查看: 48997|回复: 51
[NI软件产品] NI Vision Builder for Automated Inspection 2011SP1 Win32Eng 自动检测视觉生成器VBAI2011SP1 LabVIEW2011SP1版适用
    昨天 08:10
  • 签到天数: 3731 天
    发表于 2013-3-8 20:39:44 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    ISO版:
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    ZIP版:
    提取码: 请购买附件下载查看
    请购买附件下载查看
    VBAI2011SP1.txt (340 Bytes, 下载次数: 39, 售价: 10 圆)
    NI Vision Builder for Automated Inspection 2011 Service Pack 1 (SP1) Readme
    January 2012
    This file contains important information about National Instruments Vision Builder for Automated Inspection (Vision Builder AI) software and is organized into the following sections:
    Activation Instructions
    Remote Target Support
    PC-Based Image Acquisition and I/O Support
    Additional Resources
    To configure inspections using Vision Builder AI, the host machine must meet the following requirements:
    MinimumRecommended
    ProcessorPentium 4/M or equivalentCore Duo or equivalent
    Memory512 MB RAM1 GB RAM
    Display1,024×768 resolution video adapter with a 24- or 32-bit display1,280×1,024 resolution video adapter with a 24- or 32-bit display
    Operating System
    Microsoft Windows 7/Vista/XP/Server 2003 R2 (32-bit)/Server 2008 R2
    Browser
    Microsoft Internet Explorer 6.0 or later
    Hard Disk Space
    1 GB
    Complete the following steps to install Vision Builder AI:
    Note: You must be logged in with administrator privileges to install Vision Builder AI.
    • Insert the Vision Builder AI DVD into your DVD-ROM drive. If the DVD does not run automatically, open Windows Explorer, right-click the DVD drive icon, and select AutoPlay.
    • Select Install Vision Builder for Automated Inspection on the National Instruments Vision Builder for Automated Inspection screen.
    • Vision Builder AI prompts you to enter your user information. Select one of the following options:
      • Install this product using the following serial number
      • Install this product for evaluation
      If you choose to enter a serial number, enter the serial number found on your Certificate of Ownership card. Vision Builder AI automatically uses this serial number when you run the NI Activation Wizard.
    • Continue to follow the instructions on the screen.
    If you do not activate a valid license, Vision Builder AI runs in evaluation mode and continues to prompt you to activate a license on each launch.
    The evaluation period is 30 days. At the end of the evaluation period you must activate a Vision Builder AI license to continue using the product.
    Note: While Vision Builder AI is in Evaluation mode, all features are available except Migrate Inspection to LabVIEW.
    Complete the following steps to activate the Vision Builder AI license:
    • Launch Vision Builder AI.
    • Click Yes when prompted to activate Vision Builder AI.
    • Ensure that Automatically activate through a secure Internet connection is selected, and click Next.
    • Enter your serial number, and click Next.
    • Enter your registration information, and click Next.
    • You can enter an email address to receive a copy of the activation code for your records.
    Deployment Policy for Vision Builder AI
    Pursuant to the National Instruments Software License Agreement, Vision Builder AI software is licensed to run on only one machine. Deployed applications that use Vision Builder AI require that Vision Builder AI be installed and licensed on each host machine. Therefore, you must purchase a separate Vision Builder AI license for each host machine. For more information, refer to the enclosed National Instruments Software License Agreement or visit ni.com/legal/license.
    Licensing Options
    Vision Builder AI offers the following licensing options:
    • Vision Builder AI Full-Featured (778649-01)—Allows full access to all Vision Builder AI features, which can be used to configure, benchmark, and deploy inspections. This license does not include the Vision Builder AI Development Toolkit.
    • Vision Builder AI Run-Time (779799-03)—Allows you to deploy existing inspections to a host machine and modify the control values for steps in an inspection. This license does not allow you to add steps to or remove steps from an inspection.
    • Vision Builder AI Development Toolkit (779343-03)—Licenses only the Vision Builder AI Development Toolkit, which allows you to create custom steps for use in any Vision Builder AI application.
    The following list describes the changes and enhancements in Vision Builder AI 2011:
    • NI 177x Smart Camera support. Use the Acquire Image (Smart Camera) step to configure an acquisition and acquire images from any NI 177x Smart Camera.
