查看: 1084|回复: 0
[原创] Halcon所有类及类下算子作用索引-HOperatorSet算子集(19)(17.12~24.11版)
    昨天 08:15
  • 签到天数: 3857 天
    连续签到: 50 天
     楼主| 发表于 2025-2-10 10:24:15 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    HOperatorSet算子集(19)
    类分组所有HALCON算子。
    InterpolateScatteredDataPointsToImage插值散乱数据点至图像
    Creating an image from the interpolation of scattered data.
    通过插值散乱数据创建图像。
    InterruptOperator中断算子(18.11)
    Attempt to interrupt an operator running in a different thread.
    尝试中断在不同线程中运行的算子。
    IntersectLinesOfSight相交视线
    Get a 3D point from the intersection of two lines of sight within a binocular camera system.
    从双目相机系统内两条视线的交点获取3D点。
    IntersectPlaneObjectModel3d相交平面对象模型三维
    Intersect a 3D object model with a plane.
    将三维对象模型与平面相交。
    Intersection交集
    Calculate the intersection of two regions.
    计算两个区域的交集。
    IntersectionCircleContourXld交集圆轮廓扩展线描述
    Calculate the intersection points of a circle or circular arc and an XLD contour
    计算圆或圆弧与XLD轮廓的交点
    IntersectionCircles交集
    Calculate the intersection points of two circles or circular arcs
    计算两个圆或圆弧的交点
    IntersectionClosedContoursXld交集闭合轮廓扩展线描述
    Intersect closed contours.
    相交闭合轮廓。
    IntersectionClosedPolygonsXld交集闭合多边形扩展线描述
    Intersect closed polygons.
    相交闭合多边形。
    IntersectionContoursXld交集轮廓扩展线描述
    Calculate the intersection points of two XLD contours
    计算两个XLD轮廓的交点
    IntersectionLineCircle交集线圆
    Calculate the intersection points of a line and a circle or circular arc
    计算直线与圆或圆弧的交点
    IntersectionLineContourXld交集线轮廓扩展线描述
    Calculate the intersection points of a line and an XLD contour
    计算直线和XLD轮廓的交点
    IntersectionLines交集线
    Calculate the intersection point of two lines
    计算两条线的交点
    IntersectionLl交集线线
    Calculate the intersection point of two lines.
    计算两条线的交点。
    IntersectionRegionContourXld交集区域轮廓(24.05)
    Intersect a contour with a region.
    将轮廓与区域相交。
    IntersectionSegmentCircle交集线段圆
    Calculate the intersection points of a segment and a circle or circular arc
    计算线段与圆或圆弧的交点
    IntersectionSegmentContourXld交集线段轮廓扩展线描述
    Calculate the intersection points of a segment and an XLD contour
    计算线段和XLD轮廓的交点
    IntersectionSegmentLine交集线段线
    Calculate the intersection point of a segment and a line
    计算线段和线的交点
    IntersectionSegments交集线段
    Calculate the intersection point of two line segments
    计算两条线段的交点
    InvertFunct1d反函数一维
    Calculate the inverse of a function.
    计算函数的反函数。
    InvertImage反转图像
    Invert an image.
    反转图像。
    InvertMatrix反转矩阵
    Invert a matrix.
    反转矩阵。
    InvertMatrixMod反转矩阵模
    Invert a matrix.
    反转矩阵。
    IsotropicDiffusion各向同性扩散
    Perform an isotropic diffusion of an image.
    对图像进行各向同性扩散。
    JsonToDict JSON至字典(21.11)
    Transform a JSON string into a dictionary.
    将JSON字符串变换为字典。
    JunctionsSkeleton交点骨架
    Find junctions and end points in a skeleton.
    在骨架中查找交点和端点。
    KirschAmp Kirsch振幅
    Detect edges (amplitude) using the Kirsch operator.
    使用Kirsch算子检测边缘(振幅)。
    KirschDir Kirsch方向
    Detect edges (amplitude and direction) using the Kirsch operator.
    使用Kirsch算子检测边缘(振幅和方向)。
    LabelToRegion标签至区域
    Extract regions with equal gray values from an image.
    从图像中提取具有相等灰度值的区域。
    Laplace拉普拉斯
    Calculate the Laplace operator by using finite differences.
    使用有限差分计算拉普拉斯算子。
    LaplaceOfGauss高斯拉普拉斯
    LoG-Operator (Laplace of Gaussian).
    LoG算子(高斯拉普拉斯算子)。
    LearnClassBox学习类盒子
    Train the classifier.
    训练分类器。
    LearnNdimBox学习N维盒子
    Train a classificator using a multi-channel image.
    使用多通道图像训练分类器。
    LearnNdimNorm学习N维范数
    Construct classes for ClassNdimNorm.
    为ClassNdimNorm构建类。
    LearnSampsetBox学习样本集盒子
    Train the classifier with one data set.
    用一个数据集训练分类器。
    LengthXld长度扩展线描述
    Length of contours or polygons.
    轮廓或多边形的长度。
    LineOrientation线方向
    Calculate the orientation of lines.
    计算线的方向。
    LinePosition线位置
    Calculate the center of gravity, length, and orientation of a line.
