查看: 31301|回复: 29
[LV工具模块] NI Vision Development Module 2011 SP1 Win32/64Eng 视觉开发模块VDM2011SP1 适用LabVIEW2011SP1
    昨天 08:12
  • 签到天数: 3787 天
    连续签到: 38 天
    发表于 2013-3-8 20:31:05 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    ISO版:
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    ZIP版:
    提取码: 请购买附件下载查看
    请购买附件下载查看
    VDM2011SP1.txt (299 Bytes, 下载次数: 103, 售价: 10 圆)
    NI Vision Development Module 2011 SP1 Readme
    December 2011
    This file contains important information about National Instruments Vision Development Module and is organized into the following sections:
    General Information
    Updates and Improvements
    How to Activate the NI Vision License
    Deploying Vision Applications
    Documentation and Examples
    Refer to the Machine Vision Web site at ni.com/vision for the latest information about the NI Vision Development Module.
    General Information
    Installing this program may remove previous versions of the NI Vision Development Module that are currently installed.
    The NI Vision Development Module 2011 supports LabVIEW 8.6, 2009, 2010, and 2011, Visual Studio 2005 and 2008, and LabWindows™/CVI™ 8.1 or later. The installer specifically allows side-by-side installations of NI Vision for each of the supported versions of LabVIEW, enabling you to use the NI Vision Development Module with multiple versions of LabVIEW. National Instruments recommends that you install LabVIEW, LabVIEW Real-Time, or any other supported development environment, before installing the NI Vision Development Module.
    Note: The NI Vision Development Module overwrites existing NI Vision examples and NI Vision VIs. Move modified examples or VIs that you want to save to another directory before installing the NI Vision Development Module.
    This release of the NI Vision Development Module includes the following new features:
    • Support for the AIM DPM-1-2006 data matrix grading standard
    NI Vision Assistant includes the following additions:
    • Support for NI 177x Smart Cameras
    • Ability to display either the processed image in the main window or display both the original image and the processed image
    • Support for multibyte characters in the OCR Training Interface
    The following list describes issues in previous versions of the NI Vision Development Module that are fixed in this release. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of the NI Vision Development Module.
    326478IMAQ Find Edge crashes if the ROI coordinates are invalid.
    326182IMAQ Read File returns an error (-1074395989) for some PNG files.
    326154The Geometric Pattern Matching VIs do not find matches when the calibration axis is set to Direct.
    325436IMAQ NthOrder Filter runs slower when the horizontal image size is a multiple of 16.
    325090IMAQ Particle Filter 3 takes longer to run on multiple core processors.
    324468IMAQ Flatten Image to String crashes if an image with an empty name is sent as input.
    323426The Vision Assistant Image Correction step causes an access violation in nivissvc.dll after correcting a 16-bit image.
    319627IMAQ Read Data Matrix Barcode 2 does not detect the polarity of some images if Auto-detect is enabled.
    319496IMAQ Learn Distortion Model should also compute perspective calibration.
    316390IMAQ Find Straight Edges 3 crashes with some calibrated images.
    312055The Real-Time display is slow when the image contains a text overlay.
    310081IMAQ Extract removes calibration information.
    308930The Simple Calibration Example does not work as expected.
    307976IMAQ Particle Filter 3 hangs on the NI 17xx Smart Camera.
    306290IMAQ FFT and IMAQ Inverse FFT have memory leaks.
    305086LabVIEW crashes when you try to dispose of multiple calibrated images at the same time.
    303694The LabWindows/CVI API for calibration functions does not match the LabVIEW API.
    303324imaqGetImageInfo and IMAQ Get Image Info do not return units correctly for calibrated images.
    302298IMAQ Set Simple Calibration2 should replace the previous image calibration.
    294691IMAQ Unwrap does not support U16 images for Bi-Linear interpolation.
    288789The Data Matrix reader needs to improve for dotted patterns.
