NI Linux Device Drivers 2025 Q3 Online Linux64Eng Linux仪器驱动程序NILinux2025Q3DeviceDrivers在线安装
NI Linux设备驱动程序
NI Linux Device Drivers软件为采用Linux操作系统的NI和第三方硬件提供了所需的NI仪器驱动。
NI Linux Device Drivers软件为各种NI测试和测量硬件提供了Linux桌面支持。该软件提供了一个存储库附加工具,下载该附加工具后,就可以指示Linux软件包管理器安装NI驱动软件包,如NI-DAQmx、NI-VISA、NI-488.2和NI-Sync。NI Linux Device Drivers软件也支持LabVIEW。
发布日期:2025/7/18
包含的版本:2025 Q3完整版
RedHat
SUSE
Ubuntu
程序位数:64位
语言:英文English
校验和:(在线安装版本,文件很小,需要连网从NI服务器下载资源安装)
文件大小: 432657 字节 (422.52 KB)
修改日期: 2025-07-18 21:59
MD5: c3ad36331ec2e083aa776e56b9ecb3ad
SHA1: 0d9ded65efd10590cc7b3aa05f0a4780aef4eb0e
SHA256: f8b888c6648d477bb548a60b699d942cfa511f6f938ad89d46ab9f0544b9a916
CRC32: 90f4c8a0
百度网盘和NI官方下载地址(在线安装,需要连网支持,且能正常连接NI服务器):
Linux Device Drivers程序2025Q3.txt
(540 Bytes, 下载次数: 0, 售价: 10 圆)
2025Q3版未更新自述文件,参考2023Q3版
NI Linux Device Drivers 2023 Q3 ReadmeJuly 2023 This file contains installation instructions and compatibility information for NI Linux Device Drivers 2023 Q3. You can find more release information on ni.com. - NI Linux Device Drivers Release Notes: for known issues, bugs fixed since the last release, and other release details.
New Features Installation Instructions Package Repositories Supported Drivers Product Security and Critical Updates OverviewNI Linux Device Drivers software provides Linux Desktop support for a variety of NI test and measurement hardware. It offers repository registration packages for each supported Linux distribution. Once the appropriate driver software repository is registered for the system, use the Linux distribution's native package manager to install NI driver software packages. New Features
- Hardware Configuration Utility support for RF composite devices
Installation InstructionsRefer to Download and Install NI Driver Software on Linux Desktop. Package RepositoriesNI Linux Device Drivers are installed from one of the following two options. - Static repository registration packages are labeled with a date-based suffix, such as ni-rhel8-drivers-2023Q2. Software from this repository is not intended to change, and it is updated only for critical patches. Use this kind of repository when you need to reproduce a specific software stack.
- Stream repository registration packages are labeled with a -stream suffix, for example: ni-rhel8-drivers-stream. Software in this repository is updated regularly with the latest versions of each driver package as it is released. Running an update/upgrade command with a package manager will update installed NI packages to their latest released version for systems that have registered a stream repository. This kind of repository is the simplest way to keep NI driver software up to date.
Firstlook is present in some repository registration package names, for example ni-ubuntu2204firstlook-drivers-2023Q2.deb. Firstlook identifies a newer repository that is now in an introductory roll-out phase as NI steadily adds and validates individual drivers over the course of multiple releases. Although not yet comprehensive, support for these repositories is progressing to the same level to that of other distributions. If you plan to upgrade to a new distribution and you see "firstlook" in its NI repository registration package name, refer to the Supported Drivers table to ensure that the NI products you need support the new distribution. Supported DriversFor a list of supported hardware, refer to the NI Hardware and Operating System Compatibility page. For details about a specific driver's system requirements, limitations, and so on, refer to the readme for the individual driver (linked below). The following table shows driver support for several Linux distributions. Use your Linux distribution's package manager to install the specified add-on files for an NI driver. NI Driver Support for Linux DistributionsDriver | Packages | RHEL18 | RHEL1 9 | openSUSE2 15.3 | openSUSE2 15.4 | Ubuntu3 20.04 | Ubuntu3 22.04 | Driver
Release Notes | Tested Kernel | 4.18 | 5.14 | 5.3 | 5.14 | 5.13 | 5.15 | | NI-488.2 | Required Packages:
ni-488.2
Optional Packages:
libni4882-devel
ni-488.2-iotrace-support
| √ | √ | √ | √ | √ | √ | NI-488.2 2023 Q3 | Automotive Diagnostic
Command Set Toolkit | Required Packages:
ni-adcs
Optional Packages:
ni-adcs-labview-20xy-support
libnidiagcs-devel
| √ | √ | √ | √ | √ | √ | Automotive Diagnostic Command Set Toolkit 2022 Q4 | NI-DAQmx | Required Packages:
ni-daqmx
Optional Packages:
ni-daqmx-labview-20xy-support
ni-daqmx-labview-support
libnidaqmx-devel
| √ | √ | √ | √ | √ | √ | NI-DAQmx 2023 Q3 | NI-DCPower | Required Packages:
ni-dcpower
Optional Packages:
ni-dcpower-daqmx
ni-dcpower-labview-20xy-support
