查看: 8346|回复: 0
[LabVIEW] NI LabVIEW 2014 MAC OS X32Eng LV2014苹果系统评估版下载
    前天 10:18
  • 签到天数: 3555 天
    连续签到: 7 天
    发表于 2014-8-9 20:35:40 | 显示全部楼层 |阅读模式 来自:广东省东莞市 移动
    大小:592MB
    语言:英文
    支持操作系统:MAC OS X
    处理器需求:Pentium 4M(或同等性能)/更高主频的处理器(32位)Pentium 4 G1(或同等性能)/更高主频的处理器(64位)
    屏幕分辨率:1024 x 768像素
    苹果MAC OS X评估版,虽然官方网站写着是64位的,但是有人安装测试过,好像还是32位的。还请谨慎购买下载,仅此一个2014SP的MAC版本,无其它可供挑选的。
    请购买附件下载查看
    请购买附件下载查看
    LV2014MAC.txt (230 Bytes, 下载次数: 22, 售价: 10 元)
    LabVIEW 2014 Readme for OS X
    Version 14.0.0
    June 2014
    This file contains important information about LabVIEW 2014 for OS X, including system requirements, installation instructions, known issues, and a partial list of bugs fixed for LabVIEW 2014.
    Refer to the National Instruments website for the latest information about LabVIEW 2014.
    LabVIEW 2014 (64-bit)
    Additions to the LabVIEW Help
    OS XRun-Time EngineDevelopment Environment
    RAM256 MB2 GB
    Screen Resolution1024 x 768 Pixels1024 x 768 Pixels
    Operating SystemOS X 10.8 or 10.9OS X 10.8 or 10.9
    Disk Space656 MB - 1.3 GB1.3 GB for the complete installation
    Temporary Files DirectoryN/ALabVIEW uses a directory for storing temporary files. National Instruments recommends that you have several megabytes of disk space available for this temporary directory.
    Note  National Instruments recommends that you use Firefox 10.0 or later or Safari 6.0 or later to view the LabVIEW Help.
    Depending on whether you are installing LabVIEW for the first time or upgrading from a previous version, refer to one of the following documents for information about installing LabVIEW:
    • LabVIEW Installation Guide—Includes information about installing LabVIEW, modules and toolkits, drivers, and hardware.
    • LabVIEW Upgrade Notes—Includes information about protecting existing VIs and projects before you install a new version of LabVIEW, as well as upgrade and compatibility issues and a complete list of new features in LabVIEW 2014.
    You can access the LabVIEW Installation Guide and the LabVIEW Upgrade Notes at ni.com as well as on the installation media.
    Visit ni.com/security for security information about National Instruments products. Visit ni.com/critical-updates for information about critical updates from National Instruments.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in LabVIEW 2014.
    At the time of release, LabVIEW 2014 (64-bit) for OS X supports a limited number of National Instruments drivers, modules, and toolkits. Refer to the National Instruments Product Compatibility for LabVIEW (64-bit) for Mac OS X support document at ni.com for more information.
    The following list contains additional changes to LabVIEW that are not included in the LabVIEW Help, the LabVIEW Upgrade Notes, or both:
    • In LabVIEW 2014, when you place a For Loop or While Loop around existing code, LabVIEW automatically creates shift registers for any input and output that shares the same data type and a data flow dependancy, like error in and error out parameters.
    The following items are the IDs and titles of a subset of issues fixed in LabVIEW 2014. This is not an exhaustive list of issues fixed in the current version of LabVIEW. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    IDLegacy IDFixed Issue
    465342QH9HKJ1Enhance error filtering in the Clear Errors VI
    122057Joining numbers of different widths produces unexpected values
    125936Printing entire VI hierarchy does not include dynamic dispatch subVIs
    187861A VI snippet that contains a Property node for a front panel object results an invalid reference
    201104Toggling y-scale visibility with multiple scales causes unreadable display of data on waveform graphs
    212845When creating a VI snippet that contains a local variable, the VI snippet changes the variable to a Property Node and a reference
    255617Error 1502 can occur if dependencies are placed in non-executing Case structures
    276765Classic controls do not have distinct names in Quick Drop
    276988A large picture ring constant can cause fpsane.cpp line 442 error
    277283When creating a VI Snippet with code that contains a tab control, the snippet does not properly save the contents of each tab.