    • New Max Caliper step. Use the Max Caliper step to obtain precise maximum distance measurements based on contour extraction.
    • Updated calibration features. Vision Builder AI now supports spatial calibrations that model perspective distortion, rectilinear lens distortion, or camera model parameters such as focal length and optical axis position. You can access the NI Calibration Training Interface from the Calibrate Image step or from the Calibration tab on any acquisition step.
    • New C API. Use the C API to control Vision Builder AI from C and C++ development enviroments, such as LabWindows/CVI, or .NET development environments, such as Microsoft Visual Studio 2005 or 2008.
    • Updated Welcome Screen. The Vision Builder AI Welcome screen has been updated. Use the icons to the right of the target list to manage a selected target:
      • Refresh Target List—Refresh the list of available remote target devices.
      • Add Target—Add a new remote target device to the list.
      • Add Simulated Target—Add a simulated remote target device to the list of targets. Use a simulated to develop an inspection for deployment when the actual remote target is not available.
      • Configure Target—Configure the selected remote target device.
    Updates
    The following list describes issues in previous versions of Vision Builder AI that are fixed in this release.
    254175The NI Color Classification Training Interface does not display Japanese class names correctly when browsing samples.
    292846When using the Vision Builder AI API, closing a connection closes the VBAI Communication Server even though the engine is still running.
    310697When editing an existing a Read/Write I/O step while using an NI 177x Smart Camera, changing the edge polarity for an input line after reading some line values resets the edge counter to –1.
    310702When using a Read/Write I/O step with an NI 177x Smart Camera, if Detect Any Edges is selected for an input line only rising edges are counted.
    310968When using a Read/Write I/O step with an NI 177x Smart Camera, edge counter values are not reset in the I/O Test Panel result tree after running the inspection on the remote target.
    311912The NI OCR Training Interface does not support learning multibyte character strings longer than a single character.
    316216When creating a LabVIEW 2010 project, you cannot use shared variables from multiple targets in Vision Builder AI mode.
    316993The method for changing the execution priority for multiple transitions from a state in the state diagram is not documented in the Vision Builder AI Configuration Interface Help.
    317039Overlays are not always displayed correctly when running an inspection in the Vision Builder AI Inspection Interface on multi-core computers.
    320095When using a Read/Write I/O step in an inspection running on an NI Smart Camera, step results are not available in the Vision Builder AI Configuration Interface if you stop the inspection.
    320646It is possible to cause multiple calibrations with the same name to appear in the Vision Builder AI System Resource Manager.
    322298When using the NI Calibration Training Interface to edit a Point Distance or Point Coordinates calibration, the interface does not intuitively support adding a distortion model.
    322395When using the NI Calibration Training Interface you may be prompted to save changes to the calibration when no changes were made.
    323080In Vision Builder 2011 the Run LabVIEW VI step does not initialize output values if the VI has no inputs.
    323732When using the NI Calibration Training Interface the image is not always updated when the user clicks Next to navigate to another step.
    323941Enabling Suggest Value? for the Read QR Code step may set a value of less than 3 for the Min Cell Size, which can increase the processing time required for the step.
    323961If the Vision Builder AI window spans multiple monitors, the Vision Builder AI interface may not fill the entire window.
    323979When using the NI Calibration Training Interface to create a Point Coordinate Calibration, it is possible to specify identical Real-World Coordinates for different points.
    327459When the Create Region of Interest step is configured to use previous measurements, the step returns incorrect results when the previous measurements are invalid.
    327492When the Geometry step is configured to use previous measurements and a previous measurement is not available, the step returns a value of 0 instead of indicating that the measurement is not available.
    327811NI Vision OCR character set files are not installed with Vision Builder AI.
    327855When using the NI Calibration Training Interface to add a distortion model to a Point Coordinates calibration, the Image Selection step does not appear.
    328590Windows clipboard shortcuts do not work in Vision Builder AI steps.
    330199The Modbus TCP server does not start after starting and stopping the server.
    330243The Read Data Matrix step results do not include the raw readable data that appears in the Code Read control on the Basic tab for the step.
