查看: 10|回复: 0
[NI驱动程序] NI-568x Driver Software 18.0.1 Win32/64En NI-568x驱动程序NI568X1801
    8 小时前
  • 签到天数: 3822 天
    连续签到: 15 天
     楼主| 发表于 7 小时前 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-568x为使用NI RF功率传感器设备的客户提供支持。
    NI-568x是与所有NI RF功率传感器设备通信必需的NI仪器驱动程序,包括NI-568x系列射频功率传感器设备。该驱动软件包括基于IVI准则的灵活API、完整的硬件支持文档以及配置、归零和测试实用程序。NI-568x包含了交互式软面板和示例。
    发布日期:2018/11/1
    包含的版本:完整版,版本号18.0.1
    Windows 10 32-bit
    Windows 8.1 32-bit
    Windows 7 (SP1) 64-bit
    Windows 7 (SP1) 32-bit
    Windows 8.1 64-bit
    语言:英文En
    程序位数:32/64位
    文件大小: 512405384 字节 (488.67 MB)
    修改日期: 2023-01-21 09:58
    MD5: e8b2b1becf03163ffe04444b485079b8
    SHA1: a5c65834699bd9b76094f288e25a3340463dd7a9
    SHA256: 000b7dba7fedab35f0b156daa503b1eb0cdeecf18170bf4c354957af52a31964
    SHA512: adf4f06c93c2e9a83506a97b3a68124b181ea2a718786e7af591fc3c2459af7224344b3c891240a382fb46aa255854e889f7a056e827cf9ed91eb5a56ad65c1a
    请注册登录机器视觉论坛会员,购买附件查看下载地址
    NI-568x 18.0.1.txt (615 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-568x 18.0 Readme
    May 2018
    This file contains important information about NI-568x, including new features, bug fixes, and known issues.
    IVI Compliance Pacakge Functionality
    Using NI Software with Microsoft Windows 8.x
    This software installation provides support for customers using RF power sensor devices, as specified in the Supported Hardware section. To program your RF power sensor device, use the NI-568x instrument driver or the NI-568x Soft Front Panel (SFP).
    The getting started guide for your device provides information about how to install, configure, test, and begin using an RF power sensor device.
    NI-568x 18.0 adds support for LabVIEW 2018 (32-bit and 64-bit)
    NI-568x 17.0 includes the following new features:
    NI-568x 15.0 includes the following new features:
    • Support for LabVIEW 2015 SP1 (32-bit and 64-bit)
    • Support for LabVIEW 2014 SP1 (32-bit and 64-bit)
    • Support for Windows 10 (32-bit and 64-bit)
    • Support for the USB-5683
    • Support for the USB-5684
    • Updated NI-568x Soft Front Panel (SFP)
    • Support for triggered measurements with hysteresis consideration
    • Support for specifying buffer size in continuous power measurements
    • Support for measuring pulse-modulated signals with periods shorter than 30.0 µs
    The NI-568x instrument driver supports the following RF power sensor devices:
    • USB-5680
    • USB-5681
    • USB-5683
    • USB-5684
    Device-specific information about these modules is included in the RF Power Sensor Devices Help.
    NI-568x 18.0 has the following requirements:
    • 512 MB RAM
    • A screen resolution of 1,024 × 768
    • USB port
    Note  The minimum USB port requirement for USB-5683 and USB-5684 devices is USB 2.0.
    Note  NI recommends that you disable Windows power management modes, such as sleep, standby, and hibernate when using this product. These modes terminate any operation in progress. On a laptop computer, the default power management settings are likely to enable sleep mode.
    NI-568x 18.0 supports the following operating systems:
    • Windows 10/8.11/7 SP12
    1 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 requires Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    2 NI software is signed with a SHA-256 certificate. Windows 7 SP1 requires Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update.
    NI-568x 18.0 supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows™/CVI™ or Microsoft Visual Studio®, before installing NI-568x. To add support for application software installed after installing NI-568x, modify your NI-568x installation or launch the NI-568x installer again.