    286661Issue with the LabVIEW Icon Editor opening with a white background when it should be transparent
    292652VI snippet cannot be dragged from Chrome, Firefox or Safari
    308748Memory leak when using .NET TextBox Append Method
    313075In some cases, wiring a constant to a Case structure would result in the inability to build a LabVIEW executable with Error 1502
    362970Cannot link VI Context Help to an anchor in an HTML file
    366169Making a copy of a library using the "Save As" menu resets all VI icons in the new copy of the library to the default icon
    367468Wiring multiple inputs to the Split Signals VI causes LabVIEW to crash
    368959LabVIEW crashes by replacing a cluster constant that is being viewed as an icon with either a string or a Boolean constant
    369119Renaming a library that contains a class which contains a strictly typed VI refnum causes errors because the namespace in the refnum is not updated
    371391For a specific VI, enabling debugging caused an order of magnitude performance degradation
    376763Removing an item in an enum does not change focus to the next item in the list
    377978When compared to the Index Array function, Delete From Array function has performance overhead when using it to index the last value of an array
    381960LabVIEW runs out of images and crashes if you have large number of VIs in your user.lib palette
    382652It is possible to make changes to the items of a typedef enum constant in the properties menu, but the changes do not take effect
    384551A breakpoint inside the disabled case of a Conditional Disable structure is still hit when the VI executes
    386963Creating a typedef from a cluster that contains an empty array constant throws a DWarn 0x283E632F in replace.cpp
    393436Build VI does not return any generated files when running an installer build specification
    397393Internal Warnings 0xD1EED773 and 0x667BD7ED while changing name of a control
    397845In rare cases, LabVIEW hangs when merging VIs with missing subVIs
    397918Error 1502 sometimes occurs when building an application containing unreachable code in a Case structure with a constant wired to it
    401646Toggling the visibility of an axis on a Waveform Graph with multiple axes causes the axes to overlap
    401731Add valid "Window Run-Time Positions" from VI Properties to app builder Source File Settings - Customize VI Properties
    403179LabVIEW crashes when wiring a variant constant to a digital waveform graph and save the VI
    403202The Remote Front Panel Plugin for Chrome and Firefox needs to be installed on a repair
    403213Creating a source distribution does not allow you to have a mix of code that is source only and not source only
    403263Bookmark Manager shows bookmarks in the LabVIEW resource folder
    404038Unevenly Sampled Signal Spectrum VI uses incorrect sample weighting
    404512Compiler Error csrc=0x3F when Match Pattern VI is wired to a conditional tunnel
    404637Ctrl+z sometimes types a z character. The same behavior occurs for ctrl+c and ctrl+x
    406710LabVIEW crashes when inlined subVI with Feedback Node inside of parallel For Loop is called
    407147Opening the LabVIEW Icon Editor resets invisible layers to visible
    407471.NET invoke and property nodes do not always load or relink to the correct assembly version
    408437Mouse Wheel ButtonMods event data appears in English in French LabVIEW
    408624Rare LabVIEW crash when a FPGA target parent is drag-dropped and LabVIEW FPGA is not installed or not licensed
    409889Build All fails while building an installer when multiple build specifications are in a project
    410733Ramp Pattern VI does not produce expected results
    410846LabVIEW crashes when using concatenating tunnel mode on fixed-size array
    412912LabVIEW Crash when VI has string control wired to generate user-defined trace events is traced
    413400When configuring a new project in LabVIEW, the project root directory cannot be set to a network drive
    413502Desktop Execution Trace Toolkit does not accurately identify creation/destruction of Data Value References
    417188Officially support using VariantFlattenExp to flatten variants to previous versions
    417953LabVIEW will crash on run if array on connector pane is wired to Flatten to JSON primitive
    418199The reference to typedef objects returned by the FocusObj event structure terminal cannot be compared to regular object references
    418330Rare LabVIEW crash while quick-dropping a primitive onto the diagram
    420007Open URL in Default Browser VI does not correctly handle hashtags in Compiled Help Files
    421458Digital Waveform Graph can hang LabVIEW when writing badly overflown data
    421739Quick Drop ctrl+r needs to wire the To More Specific/Generic side terminal instead of center terminal
    422283Renaming specific .lvlibs in a project can cause typedef enum constants to revert to default values
    422905Attaching a comment to an object with a long label, the comment arrow will not point at the object
    424616Block diagram constants do not inherit a typedef's default data when a new element is added
    425582LabVIEW issues an internal warning when failing to save a VI in an unattended mode
