查看: 521|回复: 0
[TestStand] NI TestStand 2024 Q4 Patch 1 Win11 32bitENG NI测试序列管理软件32位离线安装版TestStand24.8.1-x86
    5 小时前
  • 签到天数: 3787 天
    连续签到: 38 天
     楼主| 发表于 2025-9-1 14:23:19 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    TestStand是一款旨在帮助测试和验证工程师快速构建和部署自动化测试系统的应用软件。自TestStand2010版开始,TS版本号由数字改为年代版本。自TestStand2014版开始,增加TS64位版本。
    TestStand是一款可立即运行的测试管理软件,可帮助您快速开发自动化测试和验证系统。您可以使用TestStand来开发、执行和部署测试系统软件。还可以通过在TestStand中开发测试序列来扩展系统的功能,这些测试序列可集成使用任何编程语言编写的代码模块。TestStand还为报告生成、数据库记录以及与其他企业系统的连接提供了可扩展的插件。您可以使用易用的操作界面将测试系统部署到生产环境中。
    发布日期:2025/1/15
    包含的版本:2024 Q4 Patch 1完整版,版本号24.8.1
    应用程序位数:32位
    文件大小: 2200799232 字节 (2.05 GB)
    修改日期: 2025-09-01 11:26
    MD5: ba6d94ce655b85544586949c7bb21cfa
    SHA1: 531b0835ad36c1f816f46911c61ddeaaf1b82ca7
    SHA256: 5eecc75f1926fb85f0bff89c83e94d6a74b908164325048e341e2e4af06bf711
    CRC32: 1385d54d
    请注册登录视觉论坛账号,购买附件查看下载地址
    TestStand2024Q4F1x86.txt (564 Bytes, 下载次数: 0, 售价: 10 圆)
    TestStand 2024 Q4 Changes
    Learn about new features, behavior changes, and other updates in TestStand 2024 Q4.
    .NET Adapter — .NET Assembly Execution Support
    The .NET adapter now supports .NET 8 for .NET code module execution. You can still execute .NET Framework assemblies using .NET as long as the resources used in the .NET Framework assemblies are present in .NET 8.
    Some items and resources are no longer supported. Consult the following list for some support changes and considerations to take note of when developing with the .NET Adapter and TestStand 2024 Q4:
    • The IOConfig step type no longer works with the .NET Adapter. The device drivers are located in the .NET Framework GAC location, and .NET 8 does not support loading assemblies from the GAC.
    • Creating remote objects in the TestStand .NET step using the CreateRemoteObject method is no longer supported.
    • Calling into the following assemblies is no longer supported:
      • GAC assemblies
      • .NET assemblies with dependencies on GAC assemblies
      • C++/CLI assemblies
    • Consider the following when working with .NET assemblies and LabVIEW:
      • .NET assemblies called by a VI are not automatically added to TestStand deployments. You must manually add these dependencies to deployments they are used in.
      • NET Framework assembly dependencies called by LabVIEW during the execution of a TestStand .NET step must be placed next to these .NET Framework assemblies to prevent runtime execution errors. These dependencies can be found in the LabVIEW installation directory.
      • Passing .NET objects between LabVIEW and TestStand is no longer supported.
    • Sequence Editor layout files from previous TestStand versions are no longer supported.
    • Consider the following when handling TestStand objects in managed code:
      • Explicitly dispose of instances of classes implementing IDisposable.
      • Explicitly assign null to class member variables of TestStand types, like Engine, SequenceContext, and PropertyObject, when the class is no longer in use.
      • Explicitly assign null to static variables of TestStand types, like Engine, SequenceContext, and PropertyObject, before shutting the TestStand Engine down.
    Support for Using Sequence Files Across Multiple Versions of TestStand
    The TestStand Engine no longer updates to a new version with every new release of TestStand. This allows you to use sequence files in multiple versions of TestStand without needing to use Save As to save the file for each version of TestStand you want to use it in. Save As now only needs to be used to run sequence files in versions of TestStand with different engine versions than the version it was originally written in. The engine version of your version of TestStand can be determined by consulting the program information at Help » About TestStand.
    Features from later versions of TestStand are not supported in earlier versions of TestStand, even if the versions run on the same engine version. The TestStand Analyzer can detect these support mismatches and notify the user.
    Support mismatches can also occur in custom types used between versions of TestStand. You can update your custom types according to the recommendations in Modifying Types Without Altering the Version Number to allow the TestStand Analyzer to detect and report support mismatches in custom data types.
