查看: 15334|回复: 10
[NI软件产品] NI Vision Builder for Automated Inspection 2009SP1 Win32Eng 自动化检测视觉生成器VBAI2009SP1 LV2009SP1
    12 小时前
  • 签到天数: 3740 天
    连续签到: 67 天
    发表于 2013-3-7 20:33:59 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    ZIP版:
    ISO版:
    请注册视觉论坛会员登录后购买附件下载查看
    NI官方下载地址(不一定有效或无法完成下载):
    请购买附件下载查看
    VBAI2009SP1.txt (339 Bytes, 下载次数: 59, 售价: 10 圆)
    NI Vision Builder for Automated Inspection 2009 Service Pack 1 (SP1) Readme
    January 2010
    This file contains important information about National Instruments Vision Builder for Automated Inspection (Vision Builder AI) software and is organized into the following sections:
    Activation Instructions
    Device Support
    Additional Resources
    To configure inspections using Vision Builder AI, the host machine must meet the following requirements:
    MinimumRecommended
    ProcessorPentium 4/M or equivalentCore Duo or equivalent
    Memory512 MB RAM1 GB RAM
    Display1,024×768 resolution video adapter with a 24- or 32-bit display1,280×1,024 resolution video adapter with a 24- or 32-bit display
    Operating System
    Microsoft Windows 7/Vista/XP/2000
    Browser
    Microsoft Internet Explorer 5.0 or later
    Hard Disk Space
    700 MB
    Complete the following steps to install Vision Builder AI:
    Note: You must be logged in with administrator privileges to install Vision Builder AI.
    • Insert the Vision Builder AI DVD into your DVD-ROM drive. If the DVD does not run automatically, open Windows Explorer, right-click the DVD drive icon, and select AutoPlay.
    • Select Install Vision Builder for Automated Inspection on the National Instruments Vision Builder for Automated Inspection screen.
    • Vision Builder AI prompts you to enter your user information. Select one of the following options:
      • Install this product using the following serial number
      • Install this product for evaluation
      If you choose to enter a serial number, enter the serial number found on your Certificate of Ownership card. Vision Builder AI automatically uses this serial number when you run the NI Activation Wizard.
    • Continue to follow the instructions on the screen.
    If you did not activate Vision Builder AI during the installation process, when you run a Vision Builder AI application for the first time, it prompts you to activate a license for the product. If you do not activate a valid license, Vision Builder AI runs in Evaluation mode and continues to prompt you to activate a license on each subsequent launch.
    The evaluation period is 30 days. At the end of the evaluation period you must activate a Vision Builder AI license to continue using the product.
    Note: While Vision Builder AI is in Evaluation mode, all features are available except Migrate Inspection to LabVIEW.
    Vision Builder AI offers the following licensing options:
    • Vision Builder AI Full-Featured (778649-01)—Allows full access to all Vision Builder AI features, which can be used to configure, benchmark, and deploy inspections. This license does not include the Vision Builder AI Development Toolkit.
    • Vision Builder AI Run-Time (779799-03)—Allows you to deploy existing inspections to a host machine and modify the control values for steps in an inspection. This license does not allow you to add steps to or remove steps from an inspection.
    • Vision Builder AI Development Toolkit (779343-03)—Licenses only the Vision Builder AI Development Toolkit, which allows you to create custom steps for use in any Vision Builder AI application.
    Complete the following steps to activate the Vision Builder AI license:
    • Launch Vision Builder AI.
    • Click Yes when prompted to activate Vision Builder AI.
    • Ensure that Automatically activate through a secure Internet connection is selected, and click Next.
    • Enter your serial number, and click Next.
    • Enter your registration information, and click Next.
    • You can enter an email address to receive a copy of the activation code for your records.
    Deployment Policy for Vision Builder AI
    Pursuant to the National Instruments Software License Agreement, Vision Builder AI software is licensed to run on only one machine. Deployed applications that use Vision Builder AI require that Vision Builder AI be installed and licensed on each host machine. Therefore, you must purchase a separate Vision Builder AI license for each host machine. For more information, refer to the enclosed National Instruments Software License Agreement or visit ni.com/legal/license.
    The following list describes the changes and enhancements in this release of Vision Builder AI:
    • New Read/Write Camera Attributes step—The Read/Write Camera Attributes step allows you to read camera attributes or write camera attributes, including I/O lines for GigE Vision cameras and registers for IEEE-1394 cameras, without using an acquisition step.
