查看: 259|回复: 0
[NI软件产品] NI RFmx CDMA2000 2025 Q4 Patch 1 Full/Runtime Win11 64bitEn RFmxCDMA2K完整版运行版25.8.1下载
     楼主| 发表于 2025-11-15 10:04:29 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    RFmx CDMA2000
    发布日期:2025/10/19
    包含的版本:2025 Q4 Patch 1完整版/运行版,版本号25.8.1
    Windows Server 2025
    64位完整版校验和:
    文件大小: 1287833600 字节 (1.20 GB)
    修改日期: 2025-11-03 09:23
    MD5: 38e8aaaaac0b144751330a7666ab8911
    SHA1: 5a918c5e792d0021ef9cee7bc7460f5f0513e8de
    SHA256: 98de2d3ef250fb3b4c6aa9e124c809791035e4d99e9438d230d9b6653c0868af
    CRC32: 336dcbf6
    请注册登录视觉论坛,购买附件查看下载地址
    RFmx CDMA2000 2025Q4F1.txt (551 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 1025218560 字节 (977.72 MB)
    修改日期: 2025-11-03 09:24
    MD5: d00d011168bf086ef04597141caf01fe
    SHA1: 8f9cd0417c63b8157cd4b45352d9ca7148ac0583
    SHA256: 76b51b52db80c635a74ff4236add54fdfedf553b8e7e8cc47ac74a78a0ca0ce4
    CRC32: 412686f1
    RFmx CDMA2000 2025Q4RTEF1.txt (576 Bytes, 下载次数: 0, 售价: 5 圆)
    2025Q4Patch1版未更新自述文件,参考2023Q3版本
    RFmx CDMA2k 2023 Q3 Readme
    • RFmx CDMA2k Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx CDMA2k Manuals: New features, behavior changes, and other documentation
    Installed Software
    RFmx CDMA2k 2023 Q2 includes the following new feature:
    RFmx CDMA2k 2023 Q1 includes the following new feature:
    RFmx CDMA2k 2022 Q4 includes the following new features:
    • Support for PXIe-5842
    • Support for Downlink link direction in CDMA2k ModAcc measurement.
    RFmx CDMA2k 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx CDMA2k no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx CDMA2k 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx CDMA2k 2023 Q3 to an unsupported OS. Additionally, after installing RFmx CDMA2k 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx CDMA2k supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx CDMA2k. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx CDMA2k (64-bit only)
    Required Software
    Installed Software
    Item
    Installed Location
    Import Library files (64-bit)
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.CDMA2k.Fx40.dll
    Select Start » National Instruments» RFmx CDM2k Measurement Interactive Panel to launch the RFmx CDMA2k Measurement Interactive Panel.
    RFmx CDMA2k palette VIs are available from the Functions » Measurement I/O » RFmx » CDMA2K palette.
    Documentation for RFmx CDMA2k is located at Start » National Instruments » RFmx CDMA2k Documentation.
    You can access all the installed RFmx CDMA2k examples at Start » National Instruments » RFmx CDMA2k Examples.
    The following is the behavior change in RFmx CDMA2k 2023 Q3 from RFmx CDMA2k 2023 Q2
    The following is the behavior change in RFmx CDMA2k 2022 Q4 from RFmx CDMA2k 2022 Q3
    • RFmx CDMA2k drops support for 32-bit user mode.
    The following is the behavior change in RFmx CDMA2k 20.7 from RFmx CDMA2k 20.6.
    GMT+8, 2026-1-13 11:10