    Python Adapter — Support for Python Virtual Environments Created Using 'venv'
    The TestStand Python Adapter now supports Python virtual environments created using the venv tool, in addition to virtual environments created using the earlier virtualenv tool.
    LabVIEW Adapter — Source-Only VI Execution Support Through the Version-Independent Runtime Engine Support Feature
    You can use the Version Independent Runtime Engine Support feature in the LabVIEW Adapter as an option to avoid potential issues when executing source-only VIs using the LabVIEW Runtime Engine through the LabVIEW adapter. These issues can occur if the LabVIEW version that the source-only VI was saved or mass-compiled in does not match the LabVIEW Runtime engine version, as VI version no longer gets updated during a save or mass-compile.
    Auto Login for TestStand Default User
    The default TestStand user account, administrator, no longer launches the login dialog prompting users to log in when launching TestStand. The login dialog only launches if at least one of the following is true:
    • A user clicks on the Login option
    • The administrator account has a configured password
    • Additional user accounts other than administrator are present
    TestStand Sequence Editor Visual Design Updates
    TestStand 2024 Q4 introduces visual changes to the TestStand Sequence Editor designed to provide better contrast in the Sequence Editor, provide relief in the menu and tool bars, and reduce the background colour of Sequence Editor panes.
    New Help Delivery Experience
    TestStand 2024 Q4 help links now direct you to the online TestStand help documentation in the NI documentation portal, ni.com/docs, when your system is connected to the internet. If your system is not connected to the internet, the help links launch the NI Offline Help Viewer that is installed with TestStand to connect you with help documentation. You can also use the NI Offline Help Viewer to launch TestStand help documentation from outside of TestStand.NoteUse the NI Help Preferences application to set the default method for accessing NI product help to online or offline.
    NoteTestStand 2024 Q4 removes offline help documentation sourced in the Microsoft Compiled HTML Help File (.chm) format.
    API and UI Control Additions and Changes
    TestStand 2024 Q4 includes the following new enumeration values, constant values, properties, and methods.
    • Enumeration and Constant Values
      • StepType_If
      • StepType_Else
      • StepType_ElseIf
      • StepType_For
      • StepType_ForEach
      • StepType_While
      • StepType_DoWhile
      • StepType_Break
      • StepType_Continue
      • StepType_Select
      • StepType_Case
      • StepType_End
      • StepType_StreamLoop
      • StepType_SweepLoop
      • StepType_Wait
      • VisualStudioDTEVersion_2022
    • Properties
      • EngineVersionString
      • ChildExecutionIds
      • ParentExecutionId
    • Methods
      • DisplayHelpTopicEx
      • GetExecution
    2024Q4Patch1版未更新自述文件,参考2022Q4版
    TestStand 2022 Q4 Readme
    October 2022
    This file contains installation instructions and compatibility information for TestStand 2022 Q4.
    • TestStand Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • TestStand Documentation: New features, behavior changes, and other documentation
    Activating TestStand Licenses
    Migrating to the Current Version of TestStand
    Additional TestStand Resources
    TestStand is test management software that helps you develop, debug, and deploy test systems and provides full visibility into testing process and results.
    Requirement
    Minimum
    ProcessorPentium 4/M or equivalent
    Available Memory2 GB
    Available Disk space for TestStand (32- or 64-bit)1 GB
    Available Disk space for Microsoft .NET Framework version 4.6.2, if not already installed2.5 GB
    Video adapter1024 x 768 resolution
    (Recommended minimum: 1366 x 768)
    TestStand 2022 Q4 supports the following operating systems:
    Note  TestStand no longer supports any 32-bit Windows operating system. Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes.
    TestStand 2022 Q4 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Supported NI Software for 32-bit TestStand
    Software
    Versions Supported by TestStand 2022 Q4
    Allowed but not Supported
    Comments
    LabVIEW (32- and 64-bit)2022 Q3, 2021 SP1, 2020 SP1, 2019 SP12021, 2020, 2019, 2018 SP1
    LabVIEW examples and user interfaces use files created with LabVIEW 2019 SP1.
    TestStand API support files for LabVIEW use files saved with LabVIEW 2018 SP1.
    TestStand 32-bit supports calling 32-bit VIs using LabVIEW 32-bit RTE, and 32- and 64-bit VIs using the LabVIEW ADE.
