查看: 14|回复: 0
[NI驱动程序] NI-568x Driver Software 1.2 Win32/64En NI-568x驱动程序NI568X120
  • 签到天数: 3822 天
    连续签到: 15 天
     楼主| 发表于 10 小时前 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-568x为使用NI RF功率传感器设备的客户提供支持。
    NI-568x是与所有NI RF功率传感器设备通信必需的NI仪器驱动程序,包括NI-568x系列射频功率传感器设备。该驱动软件包括基于IVI准则的灵活API、完整的硬件支持文档以及配置、归零和测试实用程序。NI-568x包含了交互式软面板和示例。
    发布日期:2013/10/25
    包含的版本:完整版,版本号1.2.0
    Windows 8 32-bit
    Windows 7 32-bit
    Windows 8 64-bit
    Windows Vista 32-bit
    Windows 7 64-bit
    Windows Vista 64-bit
    Windows XP 32-bit
    语言:英文En
    程序位数:32/64位
    文件大小: 509612832 字节 (486.00 MB)
    修改日期: 2023-01-21 09:57
    MD5: 405e4091d26e7f0ba549609b3d3d4995
    SHA1: 089264648539d89b082c168ca8fb5996342bae0b
    SHA256: e1c1edc0146a4a7ec0be2167c243368265ba5e823e491c403af74ea6fad664b3
    SHA512: 4f2f72581c101f09d5bb6cd078b66b262e927442af07ef1e7c260395df244b6139a837f846f501756a06530c0ffef4ac6237f707edd2f456b03cf2de833fdaa0
    请注册登录机器视觉论坛会员,购买附件查看下载地址
    NI-568x 1.2.txt (607 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-568x Readme
    Version 1.2
    Thank you for using NI-568x. This file contains important information regarding NI-568x and is organized into the following sections:
    • New Features
    • Supported Hardware
    • System Requirements
    • Documentation
    • NI-568x Updates and Notifications
    • Uninstalling/Modifying NI RF Power Meters Software
    • Known Issues
    • Upgrading the Firmware
    • Bug Fixes
    • How to Use NI Software with Microsoft Windows 8
    • Important Information
    NI-568x 1.2 includes the following new features:
    • Support for LabVIEW 2013 Service Pack 1 (32-bit), LabVIEW 2013 SP1 (64-bit), LabVIEW 2012 Service Pack 1 (32-bit), LabVIEW 2012 SP1 (64-bit), LabVIEW 2011 SP1 (32-bit), LabVIEW 2011 SP1 (64-bit), LabVIEW 2010 SP1 (32-bit), LabVIEW 2010 SP1 (64-bit)
    • Support for Windows 8
    • Updated NI-568x Soft Front Panel (SFP)
    • Updated shipping examples
    NI-568x 1.1 includes the following new features:
    • Support for the NI USB-5681 (NI 5681)
    NI-568x 1.0 includes the following new features:
    • Support for the NI USB-5680 (NI 5680)
    The NI-568x instrument driver supports the following power meters:
    • NI USB-5680
    • NI USB-5681
    NI-568x 1.2 supports the following operating systems:
    • Windows XP (32-bit)
    It is recommended that you have the most recent service pack for your operating system installed. For Windows XP however, the minimum is Windows XP SP3.
    Minimum System Requirements
    • RAM—
      • Windows XP: 128 MB
      • Windows 7/Vista: 512 MB
      • Windows 8: 512 MB
    • A screen resolution of 1,024 × 768
    • Windows 8/7/Vista/XP, with all available critical updates and service packs
    • USB port
    Note NI recommends that you disable Windows power management modes, such as sleep, standby, and hibernate when using this product. These modes terminate any operation in progress. Notice that in Windows Vista or on a laptop computer, the default power management settings are likely to enable sleep mode.
    Recommended System
    • RAM—
      • Windows XP: 256 MB
      • Windows 7/Vista: 1 GB
      • Windows 8: 1 GB
    Note  You should install ADEs, such as NI LabVIEW, NI LabWindows™/CVI™ or Microsoft Visual Studio®, before installing NI-568x. To add support for ADEs installed after installing NI-568x, modify your NI-568x installation or launch the NI-568x installer again.
