查看: 310|回复: 0
[NI驱动程序] NI-DMM 2025 Q4 Driver Win11 32/64bitEng/JPN NI数字万用表驱动程序25.8.0下载
    5 小时前
  • 签到天数: 3787 天
    连续签到: 38 天
     楼主| 发表于 2025-11-13 08:27:42 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-DMM
    NI-DMM支持使用NI数字万用表的客户。
    NI-DMM是与所有NI可编程数字万用表(DMM)进行通信必需的NI仪器驱动程序。NI-DMM是一种兼容可互换虚拟仪器(IVI)的仪器驱动程序,提供了一系列操作和属性,可以执行波形或信号发生器的功能,而且包含了交互式软件前面板和示例。
    NI-DMM 2025 Q4
    发布日期:2025/10/10
    包含的版本:2025 Q4完整版,版本号25.8.0
    Windows Server 2025
    语言:英文English/日语Japanese
    文件大小: 4421120000 字节 (4.12 GB)
    修改日期: 2025-11-03 11:01
    MD5: edfb61519fe4e139f5df52f308d698c3
    SHA1: fd14e41ed7a7974bbd59cf65a4c0231baeb42c4b
    SHA256: be59d418bf2a93a791fae9a6f666d9ddc222410079e5acee64098cb30cd0d026
    CRC32: dd84e7e7
    请注册登录机器视觉论坛后台,购买附件查看下载地址
    NI-DMM2025Q4.txt (506 Bytes, 下载次数: 0, 售价: 10 圆)
    2025Q4未更新自述文件,参考2023Q3版本
    NI-DMM 2023 Q3 Readme
    This file contains installation instructions and compatibility information for NI-DMM 2023 Q3.
    • NI-DMM Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-DMM Documentation: New features, behavior changes, and other documentation
    NI-DMM 2023 Q3 has the following requirements:
    Minimum System Requirements
    • RAM—1 GB, 800 MHz DDR2 RAM
    Recommended System
    NI-DMM 2023 Q3 supports the following operating systems:
    • NI Linux® Real-Time
    Note  NI-DMM no longer supports any 32-bit Windows operating system. Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes.
    NI-DMM 2023 Q3 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by NI-DMM
    LabVIEW2020 and later
    LabVIEW Real-Time Module2020 and later
    LabWindows/CVI Real-Time Module2019 and later
    If you are using the NI-DMM .NET Class Library, the .NET Framework 4.0 (minimum) is required. The NI-DMM .NET Class Library can be used with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET Framework 4.0 or the .NET Framework 4.5.
    To use the .NET API, you must select the .NET Framework 4.0 Languages Support or the .NET Framework 4.5 Languages Support packages in the NI-DMM installer to install the .NET class libraries in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to .NET Resources for NI Hardware and Software.
    Python Support
    For more information on installing and using Python, refer to the nidmm module.
    Download the NI-DMM installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager.
    Note
    The "NI-DMM Support for LabVIEW" package supports applications using NI-DMM ​with LabVIEW 2022 or later. When installing NI-DMM, this package will be recommended if you have already installed LabVIEW 2022 or later and installs to the LVAddons directory.
    Refer to the NI Digital Multimeters Help, accessible from Start»All Programs»National Instruments» NI-DMM»NI-DMM Documentation, for information about NI-DMM.
    You can access all the installed NI-DMM examples at Start»All Programs»National Instruments»NI-DMM»NI-DMM Examples and online at ni.com/examples.
    Select Help»Find Examples from LabVIEW or LabWindows/CVI to launch the NI Example Finder. LabVIEW examples for NI-DMM are located in the LabVIEW XXXX\examples\instr\niDMM directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    • Click the Browse tab to locate modulation examples by task at Hardware Input and Output»Modular Instruments»NI–DMM or by directory structure at instr»niDMM.
    • Click the Search tab to search all installed examples by keyword. For example, search for "DMM" to locate all NI-DMM examples.
    NI-DMM no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2026-1-29 14:11
