查看: 750|回复: 0
[NI驱动程序] NI RF Signal Generators 2025 Q1 Win11 32/64bitEng NI RF信号发生器NI-RFSG25.0.0
     楼主| 发表于 2025-4-24 11:10:14 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG
    NI-RFSG 2025 Q1
    发布日期:2025/1/22
    包含的版本:2025 Q1完整版,版本号25.0.0
    文件大小: 4970485760 字节 (4.63 GB)
    修改日期: 2025-03-11 17:30
    MD5: 6d0f9b201f6c8ceeeab5ba4c132c15cb
    SHA1: 16947bb0de34e0903fb94c3c8917b4f3bab27a4a
    SHA256: 4665941a86495e678c1a2e3dfcdc86a5129e098b86ae1b28e59f45398fe2ca3d
    CRC32: a138872d
    RFSG2025Q1.txt (510 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFSG2025Q1版未更新自述文件,参考2023Q3版
    NI-RFSG 2023 Q3 Readme
    • Support for LabVIEW 2023 Q1
    • 4 GB RAM*
    • NI Linux® Real-Time
    Versions Supported by NI-RFSG
    LabVIEW2020 and later
    LabWindows/CVI2019 and later
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    NI-RFSG SFP
    Document
    Format
    Description
    • Hardware device overviews
    Document
    Format
    Description
    GMT+8, 2026-1-13 09:36
