TA的每日心情 | 衰 1 小时前 |
签到天数: 3829 天 连续签到: 22 天 [LV.Master]2000FPS
NI Vision Development Module 2009 Win32/64Eng 视觉开发模块VDM2009版 适用LabVIEW2009
NI视觉开发模块VDM2009图像处理工具包。LabVIEW2009开始有64位版本,所以VDM2009也是第一个支持64位LabVIEW的视觉开发包。
石鑫华视觉珍藏版NI官方下载地址与百度网盘下载:
ZIP版:
链接: 请注册视觉论坛会员登录后购买附件下载查看
提取码: 请购买附件下载查看
ISO版:
提取码: 请购买附件下载查看
NI官方下载地址(不一定有效或无法完成下载):
请购买附件下载查看
VDM2009.txt
(314 Bytes, 下载次数: 34, 售价: 10 圆)
NI Vision Development Module 2009 Readme
June 2009
This file contains important information about National Instruments Vision Development Module and is organized into the following sections:
General Information
How to Activate the NI Vision License
Deploying Vision Applications
Documentation and Examples
Refer to the Machine Vision Web site at ni.com/vision for the latest information about the NI Vision Development Module.
General Information
Installing this program may remove previous versions of the NI Vision Development Module that are currently installed.
NI Vision 2009 supports LabVIEW 8.2, 8.5, 8.6, and 2009, Visual Studio 2005 and 2008, and LabWindows™/CVI™ 7.0 or later. The installer specifically allows side-by-side installations of NI Vision for each of the supported versions of LabVIEW, enabling you to use the NI Vision Development Module with multiple versions of LabVIEW. National Instruments recommends that you install LabVIEW, or any other supported development environment, before installing the NI Vision Development Module.
Note: The NI Vision Development Module 2009 overwrites existing NI Vision examples and NI Vision VIs. Move modified examples or VIs that you want to save to another directory before installing the NI Vision Development Module 2009.
This release of the NI Vision Development Module includes the following new features:
- Native Vision .NET API
- Vision API for LabVIEW in 64-bit operating systems. The NI Vision Development Module 2009 supports Windows Vista 64-bit.
- Support for LabVIEW 2009 (32-bit)
- Support for LabVIEW 2009 (64-bit)
- Support for color classification
- Enhanced geometric pattern matching algorithm
- Optimized the following algorithms to improve performance on multi-core processors:
- Particle Analysis
- Particle Analysis Report
- Label
| - Convex Hull
- Particle Filter
- Optimized the following algorithms to improve performance on DSPs:
- Absolute Difference
- Add
- Divide
- Modulo
- Multiply
- Subtract
| - MulDiv
- And
- Or
- Xor
- Logical Difference
- Morphology
| - Threshold
- Multithreshold
- Auto Binary Threshold
- Convolute
- Nth Order
The development computer must meet the following system requirements to run the NI Vision Development Module:
| | Minimum | Recommended | | Processor | 233 MHz Pentium or equivalent | Pentium 4/M or equivalent | | Memory | 256 MB RAM | 512 MB RAM | | Display | 1,024 × 768 resolution video adapter with a 16-bit display | 1,024 × 768 resolution video adapter with a 24- or 32-bit display | | Free Hard Disk Space | 700 MB | 1 GB | | Operating System | Microsoft Windows Vista (32-bit and 64-bit versions)/XP/2000 | | Browser | Microsoft Internet Explorer 5.0 or later | How to Activate the NI Vision License
When you run an NI Vision application for the first time, it prompts you to activate a license for the product. If you do not activate a valid license, the NI Vision application will run in Evaluation Mode and continue to prompt you to activate a license on each subsequent launch.
Complete the following steps to activate the NI Vision license through an Internet connection.
- Run the product you want to license.
- Click Yes when prompted to interactively activate your product.
- Ensure that Automatically activate through a secure Internet connection is selected, and click Next.
- Enter the product serial number, and click Next.
- Enter your registration information, and click Next.
Tip: Enter your email address to receive a copy of your activation code for your records.
Deployment refers to developing an application so that it can be distributed, or deployed, on a different computer than the one on which the application was developed. The NI Vision Development Module provides everything you need to deploy custom NI Vision applications to target computers. The NI Vision Development Module provides the following options:
- The ability to create NI Vision Run-Time Engine installers, which integrate with the LabVIEW Application Builder, applications built in LabWindows/CVI, or a custom installer.
