查看: 187|回复: 0
[NI软件产品] NI RFmx Waveform Creator 2025 Q3 Win11 32/64bitENG RFmx波形创造器25.5.0
    6 小时前
  • 签到天数: 3676 天
    连续签到: 3 天
     楼主| 发表于 2025-8-26 12:48:10 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    RFmx Waveform Creator可帮您创建、可视化和再现通用型、蜂窝、连接性、物联网(IoT)、航空航天/防卫测试应用程序的波形。
    RFmx Waveform Creator是一款应用软件,您可以用来创建通用的和基于标准的波形,用于设计、验证和生产测试应用。借助这款软件,您可以结合信号发生器以交互方式生成波形,或保存开放的、未锁定的波形文件,用于借助自动仪器进行回放或仿真波形。该软件内置有标准的信号配置;您也可以修改、保存和加载自己的自定义波形参数。此外,在预览时域、频域和功率域的信号特征之前,您可以使用RFmx Waveform Creator来应用信号减损、滤波、波峰因子降低(CFR)等功能。
    发布日期:2025/7/18
    包含的版本:2025 Q3完整版,版本号25.5.0
    Windows Server 2025
    文件大小: 1564108800 字节 (1.46 GB)
    修改日期: 2025-07-24 15:35
    MD5: e13f7a78b3157eedb8801641b32e74e0
    SHA1: 6685d29b4cc1be90aabed27078c22b9f016c4ccc
    SHA256: 970b15d3195d0baa5818aedca766e263c4fb6c2ec17f4a7d3557cc01ecf2e964
    CRC32: 9cebab21
    请注册登录机器视觉论坛用户,购买附件查看下载地址
    RFmx Waveform Creator 2025Q3.txt (621 Bytes, 下载次数: 0, 售价: 10 圆)
    2025Q3版未更新自述文件,参考2023Q3版本
    RFmx Waveform Creator 2023 Q3 Readme
    This file contains important information about the RFmx Waveform Creator, including system requirements, and installation instructions.
    • RFmx Waveform Creator Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx Waveform Creator Manuals: New features, behavior changes, and other documentation
    RFmx Waveform Creator 2023 Q3 includes the following new features:
    • Support for Pulse library
      • Single pulse generation
      • Pulse Types: Trapezoidal, Raised Cosine, Custom Profile, Custom IQ
      • Modulation: BPSK, QPSK, LFM, AM/FM step, Barker code
      • Pulse Parameters
        • Rise Time, Fall Time, Pulse Width
        • Droop, Overshoot, Ripple
    • Updated 802.11be standard support to comply with IEEE P802.11be/D3.2 specification
    RFmx Waveform Creator 2023 Q2 includes the following new features:
    • Generation API support added to RFmx Waveform Creator for Bluetooth®
    • Updated 802.11be standard support to comply with IEEE P802.11be/D3.0 specification
    • Support for UL FRC tables A.1-1a and A.2-1a with interlaced RB allocations
    • .NET Class Library support for generation APIs of WLAN standard
    RFmx Waveform Creator 2023 Q1 includes the following new features:
    • Support for Unframed Data Modulation for 802.11be standard
    • Updated 802.11be standard support to comply with IEEE P802.11be/D2.3 specification
    • Support for new reference channels for timing adjustment in UL FRC Table A.10 for Frequency Range 2 as per 3GPP Release 17 (September-2022)
    RFmx Waveform Creator has the following requirements:
    RFmx Waveform Creator 2023 Q2 supports the following 64-bit operating systems:
    Note    RFmx Waveform Creator no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx Waveform Creator 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx Waveform Creator 2023 Q3 to an unsupported OS. Additionally, after installing RFmx Waveform Creator 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx Waveform Creator supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx Waveform Creator. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx Waveform Creator (64-bit only)
    LabVIEW2020 SP1, 2021, 2022 Q3, 2023 Q1, 2023 Q3
    Required Software
    • NI-RFSG 14.5 or later
    • NI-RFSG 20.7 or later (for MIMO configurations with PXIe-5830/5831/5832 in RFmx Waveform Creator for WLAN)
    If you are using the RFmx Waveform Creator .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx Waveform Creator .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx Waveform Creator installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx Waveform Creator. For more information on RFmx Waveform Creator activation, refer to National Instruments Software Activation.
    Select Start » National Instruments» RFmx Waveform Creator to launch the RFmx Waveform Creator.
    Documentation for RFmx Waveform Creator is located at Start » National Instruments » RFmx Waveform Creator Documentation.
    You can access all the installed RFmx Waveform Creator examples at Start » National Instruments » RFmx Waveform Creator Examples.
    The following items are the behavior changes in RFmx Waveform Creator 2023 Q3 from RFmx Waveform Creator 2023 Q1
    • FR2-1 DL FRCs are now supported with two frames.
    The following items are the behavior changes in RFmx Waveform Creator 2023 Q1 from RFmx Waveform Creator 2022 Q4
    • Uplink reference channels G-FR1-A5-15 and G-FR1-A5-16 now support interlaced RB allocation.
    The following items are the behavior changes in RFmx Waveform Creator 2022 Q3 from RFmx Waveform Creator 21.8.2.
    • Default value of WLAN Oversampling Ratio control changed to 1.25.
    GMT+8, 2025-10-9 15:26
