查看: 475|回复: 0
[NI软件产品] NI RFmx SpecAn/Power Amplifier/Phase Noise/Niose Figure 2025 Q3 Win11 64bitENG RFmx频谱分析仪/功率放大器/相位噪声/噪声系数25.5.0
     楼主| 发表于 2025-8-26 12:13:16 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    RFmx SpecAn
    RFmx SpecAn为时域和频谱分析提供互动和自动测量。
    发布日期:2025/7/18
    包含的版本:2025 Q3完整版/运行版,版本号25.5.0
    Windows Server 2025
    64位完整版校验和:
    文件大小: 2698672128 字节 (2.51 GB)
    修改日期: 2025-07-23 19:26
    MD5: bee78cb76e63beeb5fb064d8ec8f4e53
    SHA1: a3a0f642e0cbe975457fd4b2274aafe7db7ead0d
    SHA256: 77eff92ff513d2d1e72733bce3f913702c19560967aae67e01c978d64dfc4dc0
    CRC32: 25df84f9
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFmx SpecAn2025Q3.txt (542 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 1035012096 字节 (987.06 MB)
    修改日期: 2025-07-23 19:33
    MD5: b27f79fe1e3239f99a6af4ceef088b1c
    SHA1: a443e81e2fb9446a77651bcfdb3bc57cb7349100
    SHA256: bfda75c08cebfb8ad89eb35865b0e18af3edb0db20974e88e009988563dd6dd3
    CRC32: fb4a2f61
    RFmx SpecAn2025Q3RTE.txt (567 Bytes, 下载次数: 0, 售价: 5 圆)
    2025Q3版本未更新自述文件,参考2023Q3版本
    RFmx SpecAn 2023 Q3 Readme
    This file contains important information about the RFmx SpecAn, including system requirements, and installation instructions.
    • RFmx SpecAn Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx SpecAn Manuals: New features, behavior changes, and other documentation
    Installed Software
    RFmx SpecAn 2023 Q3 includes the following new features:
    • Iterative Learning Control for DPD measurement
    • Support for Noise Compensation in ACP measurement for Sequential FFT mode
    RFmx SpecAn 2023 Q2 includes the following new features:
    • Support for Detectors in CHP and ACP measurements
    RFmx SpecAn 2023 Q1 includes the following new feature:
    RFmx SpecAn has the following requirements:
    RFmx SpecAn 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx SpecAn no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx SpecAn 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx SpecAn 2023 Q3 to an unsupported OS. Additionally, after installing RFmx SpecAn 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx SpecAn supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing RFmx SpecAn. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx SpecAn
    LabWindows™/CVI™2019 or later
    Required Software
    • NI-RFSG 14.0.1 or later
    • NI-RFSG Playback Library 19.1 or later (for DPD examples)
    Download the RFmx SpecAn installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • RFmx SpecAn installs the following licensed products
      • RFmx Noise Figure: This will enable the Noise Figure measurement in RFmx SpecAn.
      • RFmx Phase Noise: This will enable the Phase Noise measurement in RFmx SpecAn.
      • RFmx Power Amplifier: This will enable the AMPM and DPD measurements and the Crest Factor Reduction (CFR) support in RFmx SpecAn.
    • Use the serial number that is included with your software to activate the product. Refer to the NI Software Activation for more information on product activation.
    Installed Software
    Item
    Installed Location
    Import Library files
    RFmx SpecAn palette VIs are available from the Functions » Measurement I/O » NI-RFmx » SpecAn palette.
    Documentation for RFmx SpecAn is located at Start » National Instruments » RFmx SpecAn Documentation.
    Select Help » Find Examples from LabVIEW or LabWindows/CVI to launch the NI Example Finder and navigate to Hardware Input and Output » Modular Instruments » NI-RFmx » SpecAn. You can also select the Search tab to search all installed examples by keyword.
    You can access all the installed RFmx SpecAn examples at Start » National Instruments » RFmx SpecAn » RFmx SpecAn Examples.
    The following is the behavior change in RFmx SpecAn 2023 Q3 from RFmx SpecAn 2023 Q2
    The following is the behavior change in RFmx SpecAn 2022 Q4 from RFmx SpecAn 2022 Q3:
    • RFmx SpecAn drops support for 32-bit user mode.
    The following is the behavior change in RFmx SpecAn 2022 Q3 from RFmx SpecAn 21.8.2:
    The following are the behavior changes in RFmx SpecAn 20.7 from RFmx SpecAn 20.6.
    GMT+8, 2026-1-13 13:12
