查看: 630|回复: 0
[NI软件套件] LabVIEW + 2025 Q1 (Test Workflow) Win11 64bitEng LabVIEW Plus套件2025Q1-64位英文版
  • 签到天数: 3604 天
    连续签到: 12 天
     楼主| 发表于 2025-4-11 10:49:39 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    Test Workflow Pro 2024 Q1版更名为LabVIEW+套件,并且不再提供Test Workflow Standard标准版套件。
    LabVIEW+套件
    NI LabVIEW+套件是LabVIEW+、 DIAdem、 TestStand、 FlexLogger等NI软件的捆绑包。该套件提供专门设计的测量、分析和测试工具,可帮助工程师节省宝贵时间。
    LabVIEW+套件是一套以LabVIEW为核心的NI测试软件。LabVIEW的图形化编程环境能够加速硬件集成和系统开发。随附的附加软件可为测量、分析和测试提供特定于工程的解决方案,以更快地完成工作。您可以使用TestStand为验证实验室或生产车间开发高度优化的测试序列,使用FlexLogger快速配置和进行测量,使用DIAdem分析数据并创建可共享的报告。
    NI Test Workflow测试工作流程
    专业版包含:
    应用程序软件
    LabVIEW专业版
    G Web开发软件
    InstrumentStudio
    FlexLogger
    DIAdem专业版
    TestStand
    附加软件
    LabVIEW VI Analyzer工具包
    LabVIEW Plus 2025 Q1
    发布日期:2025/1/23
    包含的版本:2025 Q1专业版,版本号25.0.0
    语言:英文English
    文件大小: 14841454592 字节 (13.82 GB)
    修改日期: 2025-03-02 18:16
    MD5: bb536196c714478ade4622ea15d903b0
    SHA1: ffdf574da24459017f688bb52ae4a76fcdc28e48
    SHA256: d5d565a9f28d0db96f2191942e75a6472e951ab0f21a409a472cab732e1ddd32
    CRC32: 7c5c117d
    注册登录视觉论坛,购买附件查看下载地址
    LabVIEW 2025Q1x64En.txt (583 Bytes, 下载次数: 0, 售价: 30 元)
    LabVIEW Plus 2025 Q1未更新自述文件,参考Test Workflow 2023 Q1 Pro自述文件。
    Test Workflow 2023 Q1 Pro Readme
    January 2023
    This file contains installation instructions and compatibility information for Test Workflow 2023 Q1 Pro.
    • Test Workflow Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    Products Included in the Test Workflow Pro Bundle
    Test Workflow 2023 Q1 Pro supports the following operating systems:
    The following products are included in the Test Workflow Pro installer. This may not be a complete list of products that are activatable by your bundle serial number. Refer to the readme of each product for information including system requirements, installation, activation, known issues, and bug fixes.
    Application Software
    Version
    Bitness
    DIAdem2022 Q464-bit
    FlexLogger2023 Q1164-bit
    InstrumentStudio2023 Q164-bit
    1FlexLogger 2023 Q1 does not support 2023 Q1 NI driver software.
    If you are using the Test Workflow .NET Class Library, .NET Framework 4.0 (minimum) is required. The Test Workflow 2023 Q1 Pro .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the Test Workflow installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    • Use the serial number that is included with your software to activate Test Workflow. For more information on Test Workflow activation, refer to Activating a Product.
    Test Workflow no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2025-7-25 21:57
