NI Vehicle Communication Diagnostic Toolkit 2025 Q3 Patch 2 Win11 64bitEng 车辆通信诊断工具包VCDT25.5.2
Vehicle Communication Diagnostic工具包可与支持NI-XNET的设备配合使用,为电子控制单元(ECU)设计和验证提供诊断应用程序。
Vehicle Communication Diagnostic工具包是车辆通信工具包的软件附加Vehicle Communication工具包。该工具包可与诊断数据库文件(PDX)和MCD-3D服务器(未包含在诊断工具包中)配合使用,以执行诊断服务、读取诊断故障代码和刷新ECU。该工具包提供了一个用于Windows操作系统的LabVIEW和C/C++的API以及一个Web诊断数据库查看器。
发布日期:2025/7/23
包含的版本:2025 Q3 F2基本版,完整版,版本号25.5.2
Windows Server 2025
语言:英文English
文件大小: 1560434688 字节 (1.45 GB)
修改日期: 2025-08-19 18:32
MD5: fc2736f19eea73befc8e8d25d97f246c
SHA1: 59c29aac2a330a866d21c10f4c835a586193b613
SHA256: 48d62b1898fe52f4b50646159b07e511daa8569a3c3ee9c6749a5f3d0f0c1ebd
CRC32: 0e3ece1a
注册登录视觉论坛账号,购买附件查看下载地址
Vehicle Communication Diagnostic 2025Q3F2.txt
(585 Bytes, 下载次数: 0, 售价: 10 圆)
2025Q3F2未更新自述文件,参考2023Q1版
Vehicle Communication Software Suite 2025 Q3 Changes
Vehicle Communication Toolkit (NI-VCOM) New Features
- Support for LabVIEW 2025
- Support for VeriStand 2025
- Support for proto files in Ethernet Tap Mode
- Support for the enumerator, string, and array data types in the LabVIEW API
- Bug fixes and performance improvements
- Improvements to enhance user experience, including:
- Switch to Dark Mode to improve your viewing experience
- Expand the RestBus page data into tree view
- Use drop-down field suggestions for properties
Vehicle Communication Software Suite 2025 Q1 Changes
- Adds support for making the extended CAN ID settable separately for DTO messages and CRO messages.
- Adds support for text tables in the NI-VCOM LabVIEW API enum data type.
- Adds support for the Protobuf workflow.
- Adds optimized performance for the NI-VCOM custom device engine, allowing you to execute more channels with VeriStand.
Vehicle Communication Software Suite 2024 Q4 Changes
- Adds support for array signals in the NI-VCOM custom device.
- Adds support for measurement signal arrays in the Measurement and Calibration Toolkit.
Vehicle Communication Software Suite 2024 Q3 Changes
Vehicle Communication Toolkit New Features
- Base and Full Versions:
- Adds support for separate activation of the extended CRO (request) and DTO (response) CAN IDs
- Full Version Only:
- Adds support for CAN FD activation in the Measurement and Calibration Toolkit
- Adds support for Toyota OEM-specific Secure Onboard Communication for CAN .dbc files
- Adds support for AUTOSAR E2E Profile 11A and 11C for CAN/CAN-FD, Flexray, Automotive Ethernet, and SOME/IP messages
- Adds support for cyclic transmission mode for Automotive Ethernet and SOME/IP messages
Vehicle Communication Software Suite 2024 Q1 Changes
Learn about new features, behavior changes, and other updates in Vehicle Communication Software Suite 2024 Q1. Vehicle Communication Toolkit New Features
- Upgrades supported version of LabVIEW to 2024 Q1
- Upgrades supported version of VeriStand to 2024 Q1
- Adds support for a Bus monitor
- Adds support of byte array data type signals in the NI-VCOM custom device and LabVIEW API
- NI-VCOM has a new database viewer for RBS, the Calibration Toolkit, and the Diagnostic Toolkit. The new database viewer allows a more hierarchical and dense view of database content and provides a smoother search experience.
- The Read Signal - State RBS VI in the NI-VCOM LabVIEW API is now named Read (State VCOM).vi. Update the name of the VI if you use this API in your NI-VCOM application.
