. Click the Help button in the NI Example Finder to display the NI Example Finder Help. NI Vision examples for LabVIEW are installed to \examples\Vision FPGA, where is the location LabVIEW is installed.
    NI Vision for LabWindows/CVI Documentation
    • NI Vision for LabWindows/CVI User Manual—Describes how to create machine vision and image processing applications in LabWindows/CVI using the NI Vision Development Module.
    • NI Vision for LabWindows/CVI Function Reference Help—Contains reference information about NI Vision for LabWindows/CVI functions.
    • Function panel help within LabWindows/CVI—Allows you to right-click within each Vision function to access help for that function, control, function class, and function library. Function panels are installed at is the location to which LabWindows/CVI is installed.
    • Example programs for specific applications are installed at \Samples\Vision.
    NI Vision Assistant Documentation
    • NI Vision Assistant Tutorial—Describes the Vision Assistant software interface and guides you through creating example image processing and machine vision applications.
    • NI Vision Assistant Help—Contains descriptions of Vision Assistant features and functions and provides instructions for using them. In Vision Assistant, select Help»Online Help.
    • NI Classification Training Interface Help—Contains information about how to use the NI Classification Training Interface to classify binary samples. In the NI Classification Training Interface, select Help»Online Help.
    • NI Color Classification Training Interface Help—Contains information about how to use the NI Color Classification Training Interface to classify color samples. In the NI Color Classification Training Interface, select Help»Online Help.
    • NI OCR Training Interface Help—Contains information about how to use the NI OCR Training Interface to learn characters, save character sets, and verify characters by comparing them to a reference character. In the NI OCR Training Interface, select Help»Online Help.
    • NI Texture Training Help—Contains information about how to use the NI Texture Training Interface to train a texture classifier file for use in texture defect detection applications. In the NI Texture Training Interface, select Help»Online Help.
    • NI Calibration Training Help—Contains information about how to use the NI Calibration Training Interface to select and create a calibration for use in machine vision applications. In the NI Calibration Training Interface, select Help»Online Help.
    • NI Vision Template Editor Help—Contains information about how to use the NI Vision Template Editor to learn and edit template images that you can use with pattern matching, geometric matching, and golden template comparison functions. In the NI Vision Template Editor, select Help»Online Help.
    When you install National Instruments software on Microsoft Windows 8.x, you will notice a few additional tiles on the Start screen, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (MAX), and the new NI Launcher.
    Using NI Launcher
    NI Launcher helps you find and launch installed NI products. It provides you with a method of finding NI products similar to the Start menu in previous versions of Microsoft Windows. To use NI Launcher, click the NI Launcher tile on the Start screen. NI Launcher launches the desktop and opens a menu containing a list of NI products. Double-click any NI product to launch it.
    Note  MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8.x. You can launch MAX either from the Start screen or from within NI Launcher.
    Finding All Programs
    NI Vision Development Module Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    NI Vision Development Module will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI Vision Development Module that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2014 National Instruments. All rights reserved.
    GMT+8, 2026-1-30 05:21