    计算线的重心、长度和方向。
    LinearTransColor线性变换颜色
    Compute an affine transformation of the color values of a multichannel image.
    计算多通道图像颜色值的仿射变换。
    LinesColor线彩色
    Detect color lines and their width.
    检测彩色线及其宽度。
    LinesFacet线小面
    Detection of lines using the facet model.
    使用小面模型检测线。
    LinesGauss线高斯
    Detect lines and their width.
    检测线及其宽度。
    ListFiles罗列文件
    List all files in a directory.
    罗列目录中的所有文件。
    LoadDlModelWeights加载深度学习模型权重(21.05)
    Load the weights of a source model into a target model.
    将源模型的权重加载到目标模型中。
    LocalMax局部最大
    Detect all local maxima in an image.
    检测图像中的所有局部最大值。
    LocalMaxContoursXld局部最大轮廓扩展线描述
    Select XLD contours with a local maximum of gray values.
    选择具有局部最大灰度值的XLD轮廓。
    LocalMaxSubPix局部最大亚像素
    Subpixel precise detection of local maxima in an image.
    图像中局部最大值的亚像素精度检测。
    LocalMin局部最小
    Detect all local minima in an image.
    检测图像中的所有局部最小值。
    LocalMinMaxFunct1d局部最小最大函数一维
    Calculate the local minimum and maximum points of a function.
    计算函数的局部最小值和最大值。
    LocalMinSubPix局部最小亚像素
    Subpixel precise detection of local minima in an image.
    图像中局部最小值的亚像素精度检测。
    LocalThreshold局部阈值
    Segment an image using local thresholding.
    使用局部阈值分割图像。
    LockMutex锁定互斥锁
    Lock a mutex synchronization object.
    锁定互斥锁同步对象。
    LogImage对数图像
    Calculate the logarithm of an image.
    计算图像的对数。
    LookupLexicon查找词典
    Check if a word is contained in a lexicon.
    检查词典中是否包含单词。
    Lowlands低地
    Detect all gray value lowlands.
    检测所有灰度值低地。与之相关的则是Plateaus高原。
    LowlandsCenter低地中心
    Detect the centers of all gray value lowlands.
    检测所有灰度值低地的中心。
    LutTrans查找表变换
    Transform an image with a gray-value look-up-table.
    使用灰度值查找表变换图像。
    MakeDir创建目录
    Make a directory.
    创建一个目录。
    MapImage映射图像
    Apply a general transformation to an image.
    对图像应用常规变换。
    MatchEssentialMatrixRansac匹配本质矩阵随机搜索
    Compute the essential matrix for a pair of stereo images by automatically finding correspondences between image points.
    通过自动查找图像点之间的对应关系来计算一对立体图像的本质矩阵。Ransac:randomized search随机搜索算法。
    MatchFunct1dTrans匹配函数一维变换
    Calculate transformation parameters between two functions.
    计算两个函数之间的变换参数。
    MatchFundamentalMatrixDistortionRansac匹配基础矩阵畸变随机搜索
    Compute the fundamental matrix and the radial distortion coefficient for a pair of stereo images by automatically finding correspondences between image points.
    通过自动找到图像点之间的对应关系,计算一对立体图像的基础矩阵和径向畸变系数。
    MatchFundamentalMatrixRansac匹配基础矩阵随机搜索
    Compute the fundamental matrix for a pair of stereo images by automatically finding correspondences between image points.
    通过自动查找图像点之间的对应关系来计算一对立体图像的基础矩阵。
    MatchRelPoseRansac匹配相对姿态随机搜索
    Compute the relative orientation between two cameras by automatically finding correspondences between image points.
    通过自动查找图像点之间的对应关系来计算两个相机之间的相对方向。
    MaxDiameterObjectModel3d最大直径对象模型三维
    Calculate the maximal diameter of a 3D object model.
    计算3D对象模型的最大直径。
    MaxImage最大图像
    Calculate the maximum of two images pixel by pixel.
    逐像素计算两个图像的最大值。
    MaxMatrix最大矩阵
    Returns the elementwise maximum of a matrix.
    返回矩阵的元素最大值。
    MaxParallelsXld最大平行扩展线描述
    Join modified XLD parallels lying on the same polygon.
    连接位于同一多边形上的修改后的XLD平行线。
    MeanCurvatureFlow平均曲率流
    Apply the mean curvature flow to an image.
    将平均曲率流应用于图像。
    MeanImage均值图像
    Smooth by averaging.
    通过平均平滑。
    MeanImageShape均值图像形状(22.05)
    Smooth image using a mean filter with arbitrary mask.
    使用具有任意掩模的均值滤波器平滑图像。
    MeanMatrix均值矩阵
    Returns the elementwise mean of a matrix.
    返回矩阵的元素平均值。
    MeanN均值N
    Average gray values over several channels.
    多个通道的平均灰度值。
    MeanSp均值椒盐
    Suppress salt and pepper noise.
    抑制椒盐噪音。
    MeasurePairs测量对
    Extract straight edge pairs perpendicular to a rectangle or annular arc.
    提取垂直于矩形或环形弧的直边对。
    GMT+8, 2026-4-16 00:03