    331568Vision Builder AI may overlap some interface utilities, such as the UltraMon Smart Taskbar, when maximized on a secondary monitor.
    331690Editing a Create Region of Interest step that is configured to use a previous measurement causes the step to hang if the previous measurement is invalid or missing.
    332952You cannot specify a previous measurement as the value for the Desired Current Level control in the Acquire Image (Smart Camera) step.
    333000When creating new filter criteria for the Detect Objects step, selecting a sum criteria in the Parameter list can produce an out of memory message and force the Configure Object Criteria dialog box to close.
    333055If you create a shared system variable by modifying an existing local variable, the Set Variable step cannot update the shared system variable.
    You can use Vision Builder AI to remotely configure and control a supported remote target. Vision Builder AI supports the following remote targets:
    • NI 17xx Smart Cameras
    • NI 177x Smart Cameras
    • NI CVS-1450 Series Compact Vision Systems
    • NI EVS-1463RT Embedded Vision Systems
    • NI EVS-1464RT Embedded Vision Systems
    Note: Vision Builder AI 2011 SP1 is the last version of Vision Builder AI to provide support for the NI 1762 Smart Camera, the NI 1764 Smart Camera, and NI CVS-1450 Series Compact Vision Systems. Future versions of Vision Builder AI will not support these devices.
    To use Vision Builder AI with a remote target, you must use Vision Builder AI to configure the remote target. For more information about using Vision Builder AI to configure the remote target, refer to the documentation included with the remote target.
    The following table illustrates when a remote target requires you to install driver software on the development computer.
    Remote Target
    Camera Type
    Requires Driver Software Installed
    on Development Computer
    NI Smart Camera
    No
    IEEE 1394
    No
    GigE Vision
    No
    Camera Link
    Yes
    Note: To acquire images from a Camera Link camera attached to a NI EVS-1463RT device, you must use MAX to associate a camera file with the camera. For information about how to associate a camera file with a Camera Link camera connected to a remote target, visit ni.com/info and enter the info code rtcamerafile.
    Vision Builder AI supports the following image acquisition and I/O devices:
    • National Instruments image acquisition devices
    • IEEE 1394 industrial digital cameras
    • GigE Vision cameras
    • DirectShow-compatible USB cameras
    • IP cameras
    • Digital or analog I/O from NI data acquisition (DAQ) devices
    • Serial devices
    Note: You must install driver software to acquire images from an image acquisition device connected to the development computer.
    National Instruments Image Acquisition Devices
    This version of Vision Builder AI supports the following National Instruments image acquisition devices:
    • NI PCI-1405
    • NI PXI/PCI-1407
    • NI PXI/PCI-1409
    • NI PXI/PCI-1410
    • NI PXI/PCI-1411
    • NI PXI/PCI-1422
    • NI PCI-1424
    • NI PCI-1426
    • NI PCIe-1427
    • NI PXI/PCI-1428
    • NI PCIe-1429
    • NI PCIe-1430
    • NI PCIe-1433
    • NI PXIe-1435
    Note: If you are using an image acquisition device, you must install NI Vision Acquisition Software before you install the image acquisition device. NI Vision Acquisition Software gives you access to Measurement & Automation Explorer (MAX), which is software you can use to configure National Instruments devices.
    IEEE 1394 Cameras, GigE Vision Cameras, DirectShow-Compatible USB Cameras, and IP Cameras
    Vision Builder AI supports IEEE 1394 cameras, GigE Vision cameras, DirectShow-compatible USB cameras, and IP cameras. To acquire an image from one of these camera types when the camera is connected to the host computer, use the Acquire Image (1394, GigE, or USB) step. The Acquire Image (1394, GigE, or USB) step requires NI-IMAQdx, which can be installed from the NI Vision Acquisition Software DVD included with Vision Builder AI. The following table lists the minimum version of NI-IMAQdx required for each camera type:
    Vision Builder AI Camera Support
    Camera Type
    Minimum Required NI-IMAQdx Version
    Supported NI Host Adapters
    IEEE 1394 Cameras
    3.0
    NI PXI/PCI-8252, NI PCI-8254R, NI PCIe-8253, NI PCIe-8255R
    GigE Vision Cameras
    3.0
    NI PCIe-8231, NI PCIe-8235, NI PXIe-8234
    DirectShow-Compatible USB Cameras*
    3.4
    IP Cameras
    3.5
    *Verify that the camera driver supports DirectShow and that the camera driver is installed correctly. For specific information about drivers and camera compatibility, consult your camera manufacturer documentation.
