查看: 117|回复: 0
[NI软件产品] NI RFmx W-CDMA/HSPA+ 2025 Q3 Patch 2 Win11 64bitENG RFmx W-CDMA/HSPA/HSPA+蜂窝测试25.5.2
  • 签到天数: 3691 天
    连续签到: 18 天
     楼主| 发表于 2025-9-28 11:00:29 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    RFmx W-CDMA/HSPA+
    发布日期:2025/7/23
    包含的版本:2025 Q3 F2完整版/运行版,版本号25.5.2
    Windows Server 2025
    64位完整版校验和:
    文件大小: 2629058560 字节 (2.45 GB)
    修改日期: 2025-08-19 13:32
    MD5: 72090b988f8033d6cd6adfbcd4d0bd4b
    SHA1: a364c3a441e915e46be7548d27c362b23f52824e
    SHA256: 81b5007dd6279a0b15091e49104f45cf16cd60abc502cfaf49fdd3c913504a2a
    CRC32: a1425d65
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFmx W-CDMA 2025Q3F2.txt (553 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 1026983936 字节 (979.41 MB)
    修改日期: 2025-08-19 13:22
    MD5: fdb42165fcdfd208591df65236683a45
    SHA1: be4b6477d6cf2584f40be21c09195cdbb27e643d
    SHA256: 670e8a1cec94556b4fc369998c9e6b3706e6ab4b1dc25771dbdbb4c579052af0
    CRC32: c533102f
    RFmx W-CDMA 2025Q3F2RTE.txt (578 Bytes, 下载次数: 0, 售价: 5 圆)
    2025Q3F2版未更新自述文件,参考2023Q3版本。
    RFmx WCDMA 2023 Q3 Readme
    • RFmx WCDMA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx WCDMA Manuals: New features, behavior changes, and other documentation
    Installed Software
    RFmx WCDMA 2023 Q2 includes the following new feature:
    RFmx WCDMA 2023 Q1 includes the following new feature:
    RFmx WCDMA 2022 Q4 includes the following new feature:
    • Support for PXIe-5842
    RFmx WCDMA 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx WCDMA no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx WCDMA 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx WCDMA 2023 Q3 to an unsupported OS. Additionally, after installing RFmx WCDMA 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx WCDMA supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx WCDMA. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx WCDMA (64-bit only)
    Required Software
    Download the RFmx WCDMA installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx WCDMA. For more information on RFmx WCDMA activation, refer to National Instruments Software Activation.
    Installed Software
    Item
    Installed Location
    Import Library files
    RFmx WCDMA palette VIs are available from the Functions » Measurement I/O » RFmx » WCDMA palette.
    Documentation for RFmx WCDMA is located at Start » National Instruments » RFmx WCDMA Documentation.
    You can access all the installed RFmx WCDMA examples at Start » National Instruments » RFmx WCDMA Examples.
    The following is the behavior change in RFmx WCDMA 2023 Q3 from RFmx WCDMA 2023 Q2
    The following is the behavior change in RFmx WCDMA 2022 Q4 from RFmx WCDMA 2022 Q3
    • RFmx WCDMA drops support for 32-bit user mode.
    The following is the behavior change in RFmx WCDMA 2022 Q3 from RFmx WCDMA 21.8.2
    The following is the behavior change in RFmx WCDMA 20.7 from RFmx WCDMA 20.6.
    GMT+8, 2025-10-24 19:04