    LabWindows™/CVI™2020, 2019, 2017Earlier versions of LabWindows™/CVI™
    LabWindows™/CVI™ examples, user interfaces, and API use files created with LabWindows™/CVI™ 2015 SP1.
    TestStand 32-bit supports calling only 32-bit code modules.
    NI Switch Executive21.5, 2020, 2018, 2015
    Requirements Gateway2018, 2014, 2012
    SystemLink2022 Q4, 2021 R2, 21.5
    Supported NI Software for 64-bit TestStand
    Software
    Comments
    LabVIEW NXGNot supportedThis product no longer supports LabVIEW NXG. Refer to LabVIEW NXG on ni.com for more information about LabVIEW NXG Life-Cycle Dates and driver version support.
    TestStand 64-bit supports calling 64-bit VIs using LabVIEW 64-bit RTE, and 32- and 64-bit VIs using the LabVIEW ADE.
    TestStand 64-bit supports calling only 64-bit code modules.
    NI Measurement Studio - Visual Studio MFC Legacy SupportMeasurement Studio classes cannot be used in 64-bit applications.
    Requirements Gateway2018, 2014, 20121.1
    SystemLink2022 Q4, 2021 R2, 21.5The SystemLink 2021 R2 patch supports TestStand 2021.
    TestStand can execute code modules developed with versions of ADEs other than the listed supported versions, but NI performs only limited testing with earlier versions of ADEs. TestStand might be able to execute code modules developed with versions of ADEs later than the listed supported versions, but NI cannot ensure support for versions released after TestStand 2022 Q4. Visit ni.com/info and enter the Info Code tslcp for more information about the TestStand life cycle policy.
    TestStand 2022 Q4 supports the following Microsoft Visual Studio versions and associated programming languages.
    Microsoft Component
    Full Support
    Not Supported
    Microsoft Visual Studio2019 v16.112019 v16.09 and earlier
    Programming Languages.NET Framework 4.6.2 Languages
    (Visual C#, Visual Basic .NET)
    Note  TestStand does not support Visual Studio Community. TestStand includes features that automate Visual Studio for debugging, generating, and editing code module source code. Visual Studio Community Editions do not support these features.
    The .NET and Microsoft Foundation Class (MFC) examples include projects and solutions created in Visual Studio 2015.
    Python Support
    The Python Adapter in TestStand 2022 Q4 supports the following Python versions:
    Full Support
    Not Supported
    Python3.7, 3.8, 3.9, 3.103.6 or earlier
    Use the following recommended database client software with the database components included with TestStand:
    • Microsoft Access—(64-bit TestStand) Use the Microsoft Office 12.0 Access Database Engine OLE DB Provider. You can download this provider from the Microsoft website at www.microsoft.com.
      Note  You cannot install the Microsoft Office 12.0 Access Database Engine OLE DB Provider with 32-bit Microsoft Office. Visit ni.com/info and enter the Info Code 64TSaccdb to access the NI support article, Using Microsoft Access Databases with 64-bit TestStand, for more information about installing this provider.
    • Microsoft SQL Server—Use the SQL Server Native Client 10.0 or later or the Microsoft OLE DB Provider for SQL Server provider.
    • Oracle—Use the latest Oracle Provider for OLE DB and Oracle Client software. NI recommends Oracle Client 12c Release 1, version 12.1.0.1.0 or later. You can download the Oracle Provider from the Oracle website at www.oracle.com.
      Note NI does not recommend using the Microsoft OLE DB Provider for Oracle because it does not support all the OLE DB features TestStand requires.
      Note Oracle recommends using Oracle Provider 11.1.0.6.0 or later if you want to read 64-bit integer values stored in NUMBER columns.
    • MySQL—Use the MySQL Open Database Connectivity (ODBC) Driver 5.1 or later.
    • Sybase SQL Anywhere—Use the Adaptive Server Anywhere ODBC Driver 10.0 or later.
    Download the TestStand installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager.
    • Use the serial number that is included with your software to activate TestStand. For more information on TestStand activation, refer to Activating a Product.
    Unless you specify another location during installation, the TestStand installer copies core files to \National Instruments\TestStand 2022.
    You cannot install TestStand 2022 Q4 over a previous version, such as TestStand 2020, and you cannot install TestStand 2022 Q4 in the default installation directory for a previous version. If you installed a previous version of TestStand in a non-default directory, you can uninstall the previous version of TestStand and install TestStand 2022 Q4 to that directory.
