查看: 7321|回复: 4
[LabVIEW] NI LabVIEW 2012 Win64ENG 64位LV2012英文版下载
  • 签到天数: 3562 天
    连续签到: 7 天
    发表于 2012-11-24 10:51:46 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    请购买附件下载查看
    LV2012x64.txt (651 Bytes, 下载次数: 0, 售价: 10 元)
    LabVIEW 2012 Readme for Windows
    Version 12.0.0
    June 2012
    This file contains important information about LabVIEW 2012 for Windows, including system requirements, installation instructions, a partial list of bugs fixed for LabVIEW 2012, and known issues for LabVIEW.
    Refer to the National Instruments website for the latest information about LabVIEW 2012.
    LabVIEW 2012 (64-bit)
    Additions to the LabVIEW Help
    Important Information
    WindowsRun-Time EngineDevelopment Environment
    ProcessorPentium III/Celeron 866 MHz or equivalentPentium 4M or equivalent
    Screen Resolution1024 x 768 Pixels1024 x 768 Pixels
    Operating SystemWindows 7/Vista (32-bit and 64-bit)
    Windows XP SP3 (32-bit)
    Windows Server 2003 R2 (32-bit)
    Windows Server 2008 R2 (64-bit)
    Disk Space353 MB3.67 GB (includes default drivers from the NI Device Drivers DVD)
    Temporary Files DirectoryN/ALabVIEW uses a directory for storing temporary files. National Instruments recommends that you have several megabytes of disk space available for this temporary directory.
    Note  The following list describes restrictions for using LabVIEW on Windows:
    • LabVIEW does not support Windows 2000/NT/Me/98/95 or Windows XP x64.
    • You cannot access LabVIEW using a Guest account on Windows.
    Depending on whether you are installing LabVIEW for the first time or upgrading from a previous version, refer to one of the following documents for information about installing LabVIEW:
    • LabVIEW Installation Guide—Includes information about installing LabVIEW, modules and toolkits, drivers, and hardware.
    • LabVIEW Upgrade Notes—Includes information about protecting existing VIs and projects before you install a new version of LabVIEW, as well as upgrade and compatibility issues and a complete list of new features in LabVIEW 2012.
    You can access the LabVIEW Installation Guide and the LabVIEW Upgrade Notes at ni.com as well as on the installation media.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in LabVIEW 2012.
    When run on Windows (64-bit), LabVIEW 2012 (64-bit) provides access to more memory than a 32-bit operating system or a 32-bit application can provide. LabVIEW 2012 (64-bit) includes nearly all of the development environment features of LabVIEW 2012 (32-bit).
    Refer to the National Instruments website for information about obtaining a copy of LabVIEW 2012 (64-bit).
    LabVIEW 2012 (64-bit) supports many hardware devices. Refer to the National Instruments website for information about drivers compatible with LabVIEW 2012 (64-bit). For GPIB devices, you must use at least NI-488.2 2.6 for Windows. Refer to the specific hardware documentation for more information about compatibility with LabVIEW 2012 (64-bit).
    Supported Modules
    LabVIEW 2012 (64-bit) supports only the NI Vision Development Module. Refer to the Vision Development Module documentation for more information. No additional modules support LabVIEW 2012 (64-bit).
    The following list contains additional changes to LabVIEW that are not included in the LabVIEW Help, the LabVIEW Upgrade Notes, or both:
    • Because LabVIEW 2012 may apply different compiler optimizations on different machines, you may need to perform additional steps to guarantee that a built application contains the same binary contents when built on different machines. Refer to the National Instruments website for more information about reproducing builds in LabVIEW 2012.
    The following items are the IDs and titles of a subset of issues fixed in LabVIEW 2012. This is not an exhaustive list of issues fixed in the current version of LabVIEW. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    100634.NET Calendar Control is not sized properly
    124146Re-initialize to default not working on Picture Control
    156274Changes to Type Def Reference to a Tab Control doesn't update other instances
    167056Wiring cluster of fixed point values to waveform chart causes a broken arrow
    182407Remote Debugging crashes with an application that uses MathScript
    185059Member VIs of a class that is a member of a project library have a red X on them in the palettes
    186525'visarc' file included in source distribution even when excluding vi.lib
    187412Custom RTM will incorrectly link to the source location when built into an executable
    190778Huge array causes long save time and run time on LabVIEW 64-bit
    190887XY Plot Legend Shifts Right On Front Panel When Repeatedly Redrawn
    209168VI Server method "Application:Library.Open" returns wrong library if library is unsaved
    214475Cannot zoom in render window of 3D graph
    219940Cannot use Sort 1D Array with an array of clusters containing LabVIEW Classes
    236868Pane Size Event Does not generate final event as documented
    258465Pre-Build Action VI Not brought to front when Source Distribution is Built from Properties Window
    280810Giving Simulation VI class terminals that are dynamic dispatch results in LabVIEW compiler fault
    283709Logos Sockets should broadcast on all available NICs
    285210Read from Measurement File Express VI can read incorrect data
    294478Applications built from VIs that include Damemoji AKA stressed characters in the file name do not work.