    If you are developing an NI-568x application, your system must have one of the following ADEs:
    • LabVIEW 2009 SP1 (32-bit), 2009 SP1 (64-bit), 2010 SP1 (32-bit), 2010 SP1 (64-bit), 2011 SP1 (32-bit), 2011 SP1 (64-bit), 2012 SP1 (32-bit), or 2012 SP1 (64-bit), 2013 SP1 (32-bit), or 2013 SP1 (64-bit)
    • LabWindows™/CVI™ 9.0 or later
    • Microsoft Visual C++ (MSVC) 7.1 or later
      • Windows XP: Documents and Settings\All Users\Shared Documents\National Instruments
      • Windows 8/7/Vista: Users\Public\Documents\National Instruments
      • Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI\
      • Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit)*: Program Files (x86)\IVI Foundation\IVI\
        • Windows 8 (32-bit)/7 (64-bit)/Vista (64-bit)*: Program Files (x86)\IVI\
      • Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit)*: Program Files\IVI Foundation\IVI\
      * These software versions run within the 32-bit emulation layer, Windows on Windows (WOW64).
      ItemInstallation Location on Windows 8 (32-bit)/Windows 7 (32-bit)/Vista (32-bit)/XP
      NI-568x\Drivers\ni568x
      NI-568x Function Panel\Drivers\ni568x\ni568x.fp
      LabVIEW Examples\examples\instr\ni568x
      C Examples\NI-568x\examples\c
      LabWindows/CVI Examples\CVI\samples\ni568x
      NI-568x Header files\Include
      NI-568x Import Library files (32-bit)\Lib\msc
      NI-568x Import Library files (64-bit)\Lib_x64\msc
      NI-568x DLL (32-bit)\Bin
      Additional File Locations for Windows 8 (64-bit)/Windows 7 (64-bit)/Vista (64-bit)*
      ItemInstalled Location on Windows 8 (64-bit)/Windows 7 (64-bit)/Vista (64-bit)
      NI-568x DLL (64-bit)\Bin
      Documentation is available at Start»All Programs»National Instruments»NI-568x»Documentation. Visit ni.com/manuals for the latest versions of product documentation. The documentation for NI-568x includes the following items:
      • NI-568x Readme (this document)
      • NI RF Power Meters Getting Started Guide—Explains how to install, configure, and set up the NI 5680/5681 RF power meters. Printed and PDF format.
      • NI RF Power Meters Help—Contains information about how to perform basic measurements with the NI 5680/5681, device information, and programming references for LabVIEW, LabWindows/CVI, and C. Online help format.
      • Specifications document for your device—Contains specifications for the capabilities and valid operating conditions of your NI device. Printed and PDF format.
      • Read Me First: Safety and Electromagnetic Compatibility—Includes safety instructions and information about the radio-frequency interference characteristics of the hardware it accompanies. Printed format.
      Note  To view the PDF documentation, you must have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/acrobat.
      National Instruments posts information about critical updates and security notifications on ni.com. Visit ni.com/info, and enter the info code updates to access this information.
      • Click Change/Remove.
      • Select NI-568x 1.2 from the dialog box that appears.
      For Windows 8, complete the following steps:
      • Select Programs»Programs and Features.
      • Click the Uninstall button.
      As part of the NI-568x installation, the following list of software is installed. To completely remove NI- 568x from your system, you must also remove all of the following packages:
      • NI IVI Compliance Package 4.4
      • NI Measurement & Automation Explorer 5.3.3
      • NI Measurement Studio Common .NET Assemblies for .NET 4.0
      • NI System Configuration API 5.3.3
      • NI System API Windows 32-bit
      • NI-VISA Runtime 5.2
      You can access the software and documentation known issues list online. Refer to the NI-568x 1.2 Known Issues at ni.com for an up-to-date list of known issues in NI-568x 1.2.
      A newer firmware version than what shipped with the NI USB-5680 device is available at the National Instruments website. NI recommends that you upgrade the firmware after you install NI-568x 1.2.
      The following items are changes in NI-568x 1.2 from NI-568x 1.1.
      238457Fixed an issue where power meters did not appear in NI Measurement & Automation Explorer (MAX) after installing the NI-568x driver.
      238742Fixed an issue where timeout errors occurred in scope mode.
      238918Fixed an issue where you could not use the power meter after disconnecting and reconnecting the power meter.
      The following items are changes in NI-568x 1.1 from NI-568x 1.0.
      93562Fixed an issue in which the NI-568x properties were not accessible from the property node.
      211620Fixed an issue in which LabVIEW 8.2 would not launch after installing NI-568x.
      106509Fixed a timeout error when reading from the NI 5680.
      Using NI Launcher
      Note   MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8. You can launch MAX either from the Start screen or from within NI Launcher.
      Finding All Programs
      © 2007—2013 National Instruments Corporation. All rights reserved.
      Members of the National Instruments Alliance Partner Program are business entities independent from National Instruments and have no agency, partnership, or joint-venture relationship with National Instruments.
    GMT+8, 2026-3-11 20:44