    248646IMAQ Read Image Vision Info causes the NI 17xx Smart Camera to reboot when the template is too large or there is not enough memory.
    247217The Vision Assistant Clamp step returns non-integer values on a binary image.
    232997The IMAQ Fit Contour Ellipse overlay does not respect the start and end angle.
    The development computer must meet the following system requirements to run the NI Vision Development Module:
    MinimumRecommended
    Processor233 MHz Pentium or equivalentPentium 4/M or equivalent
    Memory256 MB RAM512 MB RAM
    Display1,024 × 768 resolution video adapter with a 16-bit display1,024 × 768 resolution video adapter with a 24- or 32-bit display
    Free Hard Disk Space
    1.4 GB
    Operating System
    Windows 7/Vista/XP (32-bit)/Server 2008 R2/Server 2003 R2 (32-bit)
    Browser
    Microsoft Internet Explorer 6.0 or later
    Some National Instruments components require Microsoft Silverlight 4.0. If you use a component that requires Silverlight, a dialog box prompts you to install Silverlight from the Internet. Microsoft Silverlight 4.0 is available from the Microsoft Web site at microsoft.com/silverlight.
    Installation InstructionsInstalling from the LabVIEW 2011 Platform DVDs
    If you purchased LabVIEW 2011, you can install all of your LabVIEW products—including the NI Vision Development Module—using the LabVIEW 2011 Platform DVDs.
    To request additional LabVIEW 2011 Platform DVDs, refer to the National Instruments Web site.
    Installing from the NI Vision Development Module Installation Media
    Complete the following steps to install the NI Vision Development Module from the NI Vision Development Module installation media.
    • Insert the NI Vision Development Module installation media.
    • If you do not have autorun enabled, double-click autorun.exe. If you have autorun enabled, autorun.exe runs automatically.
    • (Optional) Activate NI Vision Development Module when prompted by the installer, or activate at a later time using the NI License Manager.
    When you run an NI Vision application for the first time, it prompts you to activate a license for the product. If you do not activate a valid license, the NI Vision application will run in Evaluation Mode and continue to prompt you to activate a license on each subsequent launch.
    Complete the following steps to activate the NI Vision license through an Internet connection.
    • Run the product you want to license.
    • Click Yes when prompted to interactively activate your product.
    • Ensure that Automatically activate through a secure Internet connection is selected, and click Next.
    • Enter the product serial number, and click Next.
    • Enter your registration information, and click Next.
    Tip: Enter your email address to receive a copy of your activation code for your records.
    Deployment refers to developing an application so that it can be distributed, or deployed, on a different computer than the one on which the application was developed. The NI Vision Development Module provides everything you need to deploy custom NI Vision applications to target computers. The NI Vision Development Module provides the following options:
    • The ability to create NI Vision Run-Time Engine installers, which integrate with the LabVIEW Application Builder, applications built in LabWindows/CVI, or a custom installer.
    • The ability to install the NI Vision Run-Time Engine directly from the Vision Development Module CD.
    • One NI Vision Run-Time License, which allows you to install a custom application on a single machine.
    The NI Vision Development Module installer contains the run-time engine installer for NI Vision. The run-time engine installer is installed at \Run-Time Engine, where is the location to which the NI Vision Development Module is installed. Visit the Drivers and Updates section of ni.com to download software upgrades for NI Vision and the NI Vision Run-Time installers.
    Purchasing NI Vision Deployment Licenses
    You must purchase an NI Vision Run-Time License (part number 778044-03) for each target machine onto which you want to install your custom NI Vision application, even if you install the NI Vision Run-Time Engine directly from the NI Vision Development Module CD. The NI Vision Development Module CD ships with one run-time license. Contact a National Instruments sales representative or visit ni.com to purchase additional run-time licenses.
    Note: Additional NI Vision Run-Time Licenses do not include a CD. To install additional licenses, use the original NI Vision Development Module CD and the serial number provided by National Instruments.