    • If you uninstall one bitness of a TestStand version, NI recommends that you use the TestStand Version Selector to reactivate the remaining bitness of that version and launch TestStand to properly register its components.
    • You cannot install TestStand to a network path or a mapped network path. You must install TestStand on a local computer.
    Installing Additional Software Components
    TestStand installs the following additional software components:
    • .NET Framework 4.6.2
    • LabVIEW 2021 SP1 Run-Time Engine (RTE)
    • LabWindows™/CVI™ 2020 RTE
    • LabWindows™/CVI™ SQL Toolkit 2.4
    • NI Session Manager
    • NI Update Service
    • NI License Manager
    • TestStand Version Selector
    Note  TestStand can use newer versions of the LabVIEW RTE when you install LabVIEW on a development system. You can include newer versions of the LabVIEW RTE in deployments using the Drivers and Components dialog box of the TestStand Deployment Utility. Refer to the TestStand Help for more information about the Drivers and Components dialog box.
    To use IVI, download and install IVI-compliant drivers from the Instrument Driver Network, located at ni.com/devzone/idnet. Users with a TestStand USB distribution can navigate to the Additional Installers folder to locate and run installers for IVI.
    Installing Multiple Versions of TestStand on the Same Computer
    You can install TestStand 2022 Q4 on a computer that contains a previous TestStand version, but you cannot install TestStand 2022 Q4 over a previous TestStand version. You cannot install TestStand 2022 Q4 in the default installation directory for a previous version of TestStand. For example, TestStand 2022 Q4 does not install in \National Instruments\TestStand 2021. If you installed a previous version of TestStand in a non-default directory, you can uninstall the previous version of TestStand and install TestStand 2022 Q4 to that directory.
    Using the TestStand Version Selector
    The TestStand Version Selector application indicates the active version of TestStand and can activate a different version of TestStand. Although you can install more than one version of TestStand on a computer, only one version of TestStand can be active and can run at a time.
    The TestStand Version Selector application, TSVerSelect.exe, is located in the \National Instruments\Shared\TestStand Version Selector directory. To launch the TestStand Version Selector, select Start»National Instruments»TestStand Version Selector.
    The Current Active Version control shows the currently active version of TestStand. Select a version in the Installed TestStand versions control and click Activate to activate a specific version of TestStand. The Path to 32-bit version and Path to 64-bit version controls show the locations of the selected version of TestStand. When activation is complete, the selector displays a message to indicate success or display any warnings. Click the Launch 32-bit or Launch 64-bit button to run the sequence editor application for the active version of TestStand.
    If you activate TestStand 2022 Q4 and run a TestStand User Interface from a previous TestStand version, the user interface uses the TestStand 2022 Q4 Engine, step types, and components. If you activate a previous TestStand version and run a TestStand 2022 Q4 User Interface or the sequence editor, those applications do not function correctly.
    Note  The TestStand Version Selector does not typically require administrator privileges to activate a specific version of TestStand on Microsoft Windows 10. To require administrator privileges for using the TestStand Version Selector, add the /reqadmin command-line option to the selector shortcut.
    Refer to the TestStand Help for more information about using the TestStand Version Selector.
    After you install TestStand, you must use the NI Activation Wizard to activate the software or initiate the evaluation period for the software.
    NI offers a variety of licenses for the different ways you can use TestStand in development and deployment applications. You can select from the following types of licenses:
    • TestStand Development System License
    • TestStand Custom Sequence Editor License
    • TestStand Debug Deployment Environment License
    • TestStand Base Deployment Engine License
    In most cases, when you first install TestStand, you activate a TestStand Development System License. Use the other licenses to activate TestStand on computers to which you deploy TestStand custom sequence editors or user interfaces you develop.
    Contact a local NI representative for more information or for questions about specific licensing needs.
    Note  If you upgrade TestStand with a service pack release by installing TestStand or a deployment that includes the TestStand Engine, the TestStand Engine on the computer becomes unlicensed. You must reactivate the license on the computer. A TestStand Development System License or a Debug Deployment Environment License must be current with the Standard Service Program (SSP) to reactivate a service pack license. You can reactivate a Custom Sequence Editor License for a service pack upgrade, even if the SSP for the original license lapsed. A TestStand Base Deployment License does not require SSP to reactivate a service pack license.
    Refer to the Licensing Options for TestStand Systems section of Chapter 1, Introduction to TestStand, of the Getting Started with TestStand manual for information about how to use the available licenses when you build a TestStand-based test solution. Use the following descriptions only as a reference for the licensing options. Visit ni.com/activate for more information about activating TestStand licenses. Visit ni.com/teststand to purchase a TestStand license.