Vehicle Communication Software Suite 2023 Q3 Changes
Learn about new features, behavior changes, and other updates in Vehicle Communication Software Suite 2023 Q3. Vehicle Communication Toolkit New Features
- Adds support for J1939 protocol
- Adds support for CAN and LIN virtual devices
- Adds support for multiple VCOM custom devices, each with unique configurations, in the same VeriStand project containing multiple controllers. Each controller can be associated with one VCOM custom device.
- Adds support for LabVIEW API signal selection in the Read and Write VIs.
- Adds support for deploying configuration files to remote targets from the WebUI rather than manually copying files between machines.
- Adds performance improvements for importing large .arxml files and large numbers of signals.
- Adds support for optional Diagnostic Toolkit
- Adds support for AUTOSAR Global Time Synchronization
- The VeriStand Custom Device is now called NI:VCOM rather than Provetech:RBS
- The VeriStand Custom Device API is now located on the NI-VCOM:Restbus simulation palette
- The Measurement and Calibration Toolkit is now configured automatically.
- The VCOM custom device now creates channels that are not scalable by default, but you can set them to be scalable if necessary.
Vehicle Communication Measurement and Calibration Toolkit 2023 Q1 ReadmeMarch 2023 This file contains installation instructions and compatibility information for Vehicle Communication Measurement and Calibration Toolkit 2023 Q1 (Measurement and Calibration Toolkit). You can find more release information on ni.com. - Measurement and Calibration Toolkit Release Notes: Known issues and other notes about this release
- Measurement and Calibration Toolkit Documentation
System Requirements Supported Operating Systems Application Software Support Installation Instructions Product Security and Critical Updates Accessing the Documentation Finding Examples Automating the Installation of NI Products Using NI Software with Microsoft Windows 10 System RequirementsMeasurement and Calibration Toolkit 2023 Q1 has the following requirements: - At least 3 GB of disk space
Refer to the LabVIEW Readme for additional system requirements and supported operating systems for supported LabVIEW versions. Supported Operating SystemsMeasurement and Calibration Toolkit 2023 Q1 supports the following operating system: Measurement and Calibration Toolkit 2023 Q1 supports the following communication buses: - CAN/CAN-FD
- FlexRay
- Automotive Ethernet
Application Software SupportMeasurement and Calibration Toolkit 2023 Q1 supports the following application software versions, including service packs. Application Software | Versions Supported by Measurement and Calibration Toolkit 2023 Q1 | | LabVIEW (32- and 64-bit) | 2020, 2021, 2022, 2023 | Installation InstructionsYou must install the Vehicle Communication Toolkit before installing the Measurement and Calibration Toolkit. Refer to the Vehicle Communication Toolkit (Full) Readme or the Vehicle Communication Toolkit (Base) Readme for installation instructions. Download the Measurement and Calibration Toolkit installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager. After installing your software, you will need to activate it. Activating your software verifies the licenses associated with your NI account, so you can start using your software. You have different options for activation, based on your software and how it was purchased. Please visit ni.com/activate for more information on activation methods. If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue. Updated LabVIEW Compatibility PolicyThe "Measurement and Calibration Toolkit Support for LabVIEW" package supports applications using the Measurement and Calibration Toolkit with LabVIEW 2020 or later. When installing the Measurement and Calibration Toolkit, this package will be recommended if you have already installed LabVIEW 2020 or later and it installs to the LabVIEW VI library. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. For information about critical updates from NI, refer to Available Critical and Security Updates for NI Software. Accessing the DocumentationRefer to the Vehicle Communication Toolkit documentation, accessible from ni.com/docs, for information about the Measurement and Calibration Toolkit. Finding ExamplesSelect Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Measurement and Calibration Toolkit are located in the LabVIEW\examples\Vehicle Communication Measurement and Calibration Toolkit directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create. A demo ECU application for the Measurement and Calibration Toolkit is located in the %Public%\Documents\National Instruments\NI-VCOM\Examples\Measurement and Calibration Toolkit\Demo ECU directory. Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager documentation. Using NI Software with Microsoft Windows 10For more information about NI support for Windows 10, refer to NI Product Compatibility for Microsoft Windows 10.