    Using the NI Vision Run-Time Engine
    You can call the NI Vision Run-Time Engine installer from the application installer. If you create the application installer with the LabVIEW Application Builder or with LabWindows/CVI, you can direct the installer to call the NI Vision Run-Time Engine installer.
    Refer to the LabVIEW Help for more information about the LabVIEW Application Builder. Refer to the NI LabWindows/CVI Help for more information about building and distributing LabWindows/CVI applications.
    You can also direct a custom application installer to call the NI Vision Run-Time Engine installer. Refer to the documentation that came with the installer software to learn how to call executables from the custom installer. If you are using a custom installer, call the NI Vision Run-Time Engine installer at the end of the installation procedure because the installer may require the system to be restarted.
    To use the NI Vision Run-Time Engine installer, you must add /qn as a command line argument to the run-time engine installer. For example, enter \Run-Time Engine\vision2011rte.exe /qn to run the NI Vision Run-Time Engine installer, where is the location to which NI Vision is installed.
    Distributing LabVIEW Applications
    The NI Vision Run-Time Engine installer does not install LabVIEW VIs. If you use the LabVIEW Application Builder to create an application (EXE) or dynamic link library (DLL), the Application Builder automatically includes the VIs used by the application. If you distribute a VI, you must include all subVIs that comprise the top-level VI. You must include the appropriate LabVIEW Run-Time Engine as part of the installation.
    Refer to the LabVIEW Help for more information about viewing the hierarchy of VIs and for more information about using the LabVIEW Run-Time Engine.
    Distributing LabWindows/CVI Applications
    In addition to including the NI Vision Run-Time Engine with the installer, you must include the appropriate LabWindows/CVI Run-Time Engine. Refer to the NI LabWindows/CVI Help for more information about creating an executable, creating a dynamic link library, and distributing applications.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the NI Vision Development Module.
    • Simple calibration is not disposed of properly when you learn simple calibration on an image repeatedly or in a loop. You must remove the calibration information using the IMAQ Remove Vision Info 2 VI to remove the existing simple calibration before learning a new simple calibration by running IMAQ Set Simple Calibration2 VI.
    • If you want to learn simple calibration on images that already have perspective or microplane calibration, you must remove the calibration information using the IMAQ Remove Vision Info 2 VI, and then run the IMAQ Set Simple Calibration2 VI to learn simple calibration.
    • To store error statistics on corrected images, you must run the IMAQ Get Calibration Info2 VI before correcting the calibration template image. The Return Error Information input must be set to TRUE.
    • The IMAQ Get Calibration Info2 VI returns 0 for the X Step and Y Step subparameters of the Grid Descriptor output if the calibration template image was not learned using simple calibration.
    • Vision Assistant cannot generate C code if a double-byte character exists in the path to Vision Assistant or in the destination path for the generated code.
    • Some Vision Development Module .NET examples only work if Measurement Studio 8.6 is installed.
    • The Visual Basic .NET Label example does not compile.
    • There is no 64-bit Vision API for C or .NET.
    • Installing the Vision Development Module on a Windows Vista 64-bit computer where Visual Studio 2005 has been recently installed causes compatibility warnings.
    • The Vision Development Module cannot open two of the installed AVI files, SideCrash2.avi, when running as a 64-bit application.
    • AVI functionality requires Microsoft DirectX 8.1 or later.
    • On Windows XP computers with Service Pack 2 installed, NI Vision does not support reading AVI files located in the Local Settings folder, or any subfolders of this folder, when the AVI file uses any of the following compression filters:
      • Indeo® Video 5.10 Compression Filter
      • Intel Indeo® Video R3.2
      • Intel Indeo® Video 4.5
      • Indeo® Video 5.10
      Copying the AVI file to another folder resolves this problem.