    • New Read/Write Variables to INI File step—The Read/Write Variables to INI File step allows you to easily restore variables to a known state. Use the step to interact with an .ini file that contains inspection variables, user-defined system variables, EtherNet/IP assembly data, or Modbus table data.
    • New support for multiple instances of Vision Builder AI—Launch multiple instances of Vision Builder AI to run multiple inspections in parallel or simultaneously connect to multiple remote targets.
    • New support for IP cameras—The Acquire Image (1394, GigE, or USB) and Read/Write Camera Attributes steps support IP cameras.
    • Updated Run LabVIEW VI step and Configure Inspection Interface tool—The Run LabVIEW VI step and Configure Inspection Interface tool now support VIs created in LabVIEW 8.5 or earlier, and VIs created in LabVIEW 8.6 or later that are saved for LabVIEW 8.5 using File»Save for Previous Version.
    • Updated support for previous measurements—The following steps now support using previous measurements:
      • Find Edges
      • Find Straight Edge
      • Find Circular Edge
      • Advanced Straight Edge
      • Generate Pulse (NI-IMAQ I/O)
    Updates
    The following list describes issues in previous versions of Vision Builder AI that are fixed in this release.
    35757Vision Builder AI will not open if the Vision Builder AI ActiveX component is running as part of an inspection that is running on the host machine.
    152201The Serial I/O step returns any received characters if the step times out even though the characters do not include an end of line character.
    172828It is impossible to connect to multiple TCP slave devices that have the same IP address but different ports.
    172829The TCP I/O step returns any received characters if the step times out; the received characters are not available for subsequent steps.
    178528Creating a new EtherNet/IP device and defining default tags after opening an inspection that contains an EtherNet/IP step while no EtherNet/IP device is defined can create duplicate tags in the EtherNet/IP step.
    181217When creating a calibration, existing points do not appear in the points list and appear incorrectly when selected in the image.
    181534The Run LabVIEW VI step and steps created with the Vision Builder AI Development Toolkit do not to work properly in debug mode if LabVIEW is not installed to the default folder.
    182046The value of the constant cannot be edited when editing the Vision Assistant Operator step.
    182049The mapping method for 16-bit images in the Image Display options reverts to Full Dynamic when switching to the Vision Builder AI Inspection interface.
    184776In the Attributes tab of the Acquire Image (1394, GigE, or USB) step, it is sometimes impossible to select attributes from a specific area of the attributes tree.
    186179Some legacy ActiveX examples cannot run unless the user is logged in as an administrator.
    186766When editing the Match Pattern step on a remote target immediately after running the inspection once, the step displays the ROI and pattern from the previous template after another template is selected.
    187137Using the snap or grab buttons to acquire an image from a remote target after selecting a video mode in the Acquire Image (IEEE 1394) step can reset the video mode to the default video mode.
    187409Entering a network path that contains spaces when creating a new device in the Communication Device Manager causes communication errors.
    187595Acquire Image (IEEE 1394) steps select the default camera in an inspection that uses multiple Acquire Image (IEEE 1394) steps to acquire images from multiple cameras connected to a remote target after saving and reloading the inspection or when editing each Acquire Image (IEEE 1394)step.
    189285Vision Builder AI doesn't use initial values specified in a custom inspection interface.
    192159In the EtherNet/IP Adapter step, if editing the address of a user register repositions the user register in the User Register table, the user register appears to have the value of the user register that previously occupied its position in the User Register table.
    192353In the Calculator Step - Edit Inputs/Outputs window, previous measurements used in the step are not selected in the Input Measurements tree if the step producing the measurements is renamed.
    192685In the Vision Assistant Threshold step, it is impossible to select a Threshold Type if it does not appear as one of the first two listed types.
    193310Editing an input measurement control that uses a variable value in a Calculator step disconnects the input measurement control.
    193483Reading an I/O line with the Read/Write (NI-IMAQ I/O) step is slower in Vision Builder AI 2009.
    193730When using the Calibration Training Wizard to configure a grid calibration, it is not possible to draw an ROI to update the kernel size.
    193983A Delay step in the Inspection Setup state does not wait for the specified period of time after the first iteration of an inspection when Vision Builder AI is configured to run the Inspection Setup and Inspection Cleanup states each time the inspection is started or stopped.
