NI RFmx TD-SCDMA 2025 Q1 Win11 64bitENG RFmx蜂窝测试TD-SCDMA25.0.0
RFmx TD-SCDMA
发布日期:2025/1/23
包含的版本:2025 Q1完整版/运行版,版本号25.0.0
64位完整版校验和:
文件大小: 2390704128 字节 (2.23 GB)
修改日期: 2025-03-12 15:04
MD5: 4ee787292f9de15899b79da54c58a361
SHA1: dc5965fdb93c0a1032cce345fbdaa45b6e06a435
SHA256: e04a558a568769903e8b9d3b7b5b2b8c92614a344f947f99d28fa4d4c29db58c
CRC32: d50bbbd4
请注册登录机器视觉论坛用户,购买附件查看下载地址
TD-SCDMA2025Q1Full.txt
(546 Bytes, 下载次数: 0, 售价: 10 圆)
64位运行版校验和:
文件大小: 1046214656 字节 (997.75 MB)
修改日期: 2025-03-12 15:11
MD5: b8fb0c5e86ac97a4110df927de45e728
SHA1: 28cbea6da428870d91492a129ba54db3ef35a959
SHA256: 9e690eb11e88e61df218ffb31b02e26dd24a4e8208c97808226eac4d9d021484
CRC32: d2460ef0
请注册登录视觉机器论坛用户,购买附件查看下载地址
TD-SCDMA2025Q1RTE.txt
(571 Bytes, 下载次数: 0, 售价: 5 圆)
2025Q1未更新自述文件,参考2023Q3版本
RFmx TD-SCDMA 2023 Q3 ReadmeJuly 2023 This file contains important information about the RFmx TD-SCDMA, including system requirements, and installation instructions. You can find more release information on ni.com. - RFmx TD-SCDMA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
- RFmx TD-SCDMA Manuals: New features, behavior changes, and other documentation
New Features Supported Hardware System Requirements Supported Operating Systems Application Software Support Installation Instructions Installed Software File Locations Executable Accessing the API Accessing the Documentation Finding Examples Product Security and Critical Updates Behavior Changes Automating the Installation of NI Products Using NI Software with Microsoft Windows 11 New FeaturesRFmx TD-SCDMA 2023 Q2 includes the following new feature: - Speed improvements for Composite and Spectral measurements
RFmx TD-SCDMA 2023 Q1 includes the following new feature: - Support for LabVIEW 2023 Q1 (64-bit)
RFmx TD-SCDMA 2022 Q4 includes the following new feature: Supported HardwareVisit NI Hardware and Operating System Compatibility to view driver, desktop operating system, and real-time operating system support for individual hardware devices. To view information for your device: - Select your hardware model in the dropdown list on the page to view compatibility information for your device.
Note: Some compatibility information may only be available in the archive attached to the NI Hardware and Operating System Compatibility page. For historic driver and OS support information, refer to the readme for the relevant driver version. System RequirementsRFmx TD-SCDMA has the following requirements: - Processor—1 GHz 64-bit (x64) processor
- 4 GB RAM *
- Any supported OS, with all available critical updates and service packs
* Depending on the amount of data acquired and/or processed, a larger amount of memory may be required. Supported Operating SystemsRFmx TD-SCDMA 2023 Q3 supports the following 64-bit operating systems: - Windows 11
- Windows 10
- Windows Server 2022
- Windows Server 2019
- Windows Server 2016
Note RFmx TD-SCDMA no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx TD-SCDMA 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx TD-SCDMA 2023 Q3 to an unsupported OS. Additionally, after installing RFmx TD-SCDMA 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. Application Software SupportRFmx TD-SCDMA supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx TD-SCDMA. If you are not using NI application software, refer to Microsoft Visual Studio Support. Application Software | Versions Supported by RFmx TD-SCDMA (64-bit only) | LabVIEW | 2020 SP1, 2021 SP1 f1 patch, 2022 Q3, 2023 Q1, 2023 Q3 | Required Software- NI-RFSA 14.1 or later
- NI-RFSA 17.1 or later (for initializing debug session when "using breakpoints in C/C++/.NET application" is selected)
Microsoft Visual Studio SupportIf you are using the RFmx TD-SCDMA .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx TD-SCDMA .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5. Installation InstructionsDownload the RFmx TD-SCDMA installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager. Notes - If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue.
- Use the serial number that is included with your software to activate RFmx TD-SCDMA. For more information on RFmx TD-SCDMA activation, refer to National Instruments Software Activation.
Installed Software- is an alias for the following National Instruments file folder location:
- Program Files (x86)\National Instruments\MeasurementStudioVS2010
- is an alias for the following file folder location:
- Windows\SysWOW64 for 32-bit programs and windows\system32 for 64-bit programs
File LocationsItem | Installed Location | Version Compatibility Checker | \RFmx\niRFmxCompatibility_Checker.exe | Debug Configuration Utility | \RFmx\niRFmxDebugConfigurationUtility.exe | DLLs | | Header files | \Shared\ExternalCompilerSupport\C\include | Import Library files | - 32-bit: \Shared\ExternalCompilerSupport\C\lib32\msvc
- 64-bit: \Shared\ExternalCompilerSupport\C\lib64\msvc
| .NET Class Libraries | Assemblies | \DotNET\Assemblies\Current\NationalInstruments.RFmx.TdscdmaMX.Fx40.dll
\DotNET\Assemblies\Current\NationalInstruments.Common.dll | ExecutableSelect Start » National Instruments » InstrumentStudio to launch the InstrumentStudio. Accessing the APIRFmx TD-SCDMA palette VIs are available from the Functions » Measurement I/O » RFmx » TDSCDMA palette. Accessing the DocumentationDocumentation for RFmx TD-SCDMA is located at Start » National Instruments » RFmx TD-SCDMA Documentation. Finding ExamplesYou can access all the installed RFmx TD-SCDMA examples at Start » National Instruments » RFmx TD-SCDMA Examples. For the most recent revisions of documentation and for newly released documentation, visit ni.com/manuals. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. For information about critical updates from NI, refer to Available Critical and Security Updates for NI Software. Behavior ChangesThe following is the behavior change in RFmx TD-SCDMA 2023 Q3 from RFmx TD-SCDMA 2023 Q2 - Added support for saving and loading RFmx configurations into/from rfmxconfig files. Load from TDMS is supported but save into TDMS files is discontinued.
The following is the behavior change in RFmx TD-SCDMA 2022 Q4 from RFmx TD-SCDMA 2022 Q3 - RFmx TD-SCDMA drops support for 32-bit user mode.
The following is the behavior change in RFmx TD-SCDMA 2022 Q3 from RFmx TD-SCDMA 21.8.2: - The RFmx Soft Front Panel has been replaced by InstrumentStudio.
The following is the behavior change in RFmx TD-SCDMA 20.7 from RFmx TD-SCDMA 20.6: - Obsoleted RFmxInstr Configure Automatic SG SA Shared LO API and RFmxInstr Automatic SG SA Shared LO property. Use RFmxInstr LO Source property with Automatic_SG_SA_Shared value instead.
Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.6.2, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software. For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager manual. Using NI Software with Microsoft Windows 11Microsoft Windows 11 is the latest version of the Windows operating system and features significant changes compared to previous versions. For more information about NI support for Windows 11, refer to NI Product Compatibility for Microsoft Windows 11. |