    • Using NI Vision with LabWindows/CVI on a machine that does not support the MMX instruction set may cause an Illegal Operation exception to occur within the LabWindows/CVI environment. This error occurs when DirectX checks for the availability of the MMX instruction set on the machine.
    • The Vision Assistant Express VI image caching feature is available in LabVIEW 8.2 or later.
    The NI Vision Development Module documentation set consists of the following manuals and help files:
    • NI Vision Concepts Help—Describes the basic concepts of image analysis, image processing, and machine vision. This document also contains in-depth discussions about imaging functions for advanced users.
    The following sections describe the documents available for each application development environment and where to find example programs.
    NI Vision for LabVIEW Documentation
    • NI Vision for LabVIEW Help—Describes how to create machine vision and image processing applications in LabVIEW using the NI Vision Development Module. It also describes how to create a real-time vision application using NI Vision and the LabVIEW Real-Time Module.
      This document also contains reference information about NI Vision VIs and details about how to use NI Vision with LabVIEW. In LabVIEW, select Help»NI Vision for LabVIEW Help.
      Note: The NI Vision for LabVIEW Help combines the NI Vision for LabVIEW User Manual and NI Vision for LabVIEW VI Reference Help from previous releases into one document.
    • NI Example Finder—Illustrates common applications you can create with NI Vision. In LabVIEW, select Help»Find Examples. Click the Help button in the NI Example Finder to display the NI Example Finder Help.
    NI Vision for LabWindows/CVI Documentation
    • NI Vision for LabWindows/CVI User Manual—Describes how to create machine vision and image processing applications in LabWindows/CVI using the NI Vision Development Module.
    • NI Vision for LabWindows/CVI Function Reference Help—Contains reference information about NI Vision for LabWindows/CVI functions.
    • Function panel help within LabWindows/CVI—Allows you to right-click within each Vision function to access help for that function, control, function class, and function library. Function panels are installed at is the location to which LabWindows/CVI is installed.
    • Example programs for specific applications are installed at \Samples\Vision.
    NI Vision for .NET Documentation
    The NI Vision .NET documentation merges into the NI Measurement Studio Help. The NI Measurement Studio Help integrates into the Visual Studio Combined Help Collection under the Measurement Studio node in the Table of Contents. In order for links from Measurement Studio help topics to .NET Framework help topics to work, you must install the product documentation for Visual Studio, which installs the MSDN Library. This requires a secondary installation during the Visual Studio installation process.
    The NI Measurement Studio Help is in the Microsoft Help 2.0 format and requires a Microsoft Help 2.0 viewer to be displayed. A Microsoft Help 2.0 viewer is installed with both Microsoft Visual Studio and the Microsoft .NET Framework SDK. The SDK is freely available from MSDN at http://www.microsoft.com/downloads. If you do not have either of these products, you will need a standalone Microsoft Help 2.0 viewer to display the documentation. Some Help 2.0 viewers are available for download, such as Helpware's H2Viewer.
    • NI Measurement Studio Help—Contains reference information about NI Vision for .NET objects. Describes how to create machine vision and image processing applications in Visual Basic .NET and C# using the NI Vision Development Module. You can launch the NI Measurement Studio Help in the following ways:
      If you have Measurement Studio installed:
      • From the Windows Start menu, select Start»All Programs»National Instruments»»Measurement Studio Documentation, where is the location to which Measurement Studio is installed. The help launches in a stand-alone help viewer.
      • From Visual Studio, select Measurement Studio»NI Measurement Studio Help.
      If you do not have Measurement Studio installed:
      • From Visual Studio, select Help»Contents to view the Visual Studio table of contents. The NI Measurement Studio Help is listed in the table of contents.
    • Example programs for specific applications are installed at is the location to which NI Vision is installed.
    NI Vision Assistant Documentation
    • NI Vision Assistant Tutorial—Describes the Vision Assistant software interface and guides you through creating example image processing and machine vision applications.
