查看: 69|回复: 0
[NI软件套件] HIL and Real-Time Test Software Suite 2025 Q3 Win11 64bitEn 硬件在环和实时测试软件套件2025Q3版-64位英文
    6 小时前
  • 签到天数: 3651 天
    连续签到: 13 天
    HIL and Real-Time Test Software Suite是用于验证嵌入式软件和运行模型物理测试的软件集合。
    HIL and Real-Time Test Software Suite将LabVIEW集成开发环境(IDE)与应用软件和模块相结合,用于创建实时测试应用程序。借助该套件,您可以开发仿真模型和控制算法,并将其部署到实时硬件中。您还可以添加自定义功能,确保测试系统具有足够的灵活性来满足几乎任何应用需求,此外,您还可以在NI可重配置I/O硬件上执行高速仿真和处理。
    发布日期:2025/7/18
    包含版本:2025 Q3专业版,版本号25.5.0
    Windows Server 2025
    语言:英文English
    文件大小: 29987516416 字节 (27.93 GB)
    修改日期: 2025-07-23 10:25
    MD5: 07250a7578c5643a066ca917874d3893
    SHA1: 242f798def2ff10c65c132026245457a2c6416d9
    SHA256: 3d32d89fe42d899d192c4212eb0ee006e03614427454e36def36874e9f82571e
    CRC32: 5f66e0bb
    请注册登陆机器视觉论坛账号,购买附件查看下载地址
    HIL-RT TSS2025Q3x64En.txt (646 Bytes, 下载次数: 0, 售价: 40 圆)
    套件包含产品:
    编程环境
    ProductVersionBitness
    LabVIEW2025 Q332-bit and 64-bit
    应用软件
    VeriStand2025 Q364-bit
    附加软件
    VeriStand Model Generation  Support for LabVIEW 20252025 Q364-bit
    VeriStand自定义设备2025 Q164-bit
    VeriStand Model Framework2025 Q164-bit
    驱动程序
    NI-SLSC2025 Q164-bit
    PXI Platform Services2025 Q332-bit and 64-bit
    NI-488.22025 Q332-bit and 64-bit
    NI-DCPower2025 Q332-bit and 64-bit
    NI-Industrial Communications for  EtherCAT2025 Q232-bit and 64-bit
    NI-SWITCH2025 Q332-bit and 64-bit
    2025Q3版未更新自述文件,参考2023Q1版。
    HIL and Real-Time Test Software Suite 2023 Q1 Readme
    January 2023
    This file contains installation instructions and compatibility information for HIL and Real-Time Test Software Suite 2023 Q1.
    • HIL and Real-Time Test Software Suite Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    Products Included in the HIL and Real-Time Test Software Suite
    HIL and Real-Time Test Software Suite 2023 Q1 supports the following operating systems:
    The following products are included in the HIL and Real-Time Test Software Suite installer. This may not be a complete list of products that are activatable by your bundle serial number. Refer to the readme of each product for information including system requirements, installation, activation, known issues, and bug fixes.
    Application Software
    Version
    Bitness
    VeriStand202364-bit
    Add-ons
    Version
    Bitness
    JKI VI Package Manager2023 Q132-bit and 64-bit
    VeriStand Model Framework202132-bit and 64-bit
    VeriStand Model Generation Support for LabVIEW 2023 Q12023 Q132-bit and 64-bit
    Drivers
    Version
    Bitness
    NI-Industrial Communications for EtherCAT2023 Q132-bit and 64-bit
    Note: Some drivers included with previous versions of HIL and Real-Time Test Software Suite are not included with this release. Visit ni.com/downloads for the latest driver versions.
    If you are using the HIL and Real-Time Test Software Suite .NET Class Library, .NET Framework 4.0 (minimum) is required. The HIL and Real-Time Test Software Suite 2023 Q1 .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the HIL and Real-Time Test Software Suite installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    • Use the serial number that is included with your software to activate HIL and Real-Time Test Software Suite 2023 Q1. For more information on HIL and Real-Time Test Software Suite 2023 Q1 activation, refer to Activating a Product.
    Complete the following steps to install products using the HIL and Real-Time Test Software Suite media.
    • Insert the HIL and Real-Time Test Software Suite installation media.
    Save the original installation media in order to modify or repair your installation or to distribute NI software with your custom-built installers.
    Installing LabVIEW Add-Ons
    Installing LabVIEW add-ons, such as modules and toolkits, from the HIL and Real-Time Test Software Suite media ensures compatibility. Some versions of LabVIEW add-ons that are not found on the HIL and Real-Time Test Software Suite media may not work with the version of LabVIEW included in this release. Installing an incompatible add-on might cause some features in the add-on or LabVIEW to behave incorrectly.
    HIL and Real-Time Test Software Suite no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2025-9-13 16:13
