NI RFmx Pulse 2025 Q3 Patch 2 Win11 64bitENG RFmx脉冲分析仪25.5.2
RFmx Pulse
RFmx Pulse可帮助您执行交互式和自动化脉冲分析测量。
RFmx Pulse是一款测量专用软件,可扩展NI RF仪器的脉冲分析功能,例如PXI矢量信号分析仪和PXI矢量信号收发器。借助RFmx Pulse,您可以通过脉冲轮廓测量(例如时间、电平、相位和频率)以及FM线性调频调制测量和幅度和相位的脉冲稳定性测量来分析脉冲信号。
发布日期:2025/7/23
包含的版本:2025 Q3F2完整版/运行版,版本号25.5.2
Windows Server 2025
64位完整版校验和:
文件大小: 2621325312 字节 (2.44 GB)
修改日期: 2025-08-19 18:50
MD5: a0265f931bd4d9f13a232566d747613d
SHA1: 15acae5b3ab388594382b75073d667f60e219c4d
SHA256: a134afe3b7d2d4e9a8e897a6eceb1aacf0097b96445db54b032cb0fc4356f414
CRC32: fa647f10
NI官方下载和百度网盘下载地址:
RFmx Pulse 2025Q3F2.txt
(546 Bytes, 下载次数: 0, 售价: 10 圆)
64位运行版校验和:
文件大小: 1021992960 字节 (974.65 MB)
修改日期: 2025-08-19 18:49
MD5: 002a88c7a57c0a8edc07d641a6bca623
SHA1: 6712c52999eed9be4afc882088f92046fd93c97a
SHA256: 6384c67983d07a7dceb3f99e7abd1375f7ed3a4d39350b531bfd5f7556e52df7
CRC32: 13ab4baa
NI官方下载和百度网盘下载地址:
RFmx Pulse 2025Q3F2RTE.txt
(571 Bytes, 下载次数: 0, 售价: 5 圆)
2025Q3F2版未更新自述文件,参考2023Q3版
RFmx Pulse 2023 Q3 ReadmeJuly 2023 This file contains important information about the RFmx Pulse, including system requirements, and installation instructions. You can find more release information on ni.com. - RFmx Pulse Release Notes: Known issues, and other notes about this release
- RFmx Pulse Manuals: Features overview and other documentation
Overview of Features Supported Hardware System Requirements Supported Operating Systems Application Software Support Installation Instructions Installed Software File Locations Executable Accessing the API Accessing the Documentation Finding Examples Product Security and Critical Updates Automating the Installation of NI Products Using NI Software with Microsoft Windows 11 Overview of FeaturesRFmx Pulse 2023 Q3 includes the following features: - Support for Pulse profile measurement results
- Time
- Rise Time, Fall Time, Pulse Width and PRI
- Level
- Top level, Base level, ON level, Droop, Overshoot, Ripple
- Phase and Frequency
- Average, Deviation and Error
- Support for FM Chirp modulation results
- Support for Pulse Stability measurements
- Amplitude, Phase and Total
- Support for Segmented and Single large record in Signal Acquisition methods
Supported HardwareVisit NI Hardware and Software Operating System Compatibility to view driver, desktop operating system, and real-time operating system support for individual hardware devices. To view information for your device: - Select your hardware model in the dropdown list on the page to view compatibility information for your device.
Note: Some compatibility information may only be available in the archive attached to the NI Hardware and Operating System Compatibility page. For historic driver and OS support information, refer to the readme for the relevant driver version. System RequirementsRFmx Pulse has the following requirements: - Processor—1 GHz 64-bit (x64) processor
- 4 GB RAM *
- Any supported OS, with all available critical updates and service packs
* Depending on the amount of data acquired and/or processed, a larger amount of memory may be required. Supported Operating SystemsRFmx Pulse 2023 Q3 supports the following 64-bit operating systems: - Windows 11
- Windows 10
- Windows Server 2022
- Windows Server 2019
- Windows Server 2016
Application Software SupportRFmx Pulse supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx Pulse. If you are not using NI application software, refer to Microsoft Visual Studio Support. Application Software | Versions Supported by RFmx Pulse (64-bit only) | | LabVIEW | 2020 SP1, 2021 SP1 f1 patch, 2022 Q3, 2023 Q1, 2023 Q3 | Required Software- NI-RFSA 14.1 or later
- NI-RFSA 17.1 or later (for initializing debug session when "using breakpoints in C/C++/.NET application" is selected)
Microsoft Visual Studio SupportIf you are using the RFmx Pulse .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx Pulse .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5. Installation InstructionsDownload the RFmx Pulse installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager. Notes - If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue.
- Use the serial number that is included with your software to activate RFmx Pulse. For more information on RFmx Pulse activation, refer to National Instruments Software Activation.
Installed Software- is an alias for the following National Instruments file folder location:
- Program Files (x86)\National Instruments\MeasurementStudioVS2010
- is an alias for the following file folder location:
- Windows\system32 for 64-bit programs
File LocationsItem | Installed Location | | Version Compatibility Checker | \RFmx\niRFmxCompatibility_Checker.exe | | Debug Configuration Utility | \RFmx\niRFmxDebugConfigurationUtility.exe | | DLLs | | | Header files | \Shared\ExternalCompilerSupport\C\include | | Import Library files (64-bit) | \Shared\ExternalCompilerSupport\C\lib64\msvc | | .NET Class Libraries | | Assemblies | \DotNET\Assemblies\Current\NationalInstruments.RFmx.PulseMX.Fx40.dll
\DotNET\Assemblies\Current\NationalInstruments.Common.dll | ExecutableSelect Start » National Instruments » InstrumentStudio to launch the InstrumentStudio. Accessing the APIRFmx Pulse palette VIs are available from the Functions » Measurement I/O » RFmx » Pulse palette. Accessing the DocumentationDocumentation for RFmx Pulse is located at Start » National Instruments » RFmx Pulse Documentation. Finding ExamplesYou can access all the installed RFmx Pulse examples at Start » National Instruments » RFmx Pulse Examples. For the most recent revisions of documentation and for newly released documentation, visit ni.com/manuals. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. For information about critical updates from NI, refer to Available Critical and Security Updates for NI Software. Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.6.2, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software. For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager manual. Using NI Software with Microsoft Windows 11Microsoft Windows 11 is the latest version of the Windows operating system and features significant changes compared to previous versions. For more information about NI support for Windows 11, refer to NI Product Compatibility for Microsoft Windows 11. |