    • NI Vision Assistant Help—Contains descriptions of Vision Assistant features and functions and provides instructions for using them. In Vision Assistant, select Help»Online Help.
    • NI Classification Training Interface Help—Contains information about how to use the NI Classification Training Interface to classify binary samples. In the NI Classification Training Interface, select Help»Online Help.
    • NI Color Classification Training Interface Help—Contains information about how to use the NI Color Classification Training Interface to classify color samples. In the NI Color Classification Training Interface, select Help»Online Help.
    • NI OCR Training Interface Help—Contains information about how to use the NI OCR Training Interface to learn characters, save character sets, and verify characters by comparing them to a reference character. In the NI OCR Training Interface, select Help»Online Help.
    • NI Texture Training Help—Contains information about how to use the NI Texture Training Interface to train a texture classifier file for use in texture defect detection applications. In the NI Texture Training Interface, select Help»Online Help.
    • NI Calibration Training Help—Contains information about how to use the NI Calibration Training Interface to select and create a calibration for use in machine vision applications. In the NI Calibration Training Interface, select Help»Online Help.
    • NI Vision Template Editor Help—Contains information about how to use the NI Vision Template Editor to learn and edit template images that you can use with pattern matching, geometric matching, and golden template comparison functions. In the NI Vision Template Editor, select Help»Online Help.
    © 2011 National Instruments Corporation. All rights reserved.
    Additional Licenses
    This product contains third-party software. Refer to the NI Vision Development Module 2011 Free and Open Source Software Notices for information about applicable notices and licenses. You can access the NI Vision Development Module 2011 Free and Open Source Software Notices by navigating to \Licenses, where is the location to which you installed the NI Vision Development Module, and selecting VDM2011_FOSS_notices.pdf.
    昨天 08:16
  • 签到天数: 1027 天
    [LV.10]1000FPS
    发表于 2018-11-21 17:31:39 | 显示全部楼层 来自:广东省东莞市 电信
    NI Vision Development Module 2011SP1 for LabVIEW2010SP1 Win32/64Eng VDM2011SP1视觉开发包适用32/64位LV2011SP1版下载
    发表于 2020-7-20 17:39:45 | 显示全部楼层 来自:北京市 北京电信互联网数据中心
    能免费给一个不,好难受啊。
    发表于 2013-7-2 09:59:21 | 显示全部楼层 来自:北京市 中电华通通信有限公司
    看帖看完了至少要顶一下,向楼主无私奉献致敬!感谢石鑫华视觉http://visionbbs.com的培训资料!
    发表于 2013-8-9 23:16:14 | 显示全部楼层 来自:广东省深圳市 中移铁通
    看卡卡看看看
    发表于 2013-8-24 16:57:44 | 显示全部楼层 来自:法国
    非常感谢!
  • 签到天数: 148 天
    发表于 2013-9-26 10:12:12 | 显示全部楼层 来自:浙江省温州市 电信
    支持石鑫华视觉http://shixinhua.com,支持机器视觉论坛!http://visionbbs.com
    发表于 2013-12-23 21:12:50 | 显示全部楼层 来自:云南省昆明市 电信
    谢谢分享啊啊啊啊啊
  • 签到天数: 2 天
    发表于 2014-1-16 23:13:02 | 显示全部楼层 来自:黑龙江省哈尔滨市 电信
    谢谢,查看附件
    发表于 2014-2-10 23:27:43 | 显示全部楼层 来自:黑龙江省哈尔滨市 联通
    谢谢分享~~~~~~~~~~
    发表于 2014-3-1 21:28:06 | 显示全部楼层 来自:福建省泉州市南安市 电信
    感谢楼主分享,
  • 签到天数: 8 天
    发表于 2014-3-28 15:41:46 | 显示全部楼层 来自:江西省南昌市 电信
    谢谢楼主,好资源
    GMT+8, 2026-1-30 04:01
