查看: 846|回复: 0
[LV工具模块] LabVIEW 2025 Q1 FPGA Module Win11 32bitEng LV2025Q1FPGA模块25.1.0英文版32位
     楼主| 发表于 2025-4-9 11:46:20 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    FPGA从2018版开始,提供64位版本和32位版本,之前的则只有32位版本。64位版本的,仅有英文版。32位版本的,则通常会有英文版、日文版、中文版等。本论坛大部分的日文版不提供下载(有少数几个没有找到中文版的有提供日文版)。部分年代版本的,则没有中文版的资源,请使用英文版。
    发布日期:2025/1/23
    包含的版本:2025Q1完整版,版本号25.1.0
    应用程序位数:32位
    文件大小: 1161891840 字节 (1.08 GB)
    修改日期: 2025-03-13 16:16
    MD5: 785956cdac9ff38345fd24597a0a5901
    SHA1: 88d7c3c6155fe93cacc994c895177519262cb64b
    SHA256: 8a254de6dff19dc922854f0cc36bc98ecee8b7aae42645c98fa8d8e220d7d53d
    CRC32: 5d27c10e
    请注册登录视觉论坛会员,购买附件查看
    FPGA模块2025Q1x86En.txt (600 Bytes, 下载次数: 0, 售价: 10 圆)
    2025Q1版未更新自述说明,参考2023Q1版
    LabVIEW 2023 Q1 FPGA Module Readme
    January 2023
    This file contains installation instructions and compatibility information for LabVIEW 2023 Q1 FPGA Module.
    • LabVIEW FPGA Module Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • LabVIEW FPGA Module Documentation: New features, behavior changes, and other documentation
    FPGA Module (64-Bit)
    System RequirementsFPGA Module System Requirements
    • LabVIEW 2023 Q1 Full or Professional Development Systems
    • 3 GB of additional disk space
    • Memory1:
      • At least 4 GB of RAM for Virtex-6 and later FPGA targets
    • NI FPGA device
    • Device driver software—To program most devices with the LabVIEW FPGA Module, install the device driver software. Refer to the hardware documentation for requirements for a specific device.
    You can use either a Windows or Linux computer as a compile worker. Refer to the Xilinx Compilation Tools Readme for information about the minimum system requirements.
    • 35 MB of disk space
    • 1 GB RAM
    • Web browser that supports Microsoft Silverlight for accessing compile job queues via the NI Web-based Configuration & Monitoring Service FPGA Compile Farm Console
    Note  If you are upgrading from a previous version of LabVIEW, you must install the LabVIEW 2023 Q1 FPGA Module before mass-compiling existing FPGA VIs. Otherwise, some FPGA-specific VIs might have mutation issues.
    Download the FPGA Module installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    To install LabVIEW and the FPGA Module using the LabVIEW Platform media, complete the following steps:
      • LabVIEW
      • FPGA Module
      • Xilinx Compilation Tools—Install these compilation tools on the development computer if you want to compile your LabVIEW FPGA VIs locally. You must install these tools on your development computer if you plan to use the Configure Component-Level IP wizard, configure the IP Integration Node, incorporate Xilinx IP, or use third-party simulation. Refer to your hardware documentation for information about the FPGA chip in your device and install the appropriate set of tools. Visit ni.com/info and enter the Info Code XilinxCompileTools for more information about the NI hardware supported by each Xilinx compilation tool.
        • Xilinx Compilation Tools for Windows—Install these compilation tools if you will compile your FPGA VIs on a Windows computer. The recommended compilation tool for Windows is Vivado 2021.1. ISE Compilation tools are NOT supported on Windows 10.
    • Linux—Refer to the FPGA Module Xilinx Compilation Tools for Linux Readme for information about setting up a remote compile worker.
    The FPGA Module (64-bit) provides access to more memory than the FPGA Module (32-bit) can provide. The FPGA Module (64-bit) is available in English only.
    Visit FPGA Target Support for the LabVIEW FPGA Module 64-bit for information about the NI hardware devices supported by the FPGA Module.
    You cannot use an unsupported device with the FPGA Module (64-bit) or run example VIs that require an unsupported device in the FPGA Module (64-bit). Refer to the specific hardware documentation for more information about compatibility with the FPGA Module (64-bit).
    If you upgrade from the LabVIEW 2019 FPGA Module or later to the LabVIEW 2023 Q1 FPGA Module, you might encounter the following compatibility issues:
    Vivado Version Upgrade—The Vivado compilation tool version is upgraded from 2019.1 to 2021.1. The following are the changes and compatibility issues:
    • UHD-SDI Audio is no longer supported on targets with Xilinx Kintex-7, Virtex-7, Zynq, and Zynq UltraScale+ series FPGA.
    • DSP48 Macro has been renamed to DSP Macro.
    • The following functions are no longer available on the Xilinx IP palette:
      • Color Correction Matrix
      • Color Filter Array Interpolation
      • Gamma Correction
      • Image Enhancement
      • RGB to YCrCb Color-Space Converter
      • Video On Screen Display
      • YCrCb to RGB Color-Space Converter
    • If you open a VI saved in a previous version of LabVIEW that contains an IP Integration Node or Xilinx IP node, complete the following steps to regenerate or reconfigure files.
      IP Integration Node
      Xilinx IP Node
      • Regenerate support files for the IP by selecting Tools»FPGA Module»Regenerate IP Integration Node Support Files from LabVIEW and following the on-screen instructions.
        Note  If LabVIEW fails to update all support files, re-add the IP Integration Node to the VI and generate the support files for the IP Integration Node.
      • If the IP Integration Node contains Xilinx Vivado IP configuration (.xci) files, continue with the following steps:
        • Regenerate the Xilinx Vivado IP configuration (.xci) files in the latest Xilinx compilation tools for Vivado.
        • Re-add the configuration files to the IP Integration Node.
        • Re-add the IP Integration Node to the VI.
        • Generate the support files for the IP Integration Node.
      • Regenerate support files for the Xilinx IP node by selecting Tools»FPGA Module»Regenerate IP Integration Node Support Files from LabVIEW and following the on-screen instructions.
      • Verify the behavior of the Xilinx IP node.
      • Reconfigure the Xilinx IP node if its behavior has changed.
      Upgrading the FPGA Module requires you to upgrade to a new version of the Xilinx compilation tools. This upgrade can change the timing or resource utilization characteristics of FPGA VIs you developed in previous versions or cause these VIs to fail to compile. NI recommends that you test all FPGA designs after upgrading.
    LabVIEW FPGA Module no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2026-1-13 09:39
