查看: 101|回复: 0
[Cognex] 康耐视Cognex VISIONPRO 9.24 - SUPPLEMENTAL INSTALLER FOR VISIONPRODL 4.0 COMPATIBILITY
    6 小时前
  • 签到天数: 3730 天
    连续签到: 57 天
     楼主| 发表于 2025-11-23 15:43:41 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    If using VisionProDL 4.0 and VisionPro 9.24 on the same PC, you need to also install this supplemental package.
    VPDL 4.0 and VPro 9.24 use different CUDA versions, and require this installer to ensure that there is no interference between these software packages.
    Note: This installer will only work with VPDL 4.0 and VPro 9.24, do not install if using any other versions.
    文件类型: .zip
    文件大小: 2.6GB
    版本:
    发布日期: 2025/7/14
    文件名: VPro_9_24a_GPU_Supplement.zip
    文件大小: 2780346096 字节 (2.59 GB)
    修改日期: 2025-07-15 01:37
    MD5: c3c719b25e1d31d1d0de9aee30973cee
    SHA1: 8f7ee51a56476d43ebea5a5995a67768172b2f72
    SHA256: e63475249fd6713fa05b5b4980959a56d4ea2ac065e0ed8f8e69aaf1f7d2d404
    CRC32: a84db55a
    康耐视官方下载地址:
    链接:https://pan.baidu.com/s/10IJHchOnVB_-Wq2wsfoKcw
    GMT+8, 2025-12-2 14:45
