查看: 3950|回复: 0
[远心镜头] 石鑫华视觉供应远心镜头 VST VS-TEC15
    发表于 2014-7-29 10:16:24 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    VST VS-TEC系列500万像素微距远心镜头
    VST VS-TEC15
    For 5 Megapixel sensor (2/3”)
    对应500万像素图像传感器,最大支持2/3’靶面
    Improved distortion and brightness
    改进的畸变失真与亮度
    Changeable Magnification and Iris (Fixed models available)
    可变的放大倍率与光圈(固定型号可用)
    For wide range of applications / inspection of electronic parts, semiconductor manufacturing equipment etc.
    广泛应用于电子部件、半导体制造设备的检测
    可选组件
    镜头可选组件
    Mirror unit (picture①/②)
    镜像组件(图像1、2)
    VS-PZ-C305NF : Allows you to set up for limited space.
    VS-PZ-C305NF:允许你安装在有限的空间里。
    Co-axial unit (picture③)
    同轴组件(图像3)
    VS-HM305 : Easy to set up co-axial lighting in front of the lens.
    VS-HM305:可以在镜头前端轻松安装同轴光源
    * for Mag. above0.5x model.
    适用于放大倍率为0.5X的型号
    畸变
    畸变对比
    型号和规格
    型号放大倍率工作距离(mm)等效光圈F数值孔径NA
    VS-TEC03040.3x~0.4x212.1~147.84.32~5.00.035~0.040
    VS-TEC05130.5x~1.3x171.7(0.5x)~95.9(1.3x)5.27(0.5x)~10.18(1.3x)(光圈全开时)0.047(0.5x)~0.064(1.3x)
    VS-TEC03/S0.3x224.14.320.035
    VS-TEC035/S0.35x181.54.660.038
    VS-TEC04/S0.4x147.85.000.04
    VS-TEC050.5x171.45.270.047
    VS-TEC0650.65x142.96.180.053
    VS-TEC0750.75x130.26.80.055
    VS-TEC101.0x109.88.310.06
    VS-TEC131.3x95.410.180.064
    VS-TEC151.5x89.311.440.065
    石鑫华视觉的远心镜头购买请看http://visionbbs.com
    GMT+8, 2026-1-17 05:02