    Note  This document does not replace the NI Software License Agreement installed in the \National Instruments \Shared\MDF\Legal\license\NIReleased directory.
    TestStand Evaluation Package
    When you run TestStand in Evaluation Mode, the software expires after 7 days. You can generate a User Profile at ni.com to extend the evaluation period for an additional 45 days.
    The Evaluation Mode software runs as a fully functional TestStand Development System during the evaluation period. You can activate a license at any point during or after the evaluation period.
    TestStand Development System License (777777-35)
    Activate the TestStand Development System License to develop and edit test sequences and to save sequence files within the TestStand Sequence Editor, within a TestStand custom sequence editor, or programmatically using the TestStand API. This license also grants the right to develop custom sequence editors and operator interfaces. You must have an ni.com User Profile to activate a TestStand Development System license.
    TestStand Custom Sequence Editor License (777775-35)
    Activate the TestStand Custom Sequence Editor License to develop and edit test sequences and sequence files within a custom sequence editor or programmatically using the TestStand API.
    TestStand Debug Deployment Environment License (779851-35)
    The TestStand Debug Deployment Environment License offers the most flexibility for deploying TestStand and LabVIEW-based, LabWindows/CVI-based, and Measurement Studio-based systems.
    Activate this license to install the development versions of TestStand, LabVIEW, LabWindows/CVI, Measurement Studio, and any corresponding add-on toolkits on a single test station so you can debug deployed test applications on the test station. This license grants the right to make minor edits to fix bugs in deployed test applications but does not grant the right to perform any development tasks using TestStand, LabVIEW, LabWindows/CVI, or Measurement Studio on the test station.
    You cannot activate and deactivate the TestStand Debug Deployment Environment License and reuse it on multiple computers. If you need to use a single debug license across multiple computers, contact NI for more information about the Concurrent TestStand Debug Deployment Environment License.
    TestStand Base Deployment Engine License (777774-35)
    The TestStand Base Deployment Engine License is the minimum license required for all deployed TestStand-based applications. Activate this license to deploy the TestStand Runtime, a TestStand Operator Interface, and sequence files to the single test station to which the license applies. This license does not grant the right to perform any development tasks using the TestStand Sequence Editor, a TestStand custom sequence editor, or the TestStand API.
    If you are upgrading from TestStand 2010 or later, you can use the TestStand Migration Utility to migrate customizations and configuration settings from the earlier version of TestStand. You can also upgrade manually. Visit ni.com/info and enter the Info Code tsmigrate for more information about migrating to the current version of TestStand, including information about tasks you need to perform to upgrade manually from TestStand 4.2.1 or earlier.
    You can also migrate from 32-bit TestStand 2022 Q4 to 64-bit TestStand 2022 Q4 or from 64-bit TestStand 2022 Q4 to 32-bit TestStand 2022 Q4. Refer to the Cross-Bitness Migration section of the TestStand Help for more information about migrating to or from 64-bit TestStand 2022 Q4.
    Migrating from TestStand 2010 or Later Using the TestStand Migration Utility
    Complete the following steps to use the TestStand Migration Utility to copy settings, configuration, and public component files from the directories of TestStand 2010 or later to the current version of TestStand.
    • Launch the TestStand Migration Utility.
      Select Start»National Instruments»TestStand Migration Utility.
      If you have more than one version of TestStand installed on the computer, the utility launches a dialog box in which you can specify the previous version of TestStand from which you want to migrate.
      Note  When you migrate from TestStand 2010 SP1 or TestStand 2010 to the current version of TestStand, the utility migrates the report and database options to the format for result processing configuration options for the current version of TestStand. Refer to the TestStand Help for more information about using the TestStand Migration Utility. Visit ni.com/info and enter the Info Code tsmigrate for more information about using the utility to migrate result processing configuration options.
    • Select the previous version of TestStand.
      The utility checks the computer for all the files you can migrate to determine whether the files have changed since installation. The utility launches a status indicator dialog box during this process. When the utility finishes checking the files for changes, the utility main window launches.
    • Use the Files to Copy control to select the files you want to copy.
      By default, the utility selects files you added or modified in the previous version of TestStand.
    • Expand the directories in the Files to Copy control to view the files you can migrate and whether those files have changed since installation.
      The Conflicts column includes any conflicts that might affect the migration of the files you specify.
