查看: 4251|回复: 0
[面阵相机] 石鑫华视觉供应进口CCD相机 AVT Marlin F-201B
  • 签到天数: 128 天
    发表于 2014-8-1 17:13:21 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    AVT Marlin工业相机
    描述
    Acclaimed bestseller digital IEEE 1394 machine vision camera
    广受好评的畅销数字1394机器视觉相机
    The Marlin is AVT`s classical most-sold IEEE 1394 machine vision camera. Since 2004, many thousand Marlins are part of various different image processing applications. Due to its modular design (angled head, side-entry connectors, AVT modular concept), it fits with almost every application.
    Marlin是AVT销售最多的经典型1394机器视觉相机。自2004年以来,成千上万的Marlin相机用于各种不同的图像处理应用项目中。
    IEEE 1394a (400 Mb/s)火线1394A接口
    Sony CCD sensors (1/3, 1/2, 1/1.8), 2/3 CMOS sensor索尼CCD、CMOS图像传感器
    6 models (VGA to 2 Megapixel)六种产品型号(VGA到200万像素)
    Options可选项
    -Various IR cut/pass filters各种红外截止、带通型滤波器
    -CS-Mount镜头接口可选CS
    -Angled head带转角的头部
    -Lateral cable exit横向电缆出口
    -White medical housing白色医疗外壳
    功能
    Marlin cameras are equipped with many useful real-time image pre-processing functions. They are performed by the FPGA inside the camera – with no additional CPU load on the host, so that an inexpensive system is sufficient.
    Marlin相机配置了许多有用的实时图像预处理功能。他们是由相机内部的FGPA完成的-不需要主机上额外的CPU资源,这样一个廉价的计算机系统就可以了。
    Programmable LUT, white balance, hue, saturation可编程查找到、白平移、色调、饱和度
    Debayering拜尔解码
    Auto gain, auto exposure自动增益、自动曝光
    Color correction色彩校正
    Shading correction阴影校正
    Sub-sampling, 2x binning (b/w)子采样,2X像素组合
    AOI (with speed increase)自定义兴趣区域(增加速度)
    Sequence mode - changes the image settings on the fly序列模式-可以在运行时改变图像设置
    Image mirror图像镜像
    Deferred image transport延迟图像传输
    SIS (Secure Image Signature, enhanced time stamp)安全图像签名,增强的图像标识
    Storable user settings保存用户设置
    应用
    With its modular and flexible design and the real-time pre-processing functions, this machine vision camera (IEEE 1394) fits for many applications:
    因为拥有模块化、灵活的设计以及实时图像预处理功能,所以该类机器视觉相机(火线1394)适用于许多应用项目。
    Machine vision机器视觉
    Quality control质量控制
    Semiconductor inspection半导体检测
    Industrial inspection工业检测
    ... and many more更多
    规格
    MarlinF-201
    InterfaceIEEE 1394a - 400 Mb/s, 1 port
    Resolution1628 x 1236
    SensorSony ICX274
    Sensor typeCCD Progressive
    Sensor sizeType 1/1.8
    Cell size4.4 洀嬀/td][/tr]
    Lens mountC
    Max frame rate at full resolution12 fps
    A/D12 bit
    On-board FIFO8 MB
    Output
    Bit depth8-10 bit
    Mono modesMono8, Mono16
    Color modes YUVYUV411, YUV422
    Color modes RGBRGB8
    Raw modesRaw8
    General purpose inputs/outputs (GPIOs)
    Opto-coupled I/Os2 inputs, 2 outputs
    RS-2321
    Operating conditions/Dimensions
    Power requirements (DC)8 V - 36 V
    Power consumption (12 V)<3 W
    Mass<120 g
    Body Dimensions
    (L x W x H in mm)
    72 x 44x 29 mm including connectors, w/o tripod and lens
    RegulationsCE, FCC Class B, RoHS
    [数据接口]
    1394A
    [像素]
    200万像素
    [传感器类型]
    CCD
    [传感器尺寸(')]
    1/1.8
    [相机类型]
    面阵相机
    [相机颜色]
    [快门模式]
    全局快门
    [分辨率(Pixel)]
    1628x1236
    [最高分辨率时帧率(FPS)]
    12
    [镜头接口]
    C口
    [外触发]
    硬件触发
    [尺寸(mm)]
    72x44x29
    [系列]
    Marlin
    [供货周期(天)]
    7
    石鑫华视觉的CCD相机购买请看http://visionbbs.com
    GMT+8, 2026-1-17 07:15