    194218Vision Builder AI does not reset the Inspection Iteration Counter built-in system variable before the first iteration of an inspection when Run Inspection Multiple Times is selected.
    194224After copying a state, a copied step that uses an ROI from another step in the same state uses the ROI from the step in the original state.
    195601Editing the IP address while creating an EtherNet/IP device in the Communication Device Manager can cause two EtherNet/IP devices to be created.
    196736The Inspection Selection button does not appear in the inspection interface after rebooting the remote target.
    196944If the Inspection Measurements window is open while the Variable Manager is used to delete variables, the deleted variables are still listed in the Inspection Measurements window.
    197428After using a custom inspection interface in the Vision Builder AI Inspection Interface and then returning to the Vision Builder AI Configuration Interface and loading a modified version of the custom inspection interface, Vision Builder AI does not reflect the changes found in the modified custom inspection interface.
    197504In the Inspection Measurements window, step results for a deleted step remain in the Selected Results table after the step is deleted.
    197727In the Predefined Registers tree of the EtherNet/IP Adapter step, no value is displayed for a selected register if the register is listed as the final element in a branch.
    197811In the Inspection Measurements window, result values of NaN are included when calculating the average value.
    198529The Data Logging, Image Logging, and Read/Write INI File steps allow file paths to contain multiple line entries.
    199177When the feature-based algorithm is selected for the Geometric Matching step, the step does not use the specified Match Offset coordinates after the step is added to the inspection.
    199233After opening an inspection that contains a Run LabVIEW VI step which cannot locate the specified VI, the step deletes any VI control or indicator settings when the step is edited.
    Device Support
    Vision Builder AI supports the following remote targets:
    • NI 17xx Smart Cameras
    • NI CVS-1450 Series Compact Vision Systems
    • NI EVS-1460RT Series Embedded Vision Systems
    Vision Builder AI supports the following image acquisition and I/O devices:
    • National Instruments image acquisition devices
    • IEEE 1394 industrial digital cameras
    • GigE Vision cameras
    • DirectShow-compatible USB cameras
    • IP cameras
    • digital or analog I/O from NI data acquisition (DAQ) devices
    • serial devices
    Note: You must install driver software to acquire images from an image acquisition device connected to the host computer.
    Vision Builder AI supports all NI Smart Cameras, allowing you to remotely configure and control the device. To use Vision Builder AI with a NI 17xx Smart Camera, you must use Vision Builder AI to configure the NI 17xx Smart Camera. For more information, refer to Getting Started with the NI 17xx Smart Camera, included with every NI 17xx Smart Camera.
    Note: You do not need to install driver software to acquire images from a NI 17xx Smart Camera.
    Vision Builder AI supports the NI CVS-1450 series Compact Vision System, allowing you to remotely configure and control the device. To use Vision Builder AI with a NI CVS-1450 device, you must use Vision Builder AI to configure the NI CVS-1450 device. For more information, refer to Getting Started with the NI CVS-1450 Series, included with every NI CVS-1450 device.
    Note: You do not need to install driver software to acquire images from a camera connected to a NI CVS-1450 device.
    Vision Builder AI supports all NI Embedded Vision Systems, including NI EVS-1460RT series Embedded Vision Systems. To use Vision Builder AI with a NI EVS-1460RT series device, you must use Vision Builder AI to configure the NI EVS-1460RT series device. For more information, refer to the documentation included with the NI EVS-1460RT series device.
    Note: To acquire images from a Camera Link camera attached to a NI EVS-1463RT device, you must use MAX to configure the Camera Link camera. For more information about installing MAX, refer to Getting Started with the NI EVS-1463RT, included with every NI EVS-1463RT device.
    Note: You do not need to install driver software to acquire images from a camera connected to a NI EVS-1464RT device.
    National Instruments Image Acquisition Devices
    This version of Vision Builder AI supports the following National Instruments image acquisition devices:
    • NI PCI-1405
    • NI PXI/PCI-1407
    • NI PXI/PCI-1409
    • NI PXI/PCI-1410
    • NI PXI/PCI-1411
    • NI PXI/PCI-1422
    • NI PCI-1424
    • NI PCI-1426
    • NI PCIe-1427
    • NI PXI/PCI-1428
    • NI PCIe-1429
    • NI PCIe-1430
    Note: If you are using an image acquisition device, you must install NI Vision Acquisition Software before you install the image acquisition device. NI Vision Acquisition Software gives you access to Measurement & Automation Explorer (MAX), which is software you can use to configure National Instruments devices.