      Note  The utility overwrites any file you create or modify in the current version of TestStand if the file also exists in the corresponding directory of the previous version of TestStand and if you select the file in the Files to Copy control. Although the utility creates a backup copy of all overwritten files, verify that the utility will not overwrite any files you intend to keep in the version of TestStand to which you are migrating.
    • Click Migrate Files to begin the migration.
      When the migration completes successfully, the utility generates a text file report that contains the results of the migration, including where the utility stored the file backups and which files were moved.
      Note  Consider the following behavior when using the TestStand Migration Utility:
      • The utility only moves files and does not update any other information or settings, such as registry keys.
      • If the \Components directory of the previous version of TestStand includes files installed by an installer other than the TestStand installer, you might need to use that specific installer to move the files for the files to function and uninstall properly from the \Components directory of TestStand 2022 Q4.
        NI recommends that you use an installer that targets TestStand 2021 SP1 to install any such components instead of using the utility to copy the components. However, some installed components can function properly when copied to another directory and are safe to migrate with the utility.
      • The Migration Utility does not copy files in the \Examples, \Tutorial, or \AdapterSupport directories. These directories do not appear in the Files to Migrate column of the utility.
    Migrating TestStand 2010 SP1 or Earlier Result Processing Options to the Current Version of TestStand
    The TestStand 2012 or later process models include significant changes to implement a plug-in architecture for model sequence files. TestStand 2012 or later uses the plug-in mechanism to decouple result processing from the process models. As part of this change, the result processing options move from the TestStandModelReportOptions.ini and TestStandDatabaseOptions.ini files into a single ResultProcessing.cfg file, located in the \Cfg directory, that stores configuration information for all result processing model plug-ins.
    The result processing options files from TestStand 2010 SP1 or earlier are not compatible with TestStand 2012 or later process models. Refer to the Process Model Result Processing Plug-in Architecture section of the TestStand 2012 New Features topic in the TestStand Help for more information about the TestStand 2012 or later process models. Refer to the Using the Legacy Model Switcher Tool section of the TestStand 2012 New Features topic in the TestStand Help for more information about using the Legacy Model Switcher tool to use the equivalent legacy TestStand 2010 process models.
    The following table describes the migration actions you can select in the TestStand Migration Utility to migrate the result processing configuration options from TestStand 2010 SP1 or earlier to the current version of TestStand.
    Note  The utility does not support migrating the configuration files from TestStand 2010 SP1 or earlier if you modified the ReportOptions or DatabaseOptions data types defined in the default process models.
    Migration Action
    Description
    Apply to new modelsCreates a new configuration in a configuration set named Migrated from TestStand . The utility automatically selects a unique name for the configuration if the utility has already used the default name in a previously completed migration. Refer to the migration report for the specific configuration names the utility uses.
    Apply to legacy modelsCopies the options files from TestStand 2010 SP1 or earlier to the current TestStand directory so you can use the previous configurations with the equivalent legacy TestStand 2010 process models in the current version of TestStand. When you migrate database options, the utility renames TestStandDatabaseOptions.ini to TestStandDatabaseSchemas.ini.
    Apply to new and legacy modelsAdds a new configuration in the Migrated from TestStand configuration set and copies the options files from a previous version of TestStand.
    If you are upgrading from TestStand 4.2.1 or earlier, you can manually migrate result processing options for use with TestStand 2012 or later process models or the equivalent legacy TestStand 2010 process models. Visit ni.com/info and enter Info Code tsmigrate for more information about manually migrating result processing options to TestStand 2022 Q4.
    Refer to the TestStand Help for information about TestStand. You can access the TestStand Help in the following ways:
    • Select Help»NI TestStand Help in the sequence editor.
    • Select Start, launch the NI Launcher application, and select TestStand»TestStand Documentation»TestStand Help
    TestStand includes a variety of example programs that you can use to help you learn key concepts or to serve as a starting point for applications you create. You can browse the examples in the following ways:
    • Open the Examples.tsw workspace file located in the \Examples directory.
    • Open an example sequence file from the subdirectories of the \Examples directory.
    Select Help»Find Examples to launch the NI TestStand Example Programs Help from the TestStand Sequence Editor.
    TestStand no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    Refer to the Technical Support page at ni.com/support and search for TestStand to access the TestStand Support website, which contains online documentation, KnowledgeBase articles, tutorials, example code, discussion forums, and other resources.
    © 2000–2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-1-29 13:13