    You must configure an IEEE 1394 camera to use the NI-IMAQdx driver. Complete the following steps to use MAX to configure an IEEE 1394 camera to use the NI-IMAQdx driver.
    • Launch MAX.
    • In the MAX configuration tree, expand Devices and Interfaces to obtain a list of installed devices.
    • Expand NI-IMAQdx Devices to obtain a list of available cameras.
    • Right-click the camera and select Driver»NI-IMAQdx IIDC Digital Camera.
    National Instruments no longer supports Legacy NI-IMAQ for IEEE 1394 Cameras driver software. Installing NI-IMAQdx from the NI Vision Acquisition Software DVD included with Vision Builder AI uninstalls Legacy NI-IMAQ for IEEE 1394 Cameras driver software. If you have an existing inspection that uses the Acquire Image (IEEE 1394) step or you want to use the Acquire Image (IEEE 1394) step to acquire images from an IEEE 1394 camera connected to the host computer, you must download and install Legacy NI-IMAQ for IEEE 1394 Cameras driver software. Visit ni.com/info and enter the info code legacy1394 for information about how to install Legacy NI-IMAQ for IEEE 1394 Cameras driver software.
    Note: The Vision Builder AI software image for the NI CVS-1450 Series Compact Vision System includes all necessary driver software. You do not need to download and install Legacy NI-IMAQ for IEEE 1394 Cameras driver software to configure a CVS-1450 Series Compact Vision System.
    NI Analog and Digital I/O Devices
    This version of Vision Builder AI supports digital and analog I/O from any National Instruments data acquisition (DAQ) device using NI-DAQmx Global Virtual Channels. To support NI DAQ devices, Vision Builder AI requires NI-DAQmx 8.0 or later.
    Serial Communication
    To support serial communication, Vision Builder AI requires NI-VISA 2.6.0 or later, which is included with Vision Builder AI. You can use the serial ports built into the PC or one of the following NI serial interfaces: NI PCI-232/x, NI PXI-8420/x, or NI PXI-8422/x. You do not need to install NI-VISA to use the serial port on a remote target.
    National Instruments is aware of the following issues you may encounter while using Vision Builder AI.
    General
    • Vision Builder AI does not support U16 images.
    • Vision Builder AI behaves unexpectedly or may not display an inspection image if the image is large and your computer is low on available memory.
    • If you configure a step to pass or fail based on pixel distances and subsequently calibrate the image, the step will compare calibrated values against pixel-based limits.
    • When connected to a remote target in the Configuration interface, the TCP Communication Terminal is not updated if you select an Operate»Run Inspection option.
    • When connected to a remote target in the Configuration interface, the Serial Communication Terminal is not updated if you select an Operate»Run Inspection option.
    • Calculator step performance may decrease if the Display Result Image for this State checkbox is enabled.
    • The number of logged images resets if an inspection that contains an Image Logging step is closed and opened.
    • When connected to a remote target, the Configuration interface does not execute the Cleanup state.
    • After connecting to a remote target and starting an inspection in the Vision Builder AI Configuration interface, if you lose communication and reconnect to the target the inspection opens in the Vision Builder AI Inspection interface.
    LabVIEW Project Integration
    (LabVIEW 2010) You can create a new VI in the context of a remote target added in Vision Builder AI Mode. A VI created in this context cannot run or support shared variables. If you try to add a shared variable to the VI, the VI generates an error message indicating that the target does not support shared variables. Always create a VI in the context of My Computer or a remote target added in LabVIEW Real-Time Mode.
    Windows Firewall
    If you are using the Windows Firewall, you may notice the following behavior:
    • Microsoft Windows 7, Windows Vista, Windows Server 2008, Windows Server 2003, or Windows XP with Service Pack 2 (SP2) or later installed
      When you launch Vision Builder AI, a dialog box may prompt you to allow Vision Builder AI to receive information over the network. Depending on your operating system, select Allow access or Unblock this program so that Vision Builder AI can communicate with your remote target.