    IEEE 1394 Cameras, GigE Vision Cameras, DirectShow-Compatible USB Cameras, and IP Cameras
    Vision Builder AI supports IEEE 1394 cameras, GigE Vision cameras, DirectShow-compatible USB cameras, and IP cameras. To acquire an image from one of these camera types when the camera is connected to the host computer, use the Acquire Image (1394, GigE, or USB) step. The Acquire Image (1394, GigE, or USB) step requires NI-IMAQdx, which can be installed from the NI Vision Acquisition Software DVD included with Vision Builder AI. The following table lists the minimum version of NI-IMAQdx required for each camera type:
    Vision Builder AI Camera Support
    Camera Type
    Minimum Required
    NI-IMAQdx Version
    Supported NI Host Adapters
    IEEE 1394 Cameras
    3.0
    NI PXI/PCI-8252, NI PCI-8254R, NI PCIe-8255R
    GigE Vision Cameras
    3.0
    NI PCIe-8231, NI PCIe-8235, NI PXIe-8234
    DirectShow-Compatible USB Cameras*
    3.4
    IP Cameras
    3.5
    *Verify that the camera driver supports DirectShow and that the camera driver is installed correctly. For specific information about drivers and camera compatibility, consult your camera manufacturer documentation.
    You must configure an IEEE 1394 camera to use the NI-IMAQdx driver. Complete the following steps to use MAX to configure an IEEE 1394 camera to use the NI-IMAQdx driver.
    • Launch MAX.
    • In the MAX configuration tree, expand Devices and Interfaces to obtain a list of installed devices.
    • Expand NI-IMAQdx Devices to obtain a list of available cameras.
    • Right-click the camera and select Driver»NI-IMAQdx IIDC Digital Camera.
    National Instruments no longer supports Legacy NI-IMAQ for IEEE 1394 Cameras driver software. Installing NI-IMAQdx from the NI Vision Acquisition Software DVD included with Vision Builder AI uninstalls Legacy NI-IMAQ for IEEE 1394 Cameras driver software. If you have an existing inspection that uses the Acquire Image (IEEE 1394) step or you want to use the Acquire Image (IEEE 1394) step to acquire images from an IEEE 1394 camera connected to the host computer, you must download and install Legacy NI-IMAQ for IEEE 1394 Cameras driver software. Visit ni.com/info and enter the info code legacy1394 for information about how to install Legacy NI-IMAQ for IEEE 1394 Cameras driver software.
    Note: The Vision Builder AI software image for the NI CVS-1450 Series Compact Vision System includes all necessary driver software. You do not need to download and install Legacy NI-IMAQ for IEEE 1394 Cameras driver software to configure a CVS-1450 Series Compact Vision System.
    NI Analog and Digital I/O Devices
    This version of Vision Builder AI supports digital and analog I/O from any National Instruments data acquisition (DAQ) device using NI-DAQmx Global Channels. To support NI DAQ devices, Vision Builder AI requires NI-DAQmx 8.0 or later.
    Serial Communication
    To support serial communication, Vision Builder AI requires NI-VISA 2.6.0 or later, which is included with Vision Builder AI. You can use the serial ports built into the PC or one of the following NI serial interfaces: NI PCI-232/x, NI PXI-8420/x, or NI PXI-8422/x. You do not need to install NI-VISA to use the serial port on a remote target.
    National Instruments is aware of the following issues you may encounter while using Vision Builder AI.
    General
    • Vision Builder AI may not display an inspection image if the image is large and your computer is low on available memory.
    • To detect and configure a remote target on a system running Windows 7/Vista, the system must have only one network adapter or you must temporarily disable all but one network adapter.
    • The Run LabVIEW VI step works only with VIs that have a connector pane that consists of a single unwired terminal. For information about configuring a VI to work with the Run LabVIEW VI step, refer to the Run LabVIEW VI FAQs topic in the NI Vision Builder for Automated Inspection: Configuration Help.
    • When using the Vision Builder AI Development Toolkit, you must close all open LabVIEW VIs before attempting to create a new step or importing a step from a previous version of Vision Builder AI.