- The ability to install the NI Vision Run-Time Engine directly from the Vision Development Module CD.
- One NI Vision Run-Time License, which allows you to install a custom application on a single machine.
The NI Vision Development Module installer contains the run-time engine installer for NI Vision. The run-time engine installer is installed at \Run-Time Engine, where is the location to which the NI Vision Development Module is installed. Visit the Drivers and Updates section of ni.com to download software upgrades for NI Vision and the NI Vision Run-Time installers.
Purchasing NI Vision Deployment Licenses
You must purchase an NI Vision Run-Time License (part number 778044-03) for each target machine onto which you want to install your custom NI Vision application, even if you install the NI Vision Run-Time Engine directly from the NI Vision Development Module CD. The NI Vision Development Module CD ships with one run-time license. Contact a National Instruments sales representative or visit ni.com to purchase additional run-time licenses.
Note: Additional NI Vision Run-Time Licenses do not include a CD. To install additional licenses, use the original NI Vision Development Module CD and the serial number provided by National Instruments.
Using the NI Vision Run-Time Engine
You can call the NI Vision Run-Time Engine installer from the application installer. If you create the application installer with the LabVIEW Application Builder or with LabWindows/CVI, you can direct the installer to call the NI Vision Run-Time Engine installer.
Refer to the LabVIEW Help for more information about the LabVIEW Application Builder. Refer to the NI LabWindows/CVI Help for more information about building and distributing LabWindows/CVI applications.
You can also direct a custom application installer to call the NI Vision Run-Time Engine installer. Refer to the documentation that came with the installer software to learn how to call executables from the custom installer. If you are using a custom installer, call the NI Vision Run-Time Engine installer at the end of the installation procedure because the installer may require the system to be restarted.
To use the NI Vision Run-Time Engine installer, you must add /qn as a command line argument to the run-time engine installer. For example, enter \Run-Time Engine\vision2009rte.exe /qn to run the NI Vision Run-Time Engine installer, where is the location to which NI Vision is installed.
Distributing LabVIEW Applications
The NI Vision Run-Time Engine installer does not install LabVIEW VIs. If you use the LabVIEW Application Builder to create an application (EXE) or dynamic link library (DLL), the Application Builder automatically includes the VIs used by the application. If you distribute a VI, you must include all subVIs that comprise the top-level VI. You must include the appropriate LabVIEW Run-Time Engine as part of the installation.
Refer to the LabVIEW Help for more information about viewing the hierarchy of VIs and for more information about using the LabVIEW Run-Time Engine.
Distributing LabWindows/CVI Applications
In addition to including the NI Vision Run-Time Engine with the installer, you must include the appropriate LabWindows/CVI Run-Time Engine. Refer to the NI LabWindows/CVI Help for more information about creating an executable, creating a dynamic link library, and distributing applications.
Known Issues- There is no 64-bit Vision API for C or .NET in this release.
- Compatibilty warnings will pop up when installing the Vision Development Module on a Windows Vista 64-bit computer where Visual Studio 2005 has been recently installed.
- The Vision Development Module cannot open two of the installed AVI files, SideCrash1.avi and SideCrash2.avi, when running as a 64-bit application.
- AVI functionality requires Microsoft DirectX 8.1 or later.
- On Windows XP computers with Service Pack 2 installed, NI Vision does not support reading AVI files located in the Local Settings folder, or any subfolders of this folder, when the AVI file uses any of the following compression filters:
- Indeo® Video 5.10 Compression Filter
- Intel Indeo® Video R3.2
- Intel Indeo® Video 4.5
- Indeo® Video 5.10
Copying the AVI file to another folder resolves this problem. - Viewing the online help files requires Microsoft Internet Explorer 5 or later.
- Using NI Vision with LabWindows/CVI on a machine that does not support the MMX instruction set may cause an Illegal Operation exception to occur within the LabWindows/CVI environment. This error occurs when DirectX checks for the availability of the MMX instruction set on the machine.
- The Vision Assistant Express VI image caching feature is available in LabVIEW 8.2 or later.
The NI Vision Development Module documentation set consists of the following manuals and help files:
- NI Vision Concepts Help—Describes the basic concepts of image analysis, image processing, and machine vision. This document also contains in-depth discussions about imaging functions for advanced users.
The following sections describe the documents available for each application development environment and where to find example programs.
