查看: 1000|回复: 0
[NI驱动程序] NI RF Signal Generators 2025 Q2 Win11 32/64bitEng NI RF信号发生器NI-RFSG25.3.0
    昨天 08:11
     楼主| 发表于 2025-5-20 09:08:56 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG
    NI-RFSG 2025 Q2
    发布日期:2025/4/9
    包含的版本:2025 Q2完整版,版本号25.3.0
    Windows Server 2025
    文件大小: 4983740416 字节 (4.64 GB)
    修改日期: 2025-04-11 16:50
    MD5: 9f2ac91e4fdb64e9310aeb9f3dc006e1
    SHA1: 3fef587932705d3ade13386bdc2f24ef1472b8ee
    SHA256: 12b2451e14b6c96ce945cf1a9d4f49bff6566ec10aa123ec4121bc9bd8bd27ac
    CRC32: be9bc18c
    RFSG2025Q2.txt (510 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFSG2025Q2版未更新自述文件,参考2023Q3版
    NI-RFSG 2023 Q3 Readme
    • Support for LabVIEW 2023 Q1
    • 4 GB RAM*
    • NI Linux® Real-Time
    Versions Supported by NI-RFSG
    LabVIEW2020 and later
    LabWindows/CVI2019 and later
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    NI-RFSG SFP
    Document
    Format
    Description
    • Hardware device overviews
    Document
    Format
    Description
    GMT+8, 2026-3-13 05:08