    297201Time Critical priority VI shouldn't compile if it contains a Timed Loop
    298656Import Web Services does not support external type definition (external schema)
    299162Saving for previous with missing DLL crashes LabVIEW
    300592LabVIEW built executable with network streams won't exit process
    300864Unexpected broken wires when graphing coerced CDB arrays
    302673Programmatically changing y-axis parameters on a waveform chart or graph causes the plot to shrink horizontally.
    302888Sine Pattern VI behaves incorrectly for certain inputs
    302922Unexpected inputs can permanently corrupt a 3D graph instance.
    310813EXE/RTEXE and PPL have load time issues when statechart is embedded inside
    311293Not A Reference does not work with FTP References
    311294FTP Close Session.vi will not unregister a session if server is unresponsive
    311617Undoing block diagram cleanup in VI with Control & Simulation Loop and subsystem crashes LabVIEW
    312531When class specific VIs are used in a project, the VI Metrics Tool does not include them in the VIs it analyzes.
    313044Long Delays when editing VIs with LabVIEW object-oriented programming property nodes
    313186Long lines in 2D Picture are drawn to the wrong end points.
    313610NI LabVIEW Report Generation Toolkit for Microsoft Office 2011: broken Excel Active X methods
    315798TCP Write Stream generates add extra characters to TDMS files during FTP transfer
    316099Project load time can be affected by large .lvlps file
    317005Several Express VIs become broken when placed on Block Diagram after Spectral Measurement VI.
    318065"Find" options within context menu for implicitly linked property/invoke nodes missing when original control is a typedef
    318415Error reading LVM file "Incorrect file type"
    321650LabVIEW crashes when changing event registration refnum constant to control.
    323425Build failures caused by inlined VIs in a PPL
    325201Front Panel Indicators to Fail to Update Correctly When EXE is Loaded in Bad State
    327431Import WebService Tool doesn't work for HTTPS protocol
    327926Calling Variable Property Node in a Loop leaks memory
    329925Continuous Sound Input.vi example unresponsive after pause execution
    331216Rare Crash on VI Compile
    332247To Long Integer produces incorrect result for a SGL input of 2^31
    333279Calling the System Exec VI after calling the Pipe VI in LabVIEW for Linux will Hang LabVIEW.
    333651Converting a PSP variable to a variant, then a string and back, causes the conversion back to PSP variable to fail
    335523Creating a reference for a control that is a typedef is not retaining the typedef properties of the refnum type
    338840Shortcut Menu Activation Interferes with Independent Autoscale Y Settings in Waveform Chart or Graph with Multiple Plots
    344940Copying data in custom probe can crash LabVIEW
    346352"Explore" button on Application Builder build progress dialog doesn't close the dialog
    346819Incorrect result when calling a non-reentrant VI by a pre-allocated VI
    347785General Linear Fit (Bi-Square) VI does not return weight out
    © 2004–2012 National Instruments. All rights reserved.
  • 签到天数: 56 天
    发表于 2013-3-6 22:50:24 | 显示全部楼层 来自:陕西省西安市 电信
  • 签到天数: 3562 天
    连续签到: 7 天
     楼主| 发表于 2013-3-6 23:31:03 | 显示全部楼层 来自:广东省东莞市 联通
  • 签到天数: 56 天
    发表于 2013-3-7 08:32:57 | 显示全部楼层 来自:陕西省西安市 电信
    我试了,不能激活。不知有无别的办法。
  • 签到天数: 3562 天
    连续签到: 7 天
     楼主| 发表于 2013-3-7 09:16:06 | 显示全部楼层 来自:广东省东莞市 电信
    GMT+8, 2025-6-9 09:37
