查看: 476|回复: 0
[NI驱动程序] NI-HSDIO 2025 Q1 Win11 32/62bitEng/Jpn NI高速数字输入输出仪器驱动程序25.0.0
    昨天 08:27
  • 签到天数: 3595 天
    连续签到: 3 天
     楼主| 发表于 2025-4-3 11:50:14 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-HSDIO
    NI-HSDIO为使用NI PXI数字波形仪器或数字波形设备的客户提供支持。
    NI-HSDIO是与数字波形硬件进行通信的NI仪器驱动程序,用于执行高速DIO  (HSDIO)任务。该驱动程序软件包含基于IVI准则的灵活API、完整的硬件支持文档,以及配置和测试实用程序。
    NI-HSDIO 2025 Q1
    发布日期:2025/1/23
    包含的版本:2025Q1完整版,版本号25.0.0
    支持的操作操作系统:
    语言:英语English/日语Japanese
    文件大小: 1678952448 字节 (1.56 GB)
    修改日期: 2025-03-13 14:26
    MD5: 638bf17a737475df341ac4060dbeda5d
    SHA1: f94207521040dfe4795d242373bd43df08348e63
    SHA256: e05f454c5bc655b57650961c683e4836403e5b1508065364c9aaf519f0dca7b3
    CRC32: 0e8881d2
    请注册登录视觉论坛,购买附件后查看下载地址
    HSDIO2025Q1.txt (514 Bytes, 下载次数: 0, 售价: 10 元)
    2025Q1版未更新自述文件,参考2022Q4版
    NI-HSDIO 2022 Q4 Readme
    October 2022
    This file contains installation instructions and compatibility information for NI-HSDIO 2022 Q4.
    • NI-HSDIO Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-HSDIO Documentation: New features, behavior changes, and other documentation
    NI-HSDIO provides support for customers using NI digital waveform generators/analyzers. To program NI digital waveform generators/analyzers, use the NI-HSDIO API.
    • 1 GHz or faster 64-bit (x64) processor
    • 2 GB RAM (64-bit)
    • 1024 x 768 screen resolution
    NI-HSDIO 2022 Q4 supports the following operating systems:
    Note  NI-HSDIO does not support any 32-bit Windows operating system. Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes.
    NI-HSDIO 2022 Q4 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by NI-HSDIO
    LabVIEW2019 and later
    LabWindows/CVI2017 and later
    Microsoft Visual C++ (MSVC)6.0 and later
    Note  NI-HSDIO 2022 Q4 does not support self-calibration of the NI PXIe-6556 with LabVIEW Real-Time Module. Use NI-HSDIO 15.0 and LabVIEW 2012 to perform self-calibration of the PXIe-6556 with LabVIEW Real-Time Module.
    If you are using the NI-HSDIO .NET Class Library, .NET Framework 4.0 (minimum) is required. The NI-HSDIO 2022 Q4 .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the NI-HSDIO installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager.
    If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation method of the Suite or Bundle.
    Note  NI Script Editor is no longer installed with NI-HSDIO.
    NI-HSDIO no longer installs IVI Compliance Package (ICP). NI-HSDIO supports IVI configuration and runtime, but no longer installs the following IVI components:
    • IVI-COM Adapters
    • Added support for LabVIEW 2022
    • PXIe-6555 and PXIe-6556 no longer support self-calibration.
    Refer to the NI-HSDIO Help, accessible from Start»All Programs»National Instruments»NI-HSDIO»Documentation, for information about the NI-HSDIO API and NI digital waveform generators/analyzers.
    The documentation set is composed of the following documents:
    Document
    Format
    Description
    NI Digital Waveform Generator/Analyzer HelpHTML/Windows HelpContains instructions for opening, configuring, initiating signal generation, and closing the session. Also, contains information about programming and fundamentals.
    NI Digital Waveform Generator/Analyzer Getting Started Guide for your devicePrinted and PDFContains software and hardware installation, MAX configuration, signal connection, and troubleshooting information for your device.
    Specifications for your devicePDFContains specifications for the capabilities and valid operating conditions of your NI device.
    NI-HSDIO ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    File Locations and ExamplesInstalled Software
        • (32-bit) Program Files\IVI\
    Item
    Installed Location
    NI-HSDIO\Drivers\niHSDIO
    NI-HSDIO Examples\NI-HSDIO\Examples
    NI-HSDIO Header files\Include
    NI-HSDIO Import Library files (32-bit)\Lib
    NI-HSDIO Import Library files (64-bit)\Lib_x64
    NI-HSDIO DLL (32-bit)\Bin
    Additional File Locations for 64-bit operating systems
    Item
    Installed Location
    NI-HSDIO DLL (64-bit)\Bin
    NI-HSDIO no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2003–2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-7-17 01:18