NI Vision for LabVIEW Documentation- NI Vision for LabVIEW Help—Describes how to create machine vision and image processing applications in LabVIEW using the NI Vision Development Module. It also describes how to create a real-time vision application using NI Vision and the LabVIEW Real-Time Module.This document also contains reference information about NI Vision VIs and details about how to use NI Vision with LabVIEW. In LabVIEW, select Help»NI Vision for LabVIEW Help.
Note: The NI Vision for LabVIEW Help combines the NI Vision for LabVIEW User Manual and NI Vision for LabVIEW VI Reference Help from previous releases into one document. - NI Example Finder—Illustrates common applications you can create with NI Vision. In LabVIEW, select Help»Find Examples. Click the Help button in the NI Example Finder to display the NI Example Finder Help.
NI Vision for LabWindows/CVI Documentation- NI Vision for LabWindows/CVI User Manual—Describes how to create machine vision and image processing applications in LabWindows/CVI using the NI Vision Development Module.
- NI Vision for LabWindows/CVI Function Reference Help—Contains reference information about NI Vision for LabWindows/CVI functions.
- Function panel help within LabWindows/CVI—Allows you to right-click within each Vision function to access help for that function, control, function class, and function library. Function panels are installed at \bin\NIVision.lfp, where is the location to which LabWindows/CVI is installed.
- Example programs for specific applications are installed at \Samples\Vision.
NI Vision for .NET Documentation
The NI Vision .NET documentation merges into the NI Measurement Studio Help. The NI Measurement Studio Help integrates into the Visual Studio Combined Help Collection under the Measurement Studio node in the Table of Contents. In order for links from Measurement Studio help topics to .NET Framework help topics to work, you must install the product documentation for Visual Studio, which installs the MSDN Library. This requires a secondary installation during the Visual Studio installation process.
The NI Measurement Studio Help is in the Microsoft Help 2.0 format and requires a Microsoft Help 2.0 viewer to be displayed. A Microsoft Help 2.0 viewer is installed with both Microsoft Visual Studio and the Microsoft .NET Framework SDK. The SDK is freely available from MSDN at http://www.microsoft.com/downloads. If you do not have either of these products, you will need a standalone Microsoft Help 2.0 viewer to display the documentation. Some Help 2.0 viewers are available for download, such as Helpware's H2Viewer.
- NI Measurement Studio Help—Contains reference information about NI Vision for .NET objects. Describes how to create machine vision and image processing applications in Visual Basic .NET and C# using the NI Vision Development Module. You can launch the NI Measurement Studio Help in the following ways:If you have Measurement Studio installed:
- From the Windows Start menu, select Start»All Programs»National Instruments»»Measurement Studio Documentation, where is the location to which Measurement Studio is installed. The help launches in a stand-alone help viewer.
- From Visual Studio, select Measurement Studio»NI Measurement Studio Help.
If you do not have Measurement Studio installed:
- From Visual Studio, select Help»Contents to view the Visual Studio table of contents. The NI Measurement Studio Help is listed in the table of contents.
- Example programs for specific applications are installed at \Examples\dotNET, where is the location to which NI Vision is installed.
NI Vision Assistant Documentation- NI Vision Assistant Tutorial—Describes the Vision Assistant software interface and guides you through creating example image processing and machine vision applications.
- NI Vision Assistant Help—Contains descriptions of Vision Assistant features and functions and provides instructions for using them. In Vision Assistant, select Help»Online Help.
- NI Classification Training Interface Help—Contains information about how to use the NI Classification Training Interface to classify binary samples. In the NI Classification Training Interface, select Help»Online Help.
- NI Color Classification Training Interface Help—Contains information about how to use the NI Color Classification Training Interface to classify color samples. In the NI Color Classification Training Interface, select Help»Online Help.
- NI OCR Training Interface Help—Contains information about how to use the NI OCR Training Interface to learn characters, save character sets, and verify characters by comparing them to a reference character. In the NI OCR Training Interface, select Help»Online Help.
- NI Vision Template Editor Help—Contains information about how to use the NI Vision Template Editor to learn and edit template images that you can use with pattern matching, geometric matching, and golden template comparison functions. In the NI Vision Template Editor, select Help»Online Help.
© 2009 National Instruments Corporation. All rights reserved.
For patents covering the National Instruments products, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your CD, or ni.com/patents. |
