TA的每日心情 | 奋斗 5 小时前 |
签到天数: 3535 天 连续签到: 5 天 [LV.Master]2000FPS
发表于 2014-8-10 18:10:47
来自:广东省东莞市 移动
NI LabVIEW Desktop Execution Trace Toolkit 2014 DETT-桌面执行跟踪工具包
Trace sequence of VI events in LabVIEW applications during run time
Identify problems that could negatively impact performance such as memory leaks and reference leaks
Collect low-level information such as call chain, thread ID, and location in virtual memory of trace
Target local applications or deployed applications over a network
Profile VIs, executables, and shared libraries
Generate user-defined events
The NI LabVIEW Desktop Execution Trace Toolkit helps you trace the execution of LabVIEW VIs on a Windows target during run time to detect and locate problems in code that could affect performance or cause unexpected behavior. It provides a chronological view of VI events, queue operations, reference leaks, memory allocation, unhandled errors, and subVI execution. With this toolkit, you can programmatically generate user-defined events from the block diagram of a LabVIEW application.
In addition, you can use this toolkit to parse the trace data with custom filters or export the data to a spreadsheet for documentation. By highlighting individual events, you can obtain additional information such as the call chain and CPU number. You also can double-click traced events to highlight the corresponding object on the block diagram.
Dynamic code analysis is an important practice for demonstrating correct behavior and debugging complex software. You can configure the LabVIEW Desktop Execution Trace Toolkit to monitor execution of VIs on a local machine or remotely over a network. In addition to VIs in the development environment, you can use the toolkit to profile debuggable executables and shared libraries.
百度网盘下载及NI官方下载地址请参考以下帖子:
LabVIEW 2014 Desktop Execution Trace Toolkit Win32ENG LabVIEW2014桌面执行跟踪工具包DETT2014
http://visionbbs.com/thread-24303-1-1.html |
