查看: 12|回复: 0
[NI驱动程序] NI-Industrial Communications for CANopen 2025 Q4 Win11 32bitEng NI-CANopen仪器通信驱动程序25.8.0
  • 签到天数: 3711 天
    连续签到: 38 天
     楼主| 发表于 9 小时前 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-Industrial Communications for CANopen可帮助您创建符合CiA DS-301标准的CANopen主应用程序。
    NI-Industrial Communications for CANopen是一款驱动程序软件,为您使用CANopen接口设备、C系列CANopen接口模块和PXI CANopen接口模块提供所需的支持。它包含丰富的LabVIEW VI和属性库,因此您可以为兼容的硬件设备开发自定义的CANopen应用程序。
    发布日期:2025/10/10
    包含的版本:2025 Q4,版本号25.8.0
    应用程序位数:32位
    Windows Server 2025
    语言:中文/德语/日语/法语/英文/韩语
    程序位数:32位
    文件大小: 1774026752 字节 (1.65 GB)
    修改日期: 2025-11-03 11:29
    MD5: 335ad13b4e8dd64a742711a4ae5c72ad
    SHA1: 42e89a160759b08fb0560fce21775cafcec74c15
    SHA256: bb5af75f605adc4cf33bc13cc69034f0d680bd1d1482f2366b1c792b24d6a9f8
    CRC32: db7cffdd
    请注册登录视觉论坛账号,购买附件查看下载地址
    NI-Industrial Communications for CANopen2025Q4.txt (564 Bytes, 下载次数: 0, 售价: 10 圆)
    2025Q4未更新自述文件,参考2022Q4版本
    NI-Industrial Communications for CANopen 2022 Q4 Readme
    October 2022
    This file contains important information about the NI-Industrial Communications for CANopen, including supported application software and hardware, installation instructions, and new features.
    • NI-Industrial Communications for CANopen Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-Industrial Communications for CANopen Manuals: New features, behavior changes, and other documentation
    Caution  The NI-Industrial Communications for CANopen 18.0 software or later requires the NI-9881 module with the updated firmware. When you upgrade the software to the 18.0 version or later, check the software version of the media that shipped with the NI-9881 module. If the version is not 18.0 or later, or you are not sure of the version number, NI recommends that you update the firmware. Otherwise, when you use NI-Industrial Communications for CANopen 18.0 or later, firmware images corrupt or get mismatched. Ensure that you have appropriate hardware and software installed and complete the following task to upgrade the firmware.
    • Double-click Firmware_Update_Instructions.html in the \NI-IndCom for CANopen directory and follow the instructions to use a LabVIEW example project to update the firmware.
    The NI-Industrial Communications for CANopen software contains an extensive library of VIs and properties in LabVIEW. Use these VIs and properties to program CANopen master applications that comply with the CiA DS-301 standard. You can deploy the applications to RT targets. This software also provides built-in functionality for device configuration and online test panel in LabVIEW.
    NI-Industrial Communications for CANopen supports the following operating systems:
    Note    NI-Industrial Communications for CANopen no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    Refer to Supported Hardware and Software for NI-Industrial Communications for CANopen, for a complete list of NI hardware and software supported by each NI CANopen interface.
    The following table lists the application software versions, including service packs, supported by NI-Industrial Communications for CANopen. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by NI-Industrial Communications for CANopen
    LabVIEW2019 or later
    LabVIEW Real-Time Module2019 or later
    Download the NI-Industrial Communications for CANopen installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Installing the Software on an RT Target
    Complete the following steps to install the NI-Industrial Communications for CANopen software on an RT target in NI Measurement & Automation Explorer (MAX):
    • Expand Remote Systems in the configuration tree and expand your RT target.
    • Select the Software category. Click the Add/Remove Software icon on the toolbar to launch the LabVIEW Real-Time Software Wizard.
    • If the RT target is a CompactRIO controller, select Custom software installation.
    • Select NI-Industrial Communications for CANopen x from the feature list and click the Next button.
    • Follow the remaining installation instructions until installation is complete.
    The "NI-Industrial Communications for CANopen Support for LabVIEW" package supports applications using NI-Industrial Communications for CANopen ​with LabVIEW 2022 or later. When installing NI-Industrial Communications for CANopen, this package will be recommended if you have already installed LabVIEW 2022 or later and installs to the LVAddons directory.
    New FeaturesCANopen 2022 Q4
    • Added support for LabVIEW 2022 (32-bit).
    CANopen 21.5
    • Added support for LabVIEW 2021 (32-bit).
    • Added support for PXI and PXIe controllers with NI Linux RealTime through .ipk installation
    CANopen 20.0
    • Added support for LabVIEW 2020 (32-bit).
    The following are the behavior changes in CANopen 2022 Q4 from CANopen 21.5.
    • Extended the LabVIEW version support with NI Linux RealTime to include LabVIEW 2020 and later.
    Refer to the NI-Industrial Communications for CANopen Help, accessible by selecting Help»NI-Industrial Communications for CANopen in LabVIEW, for information about using the NI-Industrial Communications for CANopen software.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the NI-Industrial Communications for CANopen software are in the labview\examples\NI-Industrial Communications for CANopen folder. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    © 2011–2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-11-13 18:27
