查看: 6|回复: 0
[NI驱动程序] NI-DCPower 2024 Q1 Patch 1 Win11 32/64bit En/Ja NI DC电源仪器驱动程序24.0.1
    7 小时前
  • 签到天数: 3710 天
    连续签到: 37 天
     楼主| 发表于 4 小时前 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-DCPower
    NI-DCPower自20.7版本开始,仅支持64位Win10、Win Server 2016、Win Server 2019系统,但是仍然可支持32位的LabVIEW。自2022 Q3版开始,支持Win11。
    发布日期:2024/11/7
    包含的版本:2024 Q1 Patch 1完整版,版本号24.0.1
    语言:English/Japanese
    文件大小: 2862575616 字节 (2.67 GB)
    修改日期: 2025-11-12 08:59
    MD5: 89538fa4d51b02536903ef4fc1ccd155
    SHA1: b93a150f31b5f216e6533b1ada3b6d276a594eb9
    SHA256: 2db95f409a80c279b724d0cca00e72c741e62e15e58ce4cfb5a85d21835a4bde
    CRC32: c42f7b25
    NI-DCPower 2024 Q1 Patch 1.txt (576 Bytes, 下载次数: 0, 售价: 10 圆)
    2024Q1Patch1未更新自述文件,参考2023Q3版本。
    NI-DCPower 2023 Q3 Readme
    This file contains installation instructions and compatibility information for NI-DCPower 2023 Q3.
    • NI-DCPower Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-DCPower Documentation: New features, behavior changes, and other documentation
    NI-DCPower 2023 Q3 has the following requirements:
    Minimum System Requirements
    • RAM—1 GB, 800 MHz DDR2 RAM
    Recommended System
    NI-DCPower 2023 Q3 supports the following operating systems:
    • NI Linux® Real-Time1
    1 NI Linux Real-Time does not support the following features:
    • Autopopulation of resource names in LabVIEW 2020 and earlier
    • Test panels as accessible from NI Measurement & Automation Explorer (MAX)
    NI-DCPower 2023 Q3 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support or Python Support.
    Versions Supported by NI-DCPower 2023 Q3
    LabVIEW2020 and later
    LabVIEW Real-Time Module2020 and later
    LabWindows/CVI Real-Time Module2019 and later
    If you are using the NI-DCPower .NET Class Library, the .NET Framework 4.0 (minimum) is required. The NI-DCPower .NET Class Library can be used with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET Framework 4.0 or the .NET Framework 4.5.
    To use the .NET API, you must select the .NET Framework 4.0 Languages Support or the .NET Framework 4.5 Languages Support packages in the NI-DCPower installer to install the .NET class libraries in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to .NET Resources for NI Hardware and Software.
    Python Support
    For more information on installing and using the NI-DCPower Python API, refer to the nidcpower module.
    Download the NI-DCPower 2023 Q3 installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Note
    • If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. For more information and steps to resolve this issue, refer to NI Installer Hangs While Installing Visual C++ 2015 Run-Time.
    When installing NI-DCPower, the "NI-DCPower Support for LabVIEW" package will be recommended if you have already installed LabVIEW 2022 or later and installs to the LVAddons directory. This package supports applications using NI-DCPower with LabVIEW 2022 or later.
    • Support for PXIe-4162 Asymmetrical Compliance Limit
    • Support for PXIe-4162 Measurement Autorange
    Note: Some compatibility information may only be available in the archive attached to the NI Hardware and Software Operating System Compatibility page. For historic driver and OS support information, refer to the readme for the relevant driver version.
    NI-DCPower 21.0: The NI-DCPower Soft Front Panel has been replaced by InstrumentStudio, which is automatically installed when you install the NI‑DCPower driver. You can access InstrumentStudio in one of the following ways:
    • From the Windows start menu, select National Instruments»InstrumentStudio. This launches InstrumentStudio and runs a soft front panel populated with devices detected on your system.
    • From Measurement & Automation Explorer (MAX), select a device and then click Test Panels.... This launches InstrumentStudio and runs a soft front panel for the device you selected.
    The deprecated NI-DCPower Soft Front Panel remains available for download. Visit Legacy Soft Front Panels for NI-DCPower, NI-DMM, NI-FGEN, and NI-SCOPE for more information.
    Refer to the NI DC Power Supplies and SMUs Help accessible from Start»All Programs»National Instruments»NI-DCPower»NI-DCPower Documentation, for information about NI-DCPower.
    Select Help»Find Examples from LabVIEW or LabWindows/CVI to launch the NI Example Finder.
    • LabVIEW 2021 or older: Examples for NI-DCPower are located in the LabVIEW XXXX\examples\instr\niDCPower directory.
    • LabVIEW 2022 or later: Examples for NI-DCPower are located in the C:\Program Files\NI\LVAddons directory.
    You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    • Click the Browse tab to locate examples by task at Hardware Input and Output»Modular Instruments»NI–DCPower or by directory structure at instr»niDCPower.
    • Click the Search tab to search all installed examples by keyword. For example, search for "DCPower" to locate all NI-DCPower examples.
    NI-DCPower no longer installs IVI Compliance Package. NI-DCPower supports IVI configuration and runtime, but no longer supports the following features:
    • IVI-COM Adapters
    NI-DCPower no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2025-11-12 16:04