    426108Using an annotation list to visualize labels and arrows with offset in a XY Graph the offset for the labels sometimes disappears
    426280Modifying the Minimum Value in the properties of a numeric control configured to Absolute Time can crash LabVIEW
    426285In rare cases, a corrupt listbox does not output correct values
    426523A specific large project fails to build with a GenIL error and then crashes if you do not select Disconnect Type Defs
    426788Reading LinkedControl.Label.Text property of an implicit property node crashes LabVIEW
    426792LabVIEW crashes when waveform graph cursors contain invalid scale values
    427673The Actor Framework cannot be packed into a packed library
    428197Creating an I8 array indicator/control for a property node adds a U8 array instead
    428253If LabVIEW 2013 is installed, Application Builder includes the LabVIEW 2013 Web Service installer when building from LabVIEW 2012
    428273Add High Resolution Relative Seconds VI to the Timing palette
    428357Comparisons fail between empty fixed sized arrays and compare aggregates
    428767Create SubVI does not respect the Options settings for terminal label position
    428872System State Publisher incorrectly reports cached memory as "used" memory on Linux Real-Time
    429396Application directory VI incorrectly returns paths when used within a .NET Assembly or LabVIEW-built DLL
    429516VI snippets not working as expected in certain browsers
    429902Application Builder lists Windows XP SP2 as the system requirements when the LabVIEW Readme requires XP SP3
    430579The Cubic Spline Fit does not output a linear function when the balance parameter is zero and the input arrays are less than seven elements
    431956Calling a LabVIEW Web service repeatedly causes a memory leak
    432447"Adapt to source" does not work for FXP inside a cluster
    432614Remote Front Panels in LabVIEW 2013 do not release the VxWorks targets after being disconnected
    433514Dragging and dropping groups of arrays between clusters will sometimes cause a rare LabVIEW crash
    433551LabVIEW crashes when deleting an Real-Time target target from a project without Real-Time support installed
    433687Application Builder does not provide a way to set the CFBundleIdentifier in the Info.plist file on Mac
    435028Array constant does not auto resize when inner control is edited and resizes
    435029Updating a typedef does not cause a block diagram constant to resize correctly
    435259LabVIEW dialogs sometimes display offscreen with multiple monitor setups
    436784Scripting method ClusterConstant.AutoSize crashes LabVIEW
    437814Open Sessions VI from visa.llb does not work properly in LabVIEW 2013
    438550Mouse Wheel events show the incorrect coordinates for Controls and Splitters
    438646LabVIEW sometimes crashes when viewing the context help and deleting an input wire to a polymorphic VI that automatically adapts to inputs
    439026Building an Application with Enable ActiveX server selected will crash all localized versions of LabVIEW
    439041Memory leak when using User Events
    439642LabVIEW 2013 SP1 on Mac has an incorrect installer warning claiming we do not support Mavericks
    439710Launching a right-click menu on an XControl causes an increase in CPU usage
    440114Executing a TestStand sequence with LabVIEW VIs in a user interface running in the LabVIEW 2013 Development System causes delays at the beginning of execution
    441769Long build path on Mac OS X results in temporary files that prevent build
    441783LabVIEW Class VIs loaded from an unexpected path can sometimes load broken
    441892Quick Drop shortcut Ctrl-T does not work correctly for matrix and array constants
    441894Moving the label of a typedef constant through scripting moves the constant instead of the label
    442743Cutting text from one free label and pasting into another with the autotool disabled crashes LabVIEW
    444095Remove Stacked Sequence Structure from the palette
    444412LabVIEW sometimes crashes with exception 0x558A98DB when searching a block diagram containing tab controls using the find dialog
    445456webservices.ini is not installed on Linux Real-Time
    445981A memory leak occurs when calling a custom ActiveX Control function which returns a UInt64
    447072Wait (ms) VI does not work on NI Linux Real-Time target if wait is longer than 30000 ms
    449183In specific cases, adding an XControl to LabVIEW library crashes LabVIEW
    450094The menu option Project»Create Project will sometimes open a File Explorer window to the template folder
    450755Modifying Meter, Gauge, or Knob dimensions in a tab control resizes controls incorrectly
    451107In some cases, LabVIEW asks to save code changes when no changes were made
    451499LabVIEW Run-Time Engine crashes when it loads a .lvproj containing Network Variables using strict TypeDefs
    453896Error message encountered during TestStand Deployment Utility build process may show incorrect list of VIs
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about LabVIEW 2014.
    © 2004–2014 National Instruments. All rights reserved.
    GMT+8, 2025-6-2 12:49