ni-dcpower-labview-support
ni-dcpower-devel
| √ | √ | √ | √ | √ | √ | NI-DCPower 2023 Q3 | NI-DMM | Required Packages:
ni-dmm
Optional Packages:
ni-dmm-daqmx
ni-dmm-labview-20xy-support
ni-dmm-labview-support
ni-dmm-devel
| √ | √ | √ | √ | √ | √ | NI-DMM 2023 Q3 | ECU Measurement and
Calibration Toolkit | Required Packages:
ni-ecumc
Optional Packages:
ni-ecumc-labview-20xy-support
libniemcc-devel
| √ | √ | √ | √ | √ | √ | ECU Measurement and Calibration Toolkit 2022 Q4 | NI-FGEN | Required Packages:
ni-fgen
Optional Packages:
ni-fgen-daqmx
ni-fgen-devel
ni-fgen-labview-support
ni-fgen-labview-20xy-support
| √ | √ | √ | √ | √ | √ | NI-FGEN 2023 Q3 | FlexRIO | Required Packages:
ni-flexrio
Optional Packages:
ni-flexrio-795x
ni-flexrio-796x
ni-flexrio-797x
libniflexrioapi-devel
ni-flexrio-modulario-libs-devel
| √ | √ | √ | √ | √ | √ | FlexRIO 2023 Q3 | Hardware Configuration
Utility | Required Packages:
ni-hwcfg-utility
| √ | √ | √ | √ | √ | √ | Hardware Configuration Utility 2023 Q3 | PXI Platform
Services | Required Packages:
ni-pxiplatformservices
Optional Packages:
ni-pxiplatformservices-labview-20xy-support
ni-pxiplatformservices-labview-support
ni-pxiplatformservices-devel
| √ | √ | √ | √ | √ | √ | PXI Platform Services 2023 Q3 | NI-RIO4 | Required Packages:
ni-fpga-interface
Optional Packages:
ni-rio-mxie
| √ | √ | √ | √ | √ | √ | NI-RIO 2023 Q3 | NI R Series | Required Packages:
ni-rseries
| √ | √ | √ | √ | √ | √ | NI R Series 2023 Q3 | NI-RFSA | Required Packages:
ni-rfsa
Optional Packages:
ni-rfsa-daqmx
ni-rfsa-labview-20xy-support
ni-rfsa-devel
| √ | √ | √ | √ | √ | √ | NI-RFSA 2023 Q3 | NI-RFSG | Required Packages:
ni-rfsg
Optional Packages:
ni-rfsg-daqmx
ni-rfsg-labview-20xy-support
ni-rfsg-devel
| √ | √ | √ | √ | √ | √ | NI-RFSG 2023 Q3 | NI-SCOPE | Required Packages:
ni-scope
Optional Packages:
ni-scope-daqmx
ni-scope-labview-20xy-support
ni-scope-labview-support
ni-scope-devel
| √ | √ | √ | √ | √ | √ | NI-SCOPE 2023 Q3 | NI-Serial | Required Packages:
ni-serial
| √ | √ | √ | √ | √ | √ | NI-Serial 2023 Q2 | NI-SWITCH | Required Packages:
ni-switch
Optional Packages:
ni-switch-daqmx
ni-switch-daqmx-config
ni-switch-labview-support
ni-switch-labview-20xy-examples
ni-switch-devel
| √ | √ | √ | √ | √ | √ | NI-SWITCH 2023 Q3 | NI-Sync | Required Packages:
ni-sync
Optional Packages:
ni-sync-devel
ni-sync-labview-20xy-support
ni-sync-labview-support
| √ | √ | √ | √ | √ | √ | NI-Sync 2023 Q1 | System
Configuration | Required Packages:
ni-syscfg-runtime
Optional Packages:
ni-syscfg-labview-20xy-support
ni-syscfg-labview-support
ni-iotrace
ni-syscfg-devel
| √ | √ | √ | √ | √ | √ | System Configuration 2023 Q3 | NI-VISA | Required Packages:
ni-visa
Optional Packages:
ni-visa-labview-20xy-support
ni-visa-labview-support
ni-visa-devel
| √ | √ | √ | √ | √ | √ | NI-VISA 2023 Q3 | NI-XNET | Required Packages:
ni-xnet
Optional Packages:
ni-xnet-labview-20xy-support
libnixnet-devel
| √ | √ | √ | √ | √ | √ | NI-XNET 2023 Q2 |
1 Red Hat Enterprise Linux
2 openSUSE Leap
3 Ubuntu LTS
4 Enables connections via the FPGA Interface API to remote RIO devices such as CompactRIO, Single-Board RIO, and Ethernet RIO
Optional package types:
There are several categories of optional packages including:
LabVIEW support packages: These packages install the driver APIs to LV. These have the driver and 'labview' in the package name. They come in two types: version-specific LV support packages (the older style) which list a year and version-agnostic LV support packages (the newer style). Only use the version-specific LV support package when there's one that matches the version of LV that you need to use. Otherwise use the version-agnostic one.
Development packages: These packages install header files that are needed to compile code with the driver, but that aren't required to execute code that was compiled somewhere else. Typically this is needed on the development machine, but not always on a deployed system. These package names end with "-devel".
driver-DAQmx support packages: NI-DCPower, NI-DMM, NI-FGEN, NI-RFSA, NI-RFSG, NI-SCOPE, and NI-SWITCH each have a few HW devices that have separate drivers built on top of DAQmx. These packages function as the top-level driver package for those particular HW models.
For additional information about supported operating systems, refer to the NI Operating System Support Roadmap. For an introduction to using Linux with NI products see About the NI Platform on Linux Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. For information about critical updates from NI, refer to Available Critical and Security Updates for NI Software. |
