查看: 165|回复: 0
[Cognex] 康耐视Cognex VISIONPRO 9.25 - SUPPLEMENTAL INSTALLER FOR VISIONPRODL 4.1 COMPATIBILITY
  • 签到天数: 3750 天
     楼主| 发表于 2025-11-23 15:53:45 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    If using VisionProDL 4.1 and VisionPro 9.25 on the same PC, you need to also install this supplemental package. 
    VPDL 4.1 and VPro 9.25 use different CUDA versions, and require this installer to ensure that there is no interference between these software packages.
    Note: This installer will only work with VPDL 4.1 and VPro 9.25, do not install if using any other versions.
    文件类型: .zip
    文件大小: 2.6GB
    版本: 9.25
    发布日期: 2025/8/28
    文件名: VisionPro_9_25_GPU_Supplement.zip
    文件大小: 2780261293 字节 (2.59 GB)
    修改日期: 2025-08-27 17:47
    MD5: eae7a46ec9fe0ef60695633f79d96bed
    SHA1: 405d2b24e2cc80a899eec2ca4779de2e778c6d8f
    SHA256: 6be42def25ae0b0f74a44ba678f3606a7cc2846e6fd00f99ab9229b7e5d4eaf0
    CRC32: 3d6e6719
    康耐视官方下载地址:
    链接:https://pan.baidu.com/s/1pYADYwU7NeVbmmh-z0da7A
    GMT+8, 2025-12-23 19:25