    • When using the Vision Builder AI Development Toolkit, if you import a Vision Builder AI 2.6 step that uses previous measurement results, when the step executes, the array of measurements in the User Interface and User Programming VIs will be empty. Refer to the NI Vision Builder for Automated Inspection Development Toolkit Tutorial for information about using previous measurements in Vision Builder AI 3.0 or later.
    Vision Builder AI ActiveX Component
    • To use the Vision Builder AI ActiveX component from LabVIEW, you must use LabVIEW 8.2 or later.
    • When using the Vision Builder AI ActiveX component, the NIVBAITargetMode setting is not available. Therefore, the connection to a target always allows full control.
    • When using the Vision Builder AI ActiveX component, if the connection to a local target fails the first time you try to connect to the local target, restart the computer and retry the connection.
    Additional ResourcesHow do I get started?
    Read the NI Vision Builder for Automated Inspection Tutorial, which provides exercises for learning how to perform basic machine vision techniques using Vision Builder AI.
    Where can I find reference information?
    Reference information for Vision Builder AI is available from within Vision Builder AI by clicking the Show Context Help button, or selecting Start»All Programs»National Instruments»Vision Builder AI»Documentation.
    The following documents are provided with Vision Builder AI as online help:
    • NI Vision Concepts Help—Contains basic concepts of image analysis, image processing, and machine vision. This document also contains in-depth discussions about imaging functions for advanced users.
    • NI Vision Builder for Automated Inspection: Configuration Help—Contains information about the Vision Builder AI Configuration interface, managing inspections and images, and creating steps for an inspection.
    • NI Vision Builder for Automated Inspection: Inspection Help—Contains information about using the Vision Builder AI Inspection interface to run inspections.
    • NI Vision Builder for Automated Inspection: ActiveX Component Reference Help—Contains information about the ActiveX objects available to embed Vision Builder AI inspections into ActiveX applications.
    Use the Search tab in the help files to quickly locate specific information. For information about how to use the search functionality, refer to the Using Help»Searching Help topic in the help file.
    The following documents are provides with Vision Builder AI as Adobe PDF documents:
    • Vision Builder for Automated Inspection Tutorial—Describes Vision Builder for Automated Inspection and provides step-by-step instructions for solving common visual inspection tasks, such as inspection, gauging, part presence, guidance, and counting.
    • NI Vision Builder for Automated Inspection Development Toolkit Tutorial—Contains instructions for using LabVIEW to create custom steps for Vision Builder AI.
    Where can I find examples?
    Examples of common Vision Builder AI inspections are installed to the \Examples directory, where is the location to which you installed Vision Builder AI.
    Where else can I go for Vision Builder AI information?
    Visit ni.com/vision and the NI Developer Zone at ni.com/zone for the most up-to-date information about Vision Builder AI.
    © 2002–2010 National Instruments Corporation. All rights reserved.
    Members of the National Instruments Alliance Partner Program are business entities independent from National Instruments and have no agency, partnership, or joint-venture relationship with National Instruments.
    For patents covering the National Instruments products, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your DVD, or ni.com/patents.
    发表于 2013-4-3 22:28:04 | 显示全部楼层 来自:广西桂林市 电信
    发表于 2013-10-22 01:32:32 | 显示全部楼层 来自:广东省广州市 移动
  • 签到天数: 2 天
    发表于 2014-1-16 23:16:13 | 显示全部楼层 来自:黑龙江省哈尔滨市 电信
    发表于 2014-4-1 10:07:12 | 显示全部楼层 来自:江西省南昌市 电信
    发表于 2014-5-16 10:14:09 | 显示全部楼层 来自:广东省东莞市 电信
    做机器视觉实验,就到华视自动化,石鑫华视觉http://shixinhua.com免费提供实验及解决方案
    发表于 2014-5-29 09:29:49 | 显示全部楼层 来自:江苏省苏州市 联通
    发表于 2014-6-8 09:28:55 | 显示全部楼层 来自:江苏省南京市 移动
    机器视觉论坛http://visionbbs.com,最专业的LabVIEW机器视觉与图像处理论坛
    发表于 2014-6-8 09:29:03 | 显示全部楼层 来自:江苏省南京市 移动
    发表于 2018-3-31 13:17:21 | 显示全部楼层 来自:北京市 联通
    GMT+8, 2025-12-12 20:45