    • Microsoft Windows XP with Service Pack 1 (SP1) installed
      If the Microsoft Windows XP Internet Connection Firewall (ICF) is enabled, Vision Builder AI cannot discover or configure remote targets unless you disable the ICF. Perform the following steps to disable the Internet Connection Firewall:
      • From your desktop, open Network Connections by selecting Start»Control Panel»Network Connections.
      • Double-click the connection you want to modify.
      • Click Properties.
      • On the Advanced tab, clear the Protect my computer and network by limiting or preventing access to this computer from the Internet checkbox.
    Additional ResourcesHow do I get started?
    Read the NI Vision Builder for Automated Inspection Tutorial, which provides exercises for learning how to perform basic machine vision techniques using Vision Builder AI.
    Where can I find reference information?
    Reference information for Vision Builder AI is available from within Vision Builder AI by clicking the Show Context Help button, or selecting Start»All Programs»National Instruments»Vision Builder AI»Documentation.
    The following documents are provided with Vision Builder AI as online help:
    • NI Vision Concepts Help—Contains basic concepts of image analysis, image processing, and machine vision. This document also contains in-depth discussions about imaging functions for advanced users.
    • NI Vision Builder for Automated Inspection: Configuration Help—Contains information about the Vision Builder AI Configuration interface, managing inspections and images, and creating steps for an inspection.
    • NI Vision Builder for Automated Inspection: Inspection Help—Contains information about using the Vision Builder AI Inspection interface to run inspections.
    • NI Vision Builder for Automated Inspection: ActiveX Component Reference Help—Contains information about the ActiveX objects available to embed Vision Builder AI inspections into ActiveX applications.
    Use the Search tab in the help files to quickly locate specific information. For information about how to use the search functionality, refer to the Using Help»Searching Help topic in the help file.
    The following documents are provides with Vision Builder AI as Adobe PDF documents:
    • Vision Builder for Automated Inspection Tutorial—Describes Vision Builder for Automated Inspection and provides step-by-step instructions for solving common visual inspection tasks, such as inspection, gauging, part presence, guidance, and counting.
    • NI Vision Builder for Automated Inspection Development Toolkit Tutorial—Contains instructions for using LabVIEW to create custom steps for Vision Builder AI.
    Where can I find examples?
    Examples of common Vision Builder AI inspections are installed to the \Examples directory, where is the location to which you installed Vision Builder AI.
    Where else can I go for Vision Builder AI information?
    Visit ni.com/vision and the NI Developer Zone at ni.com/zone for the most up-to-date information about Vision Builder AI.
    © 2002–2012 National Instruments Corporation. All right reserved.
    Members of the National Instruments Alliance Partner Program are business entities independent from National Instruments and have no agency, partnership, or joint-venture relationship with National Instruments.
    For patents covering the National Instruments products, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your DVD, or ni.com/patents.
  • 签到天数: 19 天
    发表于 2016-2-25 10:37:22 | 显示全部楼层 来自:天津市 天津大学教育网
    发表于 2013-6-29 22:28:45 | 显示全部楼层 来自:广东省佛山市 联通
    发表于 2013-8-3 22:53:23 | 显示全部楼层 来自:江苏省苏州市 电信
  • 签到天数: 2 天
    发表于 2014-1-16 23:14:21 | 显示全部楼层 来自:黑龙江省哈尔滨市 电信
  • 签到天数: 2 天
    发表于 2014-1-16 23:14:25 | 显示全部楼层 来自:黑龙江省哈尔滨市 电信
    发表于 2014-2-10 23:26:43 | 显示全部楼层 来自:黑龙江省哈尔滨市 联通
    发表于 2014-2-17 11:22:22 | 显示全部楼层 来自:江苏省扬州市 联通
    发表于 2014-2-23 00:05:28 | 显示全部楼层 来自:陕西省西安市 联通
    发表于 2014-2-26 01:32:29 | 显示全部楼层 来自:广东省深圳市 电信
    发表于 2014-3-2 10:46:58 | 显示全部楼层 来自:湖北省武汉市 联通
    GMT+8, 2025-12-4 07:46
