查看: 1186|回复: 0
[NI软件产品] LabVIEW 2025 Q1 FPGA Module Xilinx Compilation Tools Linux64Eng LV2025Q1 FPGA编译工具(Vivado 2021.1)
     楼主| 发表于 2025-4-28 10:01:35 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW 2025 Q1 FPGA Compilation Tool for Vivado 2021.1
    发布日期:2025/1/23
    包含的版本:2025 Q1完整版,版本号25.1.0
    支持:Vivado 2021.1
    Linux
    校验和
    文件大小: 217599 字节 (212.50 KB)
    修改日期: 2025-04-28 09:55
    MD5: bb2d1651ed3e2896e4c7b25211e7d227
    SHA1: 84d6adf95c0c53c1f65bdcc6b9bc5464eb551c78
    SHA256: 9f3c4bfa9167d8514778221534ffb7c000ff3f117a73f256dcce47fb4b9c70cd
    CRC32: 8946f588
    百度网盘下载和NI官方下载地址:
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    LabVIEW FPGA Compilation Tool LabVIEW2025Q1Linux.txt (623 Bytes, 下载次数: 0, 售价: 10 圆)
    2025Q1版未更新自述文件,参考2020版
    LabVIEW 2020 FPGA Module Xilinx Compilation Tools for Linux Readme
    March 2020
    This file contains important information about the LabVIEW FPGA Module Xilinx Compilation Tools for Linux, including system requirements and installation instructions.
    The Xilinx compilation tools include tools for Vivado 2019.1 and ISE 14.7, which are supported by the LabVIEW FPGA Module. Install these compilation tools if you want to compile FPGA VIs on a Linux computer.
    The Xilinx compilation tools also support Windows. Refer to the FPGA Module Xilinx Compilation Tools for Windows Readme for more information.
    The Xilinx Compilation Tool for Vivado 2019.1 has the following system requirements:
      • Red Hat Enterprise Linux 7.4/7.5/7.6 (64-bit)
      • CentOS 7.4/7.5/7.6 (64-bit)
    • 15 GB of additional disk space
    • Memory—Refer to the Xilinx website at www.xilinx.com for memory requirements of different FPGA targets. Failure to meet the target-specific memory requirement may result in unpredictable compilation results.
      Note  The recommended memory size on the Xilinx website is for one compile job only. If you run multiple compile jobs at a time, the memory requirement increases by multiple times accordingly.
    The Xilinx Compilation Tool for ISE 14.7 has the following system requirements:
    • Red Hat Enterprise Linux 6.5 (64-bit)
    The following sections contain the NI hardware supported by the FPGA Module Xilinx Compilation Tools on Linux. Devices that are compatible with the FPGA Module (64-bit) are in bold.
    Use the Xilinx Compilation Tool for Vivado 2019.1 to compile FPGA VIs for the following devices:
    • cRIO-903x/904x/905x/906x
    • IC-317x
    • myRIO-1900/1950
    • NI ELVIS III
    • NI ELVIS RIO Control Module
    • NI-9145/9147/9149
    • PCIe-576x/577x/5785/6593/782xR/7846/7856/7857/7858/798x
    • PXIe-5163R/5164R/517xR/5624R/5745/576x/577x/5785/5840R/659x/782xR/784x/785x/786x/786xR/7902R/791x/793xR/797xR/798x/799x
    • roboRIO
    • sbRIO-9603/9608/9609/9628/9629/9638/9651/96x7
    • USB-784xR/785xR
    • USRP-RIO devices
    Use the Xilinx Compilation Tool for ISE 14.7 to compile FPGA VIs for the following devices:
    • IC-312x
    • NI-915x
    • NI CVS-145x/145xRT
    • PCIe-7841R/7842R/7851R/7852R/1473R/8237R
    • PXIe-796xR/564xR
    • PXI-784xR/785xR/795xR
    Complete the following steps to install the FPGA Module Xilinx Compilation Tools for Linux:
    • Use mount to mount the compilation tools installer.
    • If the media type is DVD, change the current directory to the mount point.
      If the media type is USB, change the current directory to mount point/Linux/Vivado2019_1 or mount point/Linux/ISE14_7, depending on which tool you want to install.
    • To run the installation script, enter sh ./INSTALL.
    © 2012–2020 National Instruments. All rights reserved.
    Third-Party Copyright Notices
    /usr/local/natinst/nifpgacompileworker/doc
    374740L-01
    GMT+8, 2026-1-13 07:52