    Application SoftwareVersions Supported by NI-568x
    LabVIEW2015 SP1, 2016, 2017 SP1, or 2018
    LabWindows™/CVI™2012 and later
    Microsoft Visual C++ (MSVC)2008 and later
    Note  If you are running your application on an RT target, 128 MB of memory or more is required.
    To use the .NET API, you must install the .NET class libraries or the .NET wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to the National Instruments .NET Driver Support document at ni.com/info and enter Info Code NETAPIdriversupport.
    Accessing the APILabVIEW
    NI-568x VIs are available in LabVIEW from the Functions»Instrument I/O»Instrument Drivers»NI-568x palette.
    LabWindows/CVI
    NI-568x functions are available in LabWindows/CVI from the Instrument menu. To load the NI-568x function panel (.fp), select Instrument»Load, and navigate to IVI\Drivers\ni568x\ni568x.fp.
    C
    You can use the NI-568x C dynamically linked library by adding a reference to:
    • (32-bit): Program Files\IVI Foundation\IVI\Bin\ni568x.dll
    • (64-bit): Program Files (x86)\IVI Foundation\IVI\Bin\ni568x.dll for 32-bit development or Program Files\IVI Foundation\IVI\Bin\ni568x_64.dll for 64-bit development.
    Select Start»All Programs»National Instruments»NI-568x»NI-568x Soft Front Panel to launch the NI-568x Soft Front Panel.
    Select Help»Find Examples from LabVIEW or LabWindows/CVI to launch the NI Example Finder, and click the Browse tab to locate examples by task at Hardware Input and Output»Modular Instruments»NI-568x (RF Power Meter). You can also select the Search tab to search all installed examples by keyword.
    All installed NI-568x examples for LabVIEW, LabWindows/CVI, and C are accessible from Start»All Programs»National Instruments»NI-568x»NI-568x Examples.
    Documentation for RF power sensor devices is located at Start»All Programs»National Instruments»NI-568x»NI-568x Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RF Power Sensor Devices HelpHTML/Windows HelpContains primary help content for RF power sensor devices. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RF power sensor devices
    • Hardware device information
    • A complete reference for all NI-568x programming functions and VIs
    Getting started guide for your devicePrinted and PDFContains software and hardware installation, MAX configuration, signal connection, and troubleshooting information for your device.
    NI-568x ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    NI-568x IVI Compliance DocumentTXTContains information about IVI compliance.
    Introduction to ni568xHTMLContains information about driver documentation, examples, connecting to your instrument, configuring instrument settings, and known issues.
    Note  To view PDFs, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com.
    NI-RFSA no longer installs IVI Compliance Pacakge. NI-RFSA supports IVI configuration and runtime, but no longer supports the following features:
    • IVI-COM Adapters
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in NI-568x 18.0.
    The following items are the IDs and titles of a subset of issues fixed in NI-568x. This is not an exhaustive list of issues fixed in the current version of NI-568x. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in NI-568x 18.0 from NI-568x 15.1.
    666625Fixed an issue where installing NI-568x 17.0 with default LabVIEW settings prevented calling NI-568x VIs when using LabVIEW 2016 (64-bit).
    575648Fixed an issue where NI-568x returned an error if more than one VISA was enabled and available on the system.
    The following items are changes in NI-568x 15.1 from NI-568x 15.0.
    601287Fixed an issue where the serial number could not be read from a USB-5680 or USB-5681 power meter.
    The following items are changes in NI-568x 15.0 from NI-568x 1.2.
    240557Fixed an issue in which scope mode would error when using short capture times.
    409122Fixed an issue in which VISA aliasing would fail in NI Measurement & Automation Explorer (MAX).
    523688Fixed several issues in which attribute behavior was inconsistent with IVI compliance standards.
    © 2007–2018 National Instruments. All rights reserved.
    375452D-01
    GMT+8, 2026-3-11 17:41
